Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Beating sound of the drum
Starts bouncing around like it will explode then a UL code come ups or F1 Had the plastic rim replaced inside the first month I had it. Had another repair man come out tell me he need to check into this because it is a new machine he was not sure....HE NEVER CAME BACK! Ok now I own a POS and no money to buy an new washer I have 7 people in this house and it takes 3 hours to wash a small basket of laundry! Whirlpool planning to recall this POS anytime soon?Will they replace this, Its 18 months old? Is there any way to fix it or am I doomed to the laundrymat with a 2 year old in tow again I will NEVER buy a whirlpool product again!!!!!
  • 15,935 Answers
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
Have a Whirlpool Cabrio top loader washing machine, keep getting code F1 during beginning of cycle. Got code uL for the first time today. What do these codes mean.
Have a Whirlpool Cabrio top loader washing machine, keep getting UL code when spin on high speed and the machine bangs all over the place.. Model num wtw6300sw0 Type 581
Aug 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
How to creat hiphop beat
I will walk you through standard hip hop beat construction and give you some sound development and production tips. There are two basic parts to a typical hip hop song: The Beat and the Vocals. Each consists of several tracks. While this article focuses on the construction of beats, lets lead off with a description of all the elements of a hip hop song so you can see how the beat fits .
This is the most important term to understand in Hip Hop construction, cause if you don't know it, you'll never understand what people are talking about. The Beat is basically, the whole song minus the vocals. It usually includes the following:
MIDI Drum patterns or audio drum loops, which comprise the complete drum tracks
A Bassline (MIDI sequence typically)
Supporting Orchestration (could be synth pads, string sections, horns)
Dubs and snips (samples that accent and give character)
Laying Down A Melody- This is where most hip hop beat-makers have the most trouble. Because most eat makers can't play the keys. For starters, you might want to learn basic keyboard skills. The major thing you need to learn are, major and minor scales. After you learn that, try and do different combinations and patterns with the drum beat you have made. Use an instrument like, a lead guitar, horns, clav, something that will stand out. Your melody can be however you want it, but for starters, you could do a 4 bar melody, or an 8 bar melody.
Hardware samplers have been making Hip Hop beats since the beginning. Those outfitted with "pads", like the MPC and MV8000, are convenient to use. However, software samplers, like Kontakt 2, Battery, Halion, Gigastudio are just as good and can offer more flexibility if your computer is strong enough to run one inside a sequencer. You can use a control pad surface like the Akai MPD16 to give you some hardware control over your software.
Hardware or software synthesizers can be used for constructing basslines and other elements of orchestration.
The Bounce- Now that you made you're beat, Its the hottest hip hop beat ever, you want to put it on cd or upload it to the internet. When you're exporting a beat for cd, Use .wav file. 44.1 16bit. If you want to upload to the internet use, 320kbps (the highest .mp3 quality) or 128kbps. Most websites wont accept 320kbps because the file size is too big. So go with 128kbps.
Nov 21, 2010 | Dell Computers & Internet
There is a felt strip that came out of inside the dryer. it popped out from under the rim of the drum part. can i get a replacement part? it the dryer still okay to use?
Yes it is replaceable . Screws up into top from door opening 2 or 4. 2 screws into front from inside case into front . Lift up and out . Felt fits in groove around bottom of plastic frame and drum just rubs against it .
Oct 29, 2010 | General Electric DRSR483GG Dryer
Spin Cycle - washer starts bouncing around room even though level
There are about 6 pairs of springs to hold the bottom tube to the bottom chassis. If some of these came off from designed positions, the tube won't be in balance then the washer starts bouncing off. Make sure these pairs of springs in place then you have no problem.
Sep 15, 2009 | Washing Machines
Rhythmic noise on passenger side of dash.
It sounds like you have an hvac actuator problem.It could be the recirculate actuator either way the system should be scanned and after replacement it has to be calibrated.
Aug 06, 2009 | 2004 Pontiac Vibe
Dryer sounds like there is a sneaker bouncing around inside it starts out really loud and then quiets down and then starts up load again
open the case the drum has come loose and you just need ta replace the front seal most likely
Aug 04, 2009 | Dryers
Noise in dryer
Does the drum turn smoothly, or does it bounce around? If it bounces, it could be the bearings in the drum wheels going out. The wheels would need to be replaced ($20 on up).
Jul 03, 2008 | Maytag MDG9206 Dryer
UL Code
Solved the unbalanced problem - open the top of the machine (press in with a flat putty knife about 3" in on the front on each side while lifting up as there are 2- 1" wide catches). Once both sides are unlatched, raise the lid then slightly lift the rear of the lid so that it fits into the curved part at the top of the hinges then open all the way - tape the lid to the top so it doesn't flap about and scotch the lid to keep it from falling back down on you. Now, look around - see all that rust?  The rust has fallen into and gotten underneath one or more of the 4 white plastic suspension "ball joints" which have probably totally dried out by now from their factory grease because of the water, bleach, and rust particles.  Having someone help you, simply lift up on one of the 4 corner suspension rods - gravity and weight is all that holds them down. The white ball will lift out of the socket and still be attached to the rod. Clean out the rust, lightly sand the "socket" with emery cloth, then slop in a fingerful of grease. I used automotive wheel bearing grease with graphite in it. Also scrub off all embedded rust on the white plastic ball. Lower that corner back into the newly cleaned and greased socket and repeat for the other 3 corners. Now when you move the tub around notice how the balls pivot in their sockets like they are supposed to. When they were dry and rusty they wouldn't move enough to allow the tub to twist like it should so it slammed around.  Now, shake your head in disgust that after only 2 years there is so much rust that you wonder if it will make it another year before falling apart, close the lid, and try another load.  That totally solved my off-balance problem where even a single handkerchief would give the UL error. It is still a finicky machine, but at least once again works like it did when new.
Jan 12, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
250 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
