Question about Sharp Office Equipment & Supplies
What do it do to fix ''maintenance required Code: CA''
This machine has multiple codes that will cause it to stop printing. Is there any place that has all the codes, and how to fix or re-set them on the machine? Sharp MX-2700N copier
  • Sharp Master
  • 1,294 Answers
The service acces code C-0-0-C,or C - interupt key -0-interupt key.Acces the list of commands maintenance preset counter setting and set to a new value,or maintenance counter clear.
Posted on Aug 02, 2009
What does code DY means and how can I fix it
DY THE DRUM CARTRIDGE PRINT COUNTER (YELLOW) REACHES 60,000 SHEETS OR THE ACCUMULATED NUMBER OF ROTATIONS OF THE DRUM (YELLOW) REACHES 715K
If your machine is displaying one of these codes let your service provider know. The codes indicates that the respective drum cartridge has reached it's maintenance or replacement interval. The machine will continue to print normally but you may experience copy quality problems on your printed pages. When the service has been performed the service provider will reset the counter and the code will stop being displayed. In some cases, the machine may be set to stop printing when this code is displayed.
Oct 16, 2014 | Sharp MX-2700N Color Copier
How do I find out how many pages are on the current drum in my Brother 2820 machine
You must enter in maintenance mode:
Press the Menu/Set and Start keys. Next press the key four times to make the machine enter
the maintenance mode, or turn on the machine while pressing the menu/set key.
The machine beeps for approx. one second and displays "MAINTENANCE " on the LCD,
indicating that it is placed in the initial stage of the maintenance mode, a mode in which the
machine is ready to accept entry from the keys.
Display of the Equipment's Log Information (Function code 80)
Function
The equipment may display its log information on the LCD.
Operating Procedure
(1) Press the 8 and 0 keys in this order in the initial stage of the maintenance mode.
The USB serial number appears on the LCD.
(2) Press the Start key. Each time the Start key is pressed, one of the following log
information items appears on the LCD in the order given below.
1) Jam count, indicating how many times a paper jam has been occurred
2) Page count, indicating how many pages the photosensitive drum has been printed
3) Total page count, indicating how many pages the equipment has been printed since
produced
4) Drum count, indicating how many times the photosensitive drum has been rotated
5) Drum change count, indicating how many times drum replacement has been made
6) Toner change count, indicating how many times toner replacement has been made
7) Copy page count, indicating how many copies have been made
8) PC print page count, indicating how many pages the equipment has been printed as
an output device of the connected PC
9) FAX page count, indicating how many received FAX pages have been printed
10) Error code of the most recent machine error *1
11) Error code of the most recent communications error *2
12) ADF jam count, indicating how many times a document jam has been occurred
13) ADF page count, indicating how many documents have been fed
(3) To stop this operation and return to the equipment to the initial stage of the maintenance
mode, press the Stop/Exit key
To exit maintenance mode press 99
Mar 07, 2011 | Brother IntelliFax-2820 Laser Fax
What does Print unable 71 mean and what do I have to do to correct the problem?
Error code 71
Print Unable 71
Turn the power off and then back on again.
Polygon motor failure
Jan 03, 2011 | Brother MFC-9840CDW Laser Printer
Maintenance code TA does the printer go offline
Ok so the TA code means that the all maintenance counter has reached its limit
To clear this you need to clear this easy you want
# , * , c , *
To enter service mode
Type in code 24 press start
Then you want sub code 04
Then you can select what you want to clear so the maintenance count all
Execute this yes then press the CA key the machine will restart and away you go
I also do advise that you service representative comes along at some point to check the machine it could need parts because if you stretch the life of parts your machine could become unreliable... But that is up to you.
Jun 05, 2010 | Sharp MX-2700N Color Copier
Maintanance required code TA
# , * , c , *
May 11, 2010 | Sharp MX-2300N Color Copier
What is "Maintenance required. Code: AA"
Maintenance timing display The message of maintenance execution timing is displayed when each counter reaches the set value. The relationship between the messages and the counters is shown blow. Maintenance counter AA WhenThe maintenance counters (both of total and color) reaches 90% of the set value of SIM21-1 (When the setting of SIM26-38 is ?print stop?). When The maintenance counters (both of total and color) reaches the set value of SIM21-1 (When the setting of SIM26-38 is ?print allowing?). Enable ? After completion of the maintenance, execute SIM 24-4 (Maintenance counters (total, color) clear).
Aug 29, 2009 | Sharp MX-2700N Color Copier
I have a sharp copier MX2700N with an error code of TK2. Will this cause the copier to stop printing and is there a way to clear it
The TK2 means its time to replace the secondary transfer belt. Depending on your copier and driver setup it may prevent you from printing. If you open your print driver properties and go to the ports tab and then click on configure port button, in the next window uncheck "SNMB printing" option - this should allow you to print. You can clear the maintenance code by going into the SIM mode. press the following keys one after the other "P" "*" "C" "*" then enter 24 and "copy start key" then enter 4 (maintenance clear) and copy start key then highlight the items you want to reset and press execute then yes. restart the copier by pressing the "CA" key. do not make adjustments to other sim code items as it can render copier useless!
hope that helps.
Apr 06, 2009 | Sharp MX-2700N Color Copier
Brother IntelliFax 1840C
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If that doesnt give you the code then try going into service mode by pressin menu key then *, 2 , 8, 6, 4  super quick!! Display goes blank or Maintenence mode is displayed, if not... not quick enough, do again to you get it, then press 77 start, error should display. press 99 to exit Maintence mode, dont play with other numbers!!
a couple of the most common errors are
Error 41 needs new print head costly
error 46 waste ink full, need new waste tank
Whats yours?
Oct 30, 2007 | Brother IntelliFAX 1840C Plain Paper...
1,212 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
