Question about Roxio Creator 2009 Ultimate for PC
Cannot burn AVCHD disk. Get this error
Cannot burn AVCHD disk. Get this error message; Project_BuildToDeviceOAurthorScript call failed Error while writing format (using Vista os)
  • 80 Answers
Burn AVCHD videos on regular DVD discs (DVD-5 or DVD-9) with HD Movie Maker.
Posted on Dec 08, 2009
The problem with creator 2009 has been fixed by the roxio people.
Instead of burning directly to the DVD disk as roxio software states,
one needs to first save this to be AVCHD movie as a file and then burn directly from the file. This works OK, but as stated this is different
from what the software claims. I'm happy. Thanks
Posted on Aug 07, 2009
Dvd don't want to burn
Make sure your blank disks are the right ones for your drive.
If they are, then the drive has likely failed or its software is corrupted.
Mar 26, 2015 | Sony VAIO VGC-V517G (VGCV517G17TVPC) PC...
I am having issues burning dvd or blue ray from my mac with adobe premiere elements. It is an external burner connected via USB works fine with final cut but has error message with elements. Says " device...
Try burning an iso image file instead from the program, then you can use the built in mac software to burn that disk image file to a disc. Sometimes in video editing there is a problem with the process of compiling the video to a disk. Try a simple very short project with a dvd-rw (reusable) disc to see if it still gives the error.
Apr 11, 2014 | ASUS Computers & Internet
Its says write error when I go to burn a avi file onto a dvd disc
Is the AVI file less than 4.7 GB in size?
Does the "write error" happen more than once?
Did it happen only with one "blank" disk?
Can you select some other file, and successfully write it to a disk?
How many seconds after clicking "start burn process" does it take before you get the error-message?
After getting the "write-error", look at the disk.
Does it appear that anything has been burned onto the disk?
If you put the disk into some other DVD-reader, is it still reported as 'blank" ?
Jun 12, 2010 | Computers & Internet
In Roxio Creator 10, I attempt to burn a disk of a slide show. I receive an error message 8004520C When I check production it reports no problem. This is repeatable.
Generally, defragmenting your hard disk will resolve this issue. To defragment your computer:
  1. Go to Start--> Programs --> Accessories --> System Tools --> Disk Defragmenter.
  2. When the Disk Defragmenter window opens, choose Defragment.
If defragmentation doesn't resolve the issue, burn your project as a data file, and then burn your project as a data disc using Disc Copier or Creator Classic. To create a disc image/data file:
  1. After clicking the Burn button, the Burn Project window opens.
  2. You have two data burning options:
    • Image file - this option will save your project as an .ISO file. To burn this file you will need to use the Burn Image option in Creator's Copy section.
    • Folder Set - burning a folder set will create a Video_TS folder that you can burn using Creator Classic. Burning a folder set to DVD will create a fully functional DVD. Do NOT rename the Video_TS folder other wise it will not play! Simply place it in a folder that is the name of your project if you need to keep track.
May 25, 2010 | Roxio Easy Media Creator 10 Suite
My Cd burner is not burning a complete disk
the ans is simple tht burn the project again on an fresh cd and play it
Dec 20, 2009 | Toshiba Satellite M55 Notebook
Roxio dvd disk type doesn't match project type
Check the following parameters
- Type of disk--> it must be a DVD RW disk (Read and write), if the media is only DVD R, you can't burn it
- Your DVD driver--> Check if it accepts DVD RW(-) or DVD RW(+) or both. With this information, check if the media matches the driver capability
- Roxio settings--> In the Main Menu select--> Disc--> Disk information--> confirm that the right driver is selected (drive D or E or the letter your computer uses for the DVD driver)
Nov 07, 2008 | Roxio Easy Media Creator 7
"Wrong Disk" error
I would assume that you finalized the disk after you burned them. THat being the case try the disk on another DVD player. If that does not work try burning another disk. Its possible that its either a failed burn, a picky DVD player or plain defective disc. So the only option left is to isolate the probelm.
Oct 04, 2008 | Memorex (3202-5639) (50 Pack) (32025639)...
When attempting to burn project in MY DVD8 an error appears 800402007 while encoding. I am therefor unable to burn disc
      Tip: Either of the above options are a great way to not only back up your projects, but make multiple copies to reduce encoding time!
Mar 03, 2008 | Televison & Video
Roxio Creator 2009 Ultimate for PC Logo
381 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
