Question about HP w1907 LCD Monitor
I turn my monitor on and it lights up then goes blank.
T goes blank not 5 seconds into start up, and say it is trying to adjust but then goes blank again. The power light for it is on however.
    Problem Solver:
  • 5 Answers
Sounds like you have a backlight problem, the wires are known to burn off the ends of the bulbs of the back light..if you try to repair it yourself be careful the lcd screen and bulbs are frigile.. there is 4 bulbs two on the top and two on the bottom of the screen ,, keep every thing in order when taking apart
Posted on Jan 13, 2010
  • 3 Answers
SOURCE: Green light and screen flash then go blank every 3-5 seconds and nothing else
Not sure I can tell you the exact nature of the problem with the info you have given. However, here are some trouble shooting tips. These are the things I would do to figure out what is causing the problem: 1. Hook up a monitor that works so that you can make some configuration changes to the graphics card. 2. Find out the native resolution of the LCD monitor that has the problem. Many 17 inch and 19 inch LCD's are 1280 X 1024 with a refresh rate of 60 Hertz. It is quite possible that your previous monitor settings are not compatable with your new LCD monitor. This is an easy fix. So go into your graphics control pannel and start by making sure that your refresh rate is set to 60 and the resolution to 1280 x 1024 or perhaps even lower like 800 x 600 but 1280 x 1024 is fairly standard with many LCD's. 3. With these new settings hook your LCD monitor up again and see if that works. 4. Still not working? ... Then there may be a problem with one of the hardware components in the monitor. When the monitor flashes are you for an instance seeing an actual picture? If so then the problem may be with your lamp controler. It's what controls the brightness etc. of your monitor. What you can try to do is lower the brightness. This sometimes restores the monitor to being useful. ie. you can use the monitor but only at a lower brightness. Setting the monitor to a lower brightenss may be a bit of problem if you can't see the brightness control which is often displayed on the screen itself through the menu function. If you are briefly seeing a picture as it goes through this 3-5 second cycle then hit the hardware menu button on your monitor. You should then see some sort of menu that you can control with the other buttons on your monitor. Find the brightness selection and lower it. You can lower it all the way to 0 and still have plenty of brightness to see a picture. NOte: you may have to make the change in brightness within one cycle of it going off and and on because each time it cycles it's quite possilbe that it resets itself. So in this case you would have to be really quick with the menu buttons on the monitor. It might take a couple of tries (or more) to get the squences of buttons you need to hit to get the brightness down. I had this problem once with a monitor and I was able to get the brightness down but only after many tries. I had to be supper fast with my menu selections. After that was done it worked flawlessly again. 5. Still not working? ... you are right you probably should have bought a new one LOL ... or next time when buying a used one make sure that you see it functioning correctly on a computer before buying it etc... Best of luck. Sincerely, Dean Dean Kenneth Robinson techinfo@ContinuousMix.com
Posted on Aug 16, 2006
  • 53 Answers
SOURCE: Dell E152FPc Monitor powers up, and screen goes blank in 5-10 sec
ok every one there is a fix the are 4 transistor 2sc5707 and 2 transistorfu9024n and i cap 16v1000uf
if you replace these your problem will be fix for a while but to it better then dell replace the 2sc57o07 with radio shack tip3055 they are 15 amp trans instead of the low 8 amp dell uses they fail because the amps at the test for the transistor is more than 8amps all the correct parts are sold in a kit on ebay look up the 2sc5707 but i recommend upgrading to the tip3055 transistors they are a bigger transistor but you can lay them down and they work great. the capicator can be found at radio 35v1000uf is a good replacment make you monitor better because the new parts are stronger then the originals so no more failures after.
Posted on Feb 20, 2009
bunnydawg
  • 5158 Answers
SOURCE: screen goes bank after 2 seconds even if powder light is on
i just finished repairing a 20 inch acer monitor that had the same issue.... you have to take it apart and examine the power supply side of the monitor. there are capacitors that go bad on that board. you can tell be feeling the tops of them... the feel rounded. replace the capacitors and put it back together and it will work fine
Posted on Apr 16, 2009
  • 1684 Answers
SOURCE: Screen comes up for about 10 seconds, then goes blank
Hello Robert,
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Posted on Jun 19, 2009
SOURCE: Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
hello i have the same problem, there are 4 lamps (bulbs) inside the monitor when some of them falls the system turn off, cheks and good look
Posted on Oct 27, 2009
Soyo monitor goes blank after a couple of seconds.
your power supply is bad or the back lights. you need to open the back cover and look for leaking or crown capacitors and replace them.
Dec 30, 2009 | Soyo TFT 19" LCD Monitor
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Could be a power issue. If it doesn't show anything at all then that may be the case. It may also be the display itself. It would be a costly repair so you might be better off finding a new monitor.
Sep 16, 2009 | Samsung SyncMaster 920NW Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
The screen goes blank after 5 seconds
Make sure you have the correct drivers install for you video card. Also, check to make sure your resolution is not set to high for you video card. To get to resolution; right click on Desktop > click Properties > press Settings Tab, from there you can move the slider to change your screen resolution (try different resolutions until it doesn't shut off anymore).
Let me know.
Jul 09, 2009 | ViewSonic VG900b 19" LCD Monitor
Hello Robert,
Buddy
Corporate Computer
Jun 19, 2009 | LG Flatron L1750S 17" LCD Monitor
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Pc does start but monitor is blank but its light is on
What connection are u using? DVI to DVI? VGA to VGA? or are u using DVI+ adapter to change the source to VGA?
Nov 21, 2008 | LG L1717S-BN 17" LCD Monitor
the moniter may be having  some technical errors   maybe the IC's has got corrupt
you need to call the seller of the moniter
Sep 06, 2008 | BenQ FP71G 17" LCD Monitor
Hp1903 blank screen
power shortage maybe...try to plug your monitor on the other power supply,,be sure that your monitor is compatible on the voltage it required..
Aug 04, 2008 | HP vs19 (Silver) 19" LCD Monitor
HP w1907 LCD Monitor Logo
526 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
