Question about Kenmore 12102
Bottom thread is so sloppy
The thop threading comes out so perfectly, but the bottom is so messy. Please someone advise on how i can solve this problem. The bobbn always jumbles up in a big ball of thread.
    Problem Solver:
  • 16 Answers
Are you sure the machine is threaded properly? Try tightening the tension. And make sure the bobbin was wound in the correct direction.
Posted on Aug 02, 2009
My Elna sewing machine is sewing very loosely and it is very messy on the bottom side of my material, why?, and how can i fix it?
When your bottom thread is messy it is the top thread needing adjustment. Your machine may not be threaded properly and the thread may not be sitting correctly between the tension discs.
Check to make sure your machine is threaded correctly.
Check thread between the tension discs.
After checking, adjust the tension (tighter) and do a test. If it is still messy add some more tension and do another test.
Jul 10, 2017 | Elna Sewing Machines
Consew machine. My bottom thread has ball knots on the bottom. I have changed the needle and the top stitch is perfect. Please advise.
Re-check the thread that is knotted. It's most likely the top thread causing what is called thread nesting or what I term "thread barfs."
Thread problems appearing on the top of the fabric are generally caused by the bobbin thread. Problems appearing under the fabric are usually a result of upper thread issues.
Remove the top thread.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Set the upper tension to the midway point.
http://www.superiorthreads.com/blog/2015/8/what-causes-bird-nests/
Apr 19, 2017 | Consew Sewing Machines
How hat do to adjust the tension on my Singer 3201 - the under thread is real loose
If the bottom stitches are messy it usually means the top thread isn't threaded correctly.
May 10, 2014 | Singer Sewing Machines
Sewing on top is fine but bottom bobbin keeps sewing messy on the underside domesco sewing machine how do i fix?
It is in your top threading, it is not threaded right. Make sure that there is no tangles in your thread, no bent needle. Check your threading by, presser foot up, pull thread, it should move smoothly, put presser foot down and pull thread again, now it should hardly move. This will seat the thread in the tension discs.
Feb 27, 2011 | Sewing Machines
Bobbin thread keeps knotting
1. Do you mean that there are knots in the bobbin thread?
2. Is the bottom thread in your stitching looping and knotting.
If yes to 1. you need to rewind your bobbin fresh, and keep slight tension on the thread reel that you are winding it from. Put the handle of your scissors into the top of the reel to apply a gentle pressure while winding. Keep your eye on the bobbin as it winds and give it a nudge with a finger tip to ensure it winds the bobbin evenly top, middle and bottom.
If yes to 2, then you need to check your bobbin threading, is the thread even under tension. Is the bobbin tension set correctly. Break out your manual and revisit this to ensure it is set correctly.
Feb 27, 2011 | Brother XL-5340 Mechanical Sewing Machine
How do I adjust the lower (bobin) tension on a Viking 190
I do not recomend that you try to adjust the bottom tension at all, that will cause you alot of problems usually. If your having trouble with the stitches, have you tried an new needle, re-thread and make sure that the thread is seated in both thop and bottom tensions
Aug 20, 2010 | Husqvarna Viking 1
Sewing machine
The top tension pulls the top thread up. The bobbin tension pulls the bottom thread down. A balanced tension is an an even knot between the stitches.
If the thread is messy on the bottom, the top tension is non-existent or is too low. The top thread tension dial should be on 4 or 5. Pull the thread out and re-thread the machine with the presser foot up. If it is still messy, perhaps there is a burr on the bobbin case snagging the thread.
Jun 19, 2009 | Singer Drop-In Bobbin 758B-28BH Mechanical...
The thread bunches at the bottom. It worked fine then one day in the middle of my sewing it bunched. I rethreaded. I adjusted bobbin tensions with the little screw and on top. Help
Welcome to FixYa! I am the sewing machine expert that chose to help you with your issue.
There are really only two things that can cause bottom (note: remember that problems with the bottom thread, almost always comes from the top and not the bobbin. Bobbins rarely need tension adjustments). These two things are:
  1. An area was missed when the machine was threaded (most machines have an arrow at each area on the thread path where the thread MUST run or the stitch on the bottom will be sloppy. Threading can be tricky and even the most experienced miss once in a while.
  2. The tension adjustment mechanism in the thread path. If the thread is not properly through this area, the thread on the bottom will be sloppy or if, threaded properly, and the tension is set too loose, the stitch will be sloppy. If the tension is set too tight, the bottom thread will be tight and pucker the fabric.
It is counter-intuitive that problems with the top tension cause problems with the bottom stitch but it sure will.
So try it and see if that helps.
Thanks for using FixYa.com
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further.
Jan 31, 2009 | Singer 3116 Simple
Loose stitch
Welcome to FixYa. I am the sewing machine expert that chose your issue to solve.
When everything seems to be working fine and an occasional stitch is loose.....now get ready.......here it is.......the needle!
It seems impossible, but the needle is the most neglected part of the machine. The one you are using could be slightly bent or have a slight burr that you won't see with the naked eye. Also, needles, especially in an embroidery machine (which work their buns off), are only good for about 8 hours of cumulative use. I would say that an embroidery needle should be retired after 3 or 4. They get dull like a razor blade which can cause enough drag to create a timing issue that's barely perceptible.
Jan 31, 2009 | Bernina Bernette 75
Bobbin on 12102 kenmore
Welcome to FixYa!
Don't mess with the bobbin! They rarely need adjustment. Sloppy bottom stitches usually come from two things. Tension too loose on the tension dial or improper threading.
Dial tension should be set on about the mid range and you must, must, must, make sure that you have the machine in the proper thread patch. Have someone check it with you. Sometimes a fresh set of eyes will help you spot an area that you missed.
Thanks and if you found my solution helpful, please reward me with a FixYa rating.
Sep 26, 2008 | Kenmore 12102
Kenmore 12102 Logo
129 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
