Question about KitchenAid KSCS25IN Side by Side Refrigerator
KitenAid KSRX25F -- HOT FRONT FRAME
I have a Kitchenaid KSRX25F refrigerator. The freezer portion works fine but the fridge side recently quit working. I unplugged it then plugged it back in and it is working again but there is one thing that rally concerns me. There is a divider between the freezer side and the fridge side. The front of this divider, where the doors essentually meet, is extremely hot. It has been like this for a while, over a year, but in the last two weeks it has gotten much hotter. Any clue how to fix this???
  • 1,606 Answers
The fan which cools the compressor is not working , OR , the coils under the front of fridge are very dirty .
Posted on Aug 01, 2009
I have a KSCS25INWH. I had the same problem- that is door frame very hot because the cooling fan was not running in conjunction with the compressor. My frig is only 6 years old. Trouble shooting was tough because the fan worked intermittantly. Anyway, I replaced the fan motor, replaced the inverter box, and replaced the control board. None of these fixed the problem ($425). Don't try to get help from KitchenAid/ Maytag. There is no one to talk to or email for help. I even asked, "What if a technician needs help? Who do they call?" I was told, "They have a special number. We don't give that out to customers." Now I've disconected the harness from the control box, then blew air into the connection terminals to get rid of any dust, and reconnected. So far it seems to be working. On my frig this box is up against the far left wall and not attached to the base unit. ...hope this helps somebody...
Posted on Dec 13, 2010
I have a GSS22IBMA GE side buy side. The fridge side works fine but the freezer will not freeze. Also it is hot around the the door frame of the freezer sometime quite hot.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 08, 2011 | GE Refrigerators
The black strip down the middle of the fridge ( between the fridge and freezer) is VERY hot to touch..for about 2 days. just for the record our ice machine hasnt worked for a year..I dont know if they are...
check you condenser fan motor to see if there something jammed in fan or if it just quit running, remove back panel to acces fan motor, that would cause that center mullion to get very hot
Sep 07, 2010 | KitchenAid Superba Architect KSCS25INSS...
The middle part of the fridge frame where the side by side doors close onto is very hot to the touch. The fridge and the freezer portion themselves are working properly, but I just leaned on the frame in...
I had the same problem. I had just brush cleaned my coils and then it began. When I took the back off the fridge, I saw the fan was not spinning. I unplugged the fridge and then tried to spin the fan blades. I had inadvertantly bent a blade so it would not spin. I bent the blade back into shape and turned it on. The fan worked and very quickly the middle was no longer hot.
Apr 18, 2010 | Refrigerators
The frame where the doors close onto is hot to the
Hi Mr Hodjati,
No this is not normal. You have a failure of air flow in your condenser. I will explain how to repair if you wish to make the repair youself. If this is not addressed you will soon realize a reduction in cooling and a higher use of energy.
There is a fan that pulls air in from the lower right side front of the refrigerator grille located below the fresh food door, and exhausts the air on the left side of this same grille. Remove this grill and clean the coils with a vacume cleaner and a brush. Pull the refrigerator out so you can get behind the unit. Unplug the power cord from the wall. Next remove the screws from the panel behind the refrigerator near the bottom, the panel may look like a piece of cardboard, but it is a critical component. Once this panel is removed you will see the fan motor and fan blade, make sure nothing like a food wrapper or animal is stuck in the fan causing it to be stuck. If it turns free by hand (it will be real hot down there so be careful), then the motor needs replaced. If you send me the model number I can find you the replacement part number. Let me know if this helps.
Apr 18, 2010 | KitchenAid Architect 24.5 Cu. Ft....
Amana 25 Cu. ft. French door Freezer Fridge quit
IN MOST CASES THERE IS A FAN THAT SENDS COLD AIR FROM THE FREEZER TO KEEP THE FRIDGE COLD. EITHER YOUR FAN MOTOR HAS GONE BAD OR YOUR THERMOSTAT IN YOUR FRIDGE IS BAD.
Feb 20, 2010 | Televison & Video
Kitchenaid fridge #KSCS25INSS hot door frame
There are heaters located inside the door frame, to prevent your doors from freezing shut, and also to prevent condensation on the outside of the appliance. It sounds to me as though that is where your problem is... Hope this helps
Sep 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Zanussi ZFC 45/30 SS is hot at front between the doors..
This is normal. This is a defroster to keep moisture from condensation from freezing the doors shut.
Jun 30, 2009 | Refrigerators
Ksrs25ikss01 kitchen aid fridge portion not
1.check if the fan inside the freezer is running
2. if ref runs none stop, defrost timer is out.
3. or it could be the high limit that paired in series with the defrost heater
good luck!
Jun 25, 2009 | KitchenAid Superba Architect KSCS25INSS...
Buzzing sound clicks on and off from underneath fridge
that would be your relay going bad it will stop the fridge all together change it to a 3 and 1 relay
Apr 15, 2009 | Admiral 26 cu. ft. Side-By-Side...
KitchenAid KSCS25IN Side by Side Refrigerator Logo
372 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
