Question about Whynter FX-6SW Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D
My black and decker water cooler makes noise like its boiling water which I know it does but it's much more pronouced and more frequent than before.
Slight boiling noise aside, a loud and unbearable rattling noise plagued my B&D Hot and Cold Water Cooler (top load). DIY Solution: The issue was some sort of copper coil vibrating against the front panel cover (just behind where you would place a glass. This copper colored coil is attached a canister looking thingy ma-bob, with a long black arm that is runs to the bottom right of the back cover. By removing all four screws on the back cover, you may angle (bottom out) the cover enough to gain access to this arm. GENTLY... lift the arm/rod so that the copper coil is no longer touching the front panel (and thus it is free to vibrate without that annoying noise). CAUTION: unplug the unit and ground yourself to avoid shock. Once you can see the coil is no longer touching, plug-er back in and see if the noise has stopped. Perform above at own risk.!!!!!
Posted on Mar 05, 2012
3 Suggested Answers
  • 14 Answers
SOURCE: advise
you need to purge the air out of the "hot" side after placing the bottle on top. If not enough water is inside the chamber the water will boil.
Posted on Jul 10, 2008
SOURCE: Our Hamilton beach water cooler makes a constant
When empty of water remove the back panel and the cooling fins are most likely covered with an inch of dirt! Find an air compressor and blow out the dirt. It worked on mine!
Posted on Feb 19, 2011
Does altitude affect a steam irons ability to produce steam for ironing?
It certainly does.
The higher altitude you're at, the lower the boiling point of water is.
Check the link below for proof.
-Steve
Boiling Points of Water at Various Elevations
Mar 14, 2015 | Applica Black And Decker Steam Iron
There are too much mineral residue in the bottom of ny kettle PLs show me how to remove it , my is about 10 month s old!!
You can remove it by using baking soda, or use the stain remover available in household hardware shop. There instruction in the box so just follow it.
Also when mineral residue is remove. Use a fitered water for boiling the water, filtered water doesn't stain must compare to tap water.
I hope I help you solve your problem.
Mar 30, 2011 | Black & Decker Black and Decker SmartBoil...
Just want the cold water - Black and Decker 900144
I need to do the same thing. Please let me know if you were able to get this done. It would help me out alot. Thanks you.
May 03, 2010 | Whynter FX-6SW Free Standing Hot & Cold...
Mr. Cuppacino milk frother manual
guess the problem is fixed long time ago? anyway i am happy to let you know if this appliance still annoying you.
i ve one which bought at laverton market some months ago, same problem as yours: no manual and even black and decker ignore my request to send me one. therefore i studied the construction and found out how it use:
1. fill up water to the level which engrave at the cylinder. (can fill hot or boiled water to save electricity and speed up the heating process)
2. when it boil power will off automatically, remember do not overfill to leave room for the generated steam;
3. plug off the power; pull up the looped pin of the bend tube;
4. place your milk jug (of course with milk or soy filled inside may be half full only);
5. press the grey button on the cylinder top (use some more energy; i know it is hard!) steam will come out to frothy your milk. 70c for latte, or 85-90c for cuppancino something like that.
hope this can help!
Nov 29, 2009 | Black & Decker Coffee Makers & Espresso...
How do I clean my Black N Decker Advantage Iron
I work for Black & Decker customer service. Our number is 800-231-9786.
You can obtain a new manual for free by visiting www.useandcaremanuals.com. Below is the section from the manual on care and cleaning of your iron.
Care and Cleaning
This product contains no user serviceable parts. Refer
service to qualified service personnel.
It is not necessary to empty the water reservoir after each
use of the iron, if you iron frequently.
To empty the iron, hold the iron over the sink with the tip
pointing down. Water will stream out of the water fill
opening.
TO CLEAN THE OUTSIDE SURFACES
• Unplug and allow iron to cool completely. Wipe the
soleplate and outer surfaces with a soft cloth
dampened in water and a mild household detergent.
Never use abrasives, heavy duty cleansers, vinegar, or
scouring pads that may scratch or discolor the iron.
• After cleaning, iron with steam over an old cloth to
remove any residue from the steam vents.
ABOUT THE SELF-CLEANING SYSTEM
• Use the self-cleaning system to flush out minerals and
lint. If lint is allowed to accumulate in the vents, it can
scorch and cause brown spotting.
For Models D2000 and D2020: Clean about once a
month.
For Models D2010, D2030 and D2035: A "CLEAN"
indicator will appear in the digital display to notify you
when your iron needs cleaning (A).
• Fill the iron as described in "How to Use" but keep the
water level below the MAX line. Plug in the iron, set
the temperature to 6, and stand the iron on its heel
rest. Allow to heat about 3 minutes.
• Unplug the iron and take it to a sink. Holding it
horizontally over a sink, move and HOLD the variable
steam dial in the CLEAN position ( ). There may be
some hissing and spitting while self-cleaning. This is
normal.
• Stay clear of HOT steam and boiling water as it comes
out of the vents while lint, scale, and minerals flush
through! Continue to hold the variable steam dial in
the CLEAN position until all the water has emptied.
If necessary, rock the iron side to side and front to back
to empty it.
• When finished, release the variable steam dial, stand
the iron on its heel rest, and plug it in. Heat for about
2 minutes to dry out any remaining water then unplug.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Jul 03, 2009 | Black & Decker D2030 Iron
Advise
Jul 07, 2008 | Hamilton Beach Water Cooler with Storage...
Whynter FX-6SW Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D Logo
2,177 people viewed this question
Top Whynter Water Filters & Coolers Experts
Tom Chichester
Are you a Whynter Water Filter and Cooler Expert? Answer questions, earn points and help others
