Question about Sony PSP-3000 Silver Console
Well I'm trying to use internet on my psp. security thing is wpa-psk(tkip). after i do all the settings & test my connection. it always says; connection error has occured. the attemptto obtain the ip adresse timed out.
  • Sony Master
  • 1,525 Answers
Hello have you try pairing the psp first at the side of the router there should be a pair button once this is done the re enter the wep key
all the best
shaun
Posted on Aug 02, 2009
We have a vizio smart tv but cannoy connect yo wifi.What should we do?
Vizio will not connect with Netgear wi fi, BUT if you want to try it, you have to adjust the security
If you have the skilset then..........
Set your router to use both WPA-PSK (TKIP) and WPA2-PSK (AES) and the TV finally connected using the WPA-PSK (TKIP) security!
Mar 06, 2014 | LG Televison & Video
How to update a psp 3001 via internet
firstly you must have a wireless router that supports wpa-psk or wep settings always remember that psp 3001 does not supports wpa-psk 2 settings
Now open the system update in the settings and then select new connection there are four options for u select the first one(scan)after a few seconds the access point from the router is detected on your psp select the access point there after configure the settings your connected to the internet (enjoy ;- )
Aug 20, 2012 | Sony PSP 3001 Game console - Black w/Games
How do you write an ASCII network encryption key?
Hello. Wireless security strength depends on the mode of encryption you are going to use (WEP, WPA-PSK [TKIP], WPA2-PSK [AES], WPA-PSK [TKIP] + WPA2-PSK [AES]).
WPA-PSK should be enough to secure your Wireless network.
ASCII - Choose from any key available on the keyboardHexadecimal - Characters ( 0~9 and A~F)
  • Before setting up wireless security on the router, make sure the computer you are going to use to setup wireless security is directly connected to the router using an Ethernet cable(wired).
  • To setup wireless security on the router, access the router user by typing http://www.routerlogin.net or 192.168.1.1 in the address field of your browser and then press Enter.
  • Enter admin for the router user name and your password (or the default, password).
  • Choose Wireless Settings from the Menu on the left.
  • Select WPA-PSK under Security Options. Input the Passphrase.
Passphrase can be 8~63 Hexadecimal characters or 8~63 ASCII characters.
Take note of the passphrase then click Apply.
Hope this helps. Have a nice day.
Nov 24, 2011 | NetGear Computers & Internet
Cant get the ps3 to connect to router with password that i set up...computer does just fine
change the wireless security settings options in router Security Options None
WEP WPA-PSK [TKIP] WPA2-PSK [AES] WPA-PSK [TKIP] + WPA2-PSK [AES]try this link it might help http://manuals.playstation.net/document/en/ps3/current/settings/connectwireless.html
Dec 29, 2010 | Computers & Internet
I cant connect my xbox360 or my printer to my cable router
Are you connecting the Xbox via wireless?
Try changing the router wireless authentication to WPA-PSK with TKIP encryption.
XBox and PSP have problems with WEP.
Regards Brian
Mar 20, 2009 | Computers & Internet
Internet connection of psp
To connect to the internet on your PSP, you need a Wireless Router or Wireless Access Point. Once you have a wireless one, you should know the name of your router. That's what an SSID (Service Set Identifier) is.
Once you know this information you should be able to find your router on your PSP. Once you do you should have a password on your router so no one you don't know can use your internet. When adding a connection on your PSP you will also need to enter the password for your router. You can use WEP, WPA-PSK (TKIP) or WPA-PSK (AES). WPA-PSK (TKIP) or WPA-PSK (AES) have very high security and WEP has a lower security.
Once you have added your connection, just type an address and surf! Not all websites will load because some require too much memory.
Assuming you have Official SONY PSP Firmware, Update to the latest version by going to Settings>Network Update. Locate your router and use it as the network connection.
Download the needed files and update by going to Game>Memory Stick>PSP Update.
Once you finish Update, go to Network>Internet Radio>About Internet radio. It will take you to a website to download the files needed and will install to your Memory Stick.
To put music on your Memory Stick, the Music must be MP3, AAC, M4A or WMA format.
Open your memory stick on your computer by pluggin in a USB cable to your PSP and going to Network>USB Connection or you can put the memory stick in a card reader.
Once in the root of your memory stick, there should be a folder called "Music". Put your music in there or in one more folder inside that. Two folders inside of each other will not be playable.
Place videos in the "Video" folder on the root of your memory stick.
Videos need to be MP4 format. 368X208 Highest MPEG4 Codec, or 480X272 x264 or AVC codec.
Need a converter?
http://www.formatoz.com/
Its a free and very good converter. Try it
Reply if you need anything else.
Oct 09, 2008 | Sony PlayStation Portable (PSP) Console
How can i put internet in my psp?
To connect to the internet;
  1. Check that you have your PSP® (PlayStation® Portable) system set up for Wireless (WLAN) networking in Infrastructure Mode.
  2. Make sure the WLAN switch on the left side of the PSP® is turned on so that the PSP® can connect to the internet.
  3. Make sure you are within range of a wireless access point (or hotspot) that allows connections to the internet.
  4. Select icn_www.gif (WWW) under icn_network.gif (Network) from the home menu and press icn_btnx_color.gif.
  5. Use the up and down buttons to select the address bar and press to display the on-screen keyboard.
  6. Use the on-screen keyboard to enter the address for the web page you want to display.
  7. When you have finished entering the address, highlight the Enter button and press icn_btnx_color.gif.
  8. Select a connection and press icn_btnx_color.gif.
  9. The web page will be displayed.
  10. To hide the on-screen menu, press icn_btntriangle_color.gif.
Setting up Infrastructure Mode;
Infrastructure Mode allows you to connect your PSP® (PlayStation® Portable) system to the internet through a wireless network (WLAN) access point.
Required items:
  • A PSP® with system software version 2.0 or later.
  • A wireless network(WLAN) access point with internet access, such as:
    • A Wi-Fi hotspot (such as those at cafés, hotels and airports).
    • A home wireless network, which might include:
      • A subscription to an Internet Service Provider (ISP)
      • A DSL or cable modem
      • A wireless broadband router
  • Settings used for the SSID, WEP/WPA-PSK encryption and WEP/WPA-PSK key, as specified when the wireless access point was configured.
To set up Infrastructure Mode on your PSP®:
  1. Make sure the WLAN switch on the left side of the PSP® is turned on so that the PSP® can connect to the internet.
  2. Highlight icn_settings.gif(Settings) from the home menu.
  3. Select icn_networksettings.gif(Network Settings) and press icn_btnx_color.gif.
  4. Select Infrastructure Mode and press icn_btnx_color.gif.
  5. Select New Connection and press icn_btnx_color.gif.
  6. Use the on-screen keyboard to enter a name for the connection, then press the right arrow button to continue.
  7. To set the Service Set Identifier (SSID) for the access point, select one of the following:
    • Scan: searches for and then displays a list of access points (or wireless networks) and displays the SSIDs.
    • Enter Manually: allows the user to enter the SSID using the keyboard. Select this option if you know the SSID of the access point.
  8. If you choose the Scan option in the previous step, select the access point to be used and press icn_btnx_color.gif.
  9. Confirm the SSID and press the right directional button.
  10. To enter security information for the access point, choose one of the following:
    • None: does not set security information.
    • Wired Equivalent Privacy (WEP), WPA-PSK (TKIP), WPA-PSK (AES): all set security information. Press the right arrow button to move to the screen for entering WEP or WPA (Wi-Fi Protected Access) keys. Note: The WEP and WPA key fields display eight asterisks no matter how many characters you enter as the key.
  11. After entering the security information, press the right arrow button to continue.
  12. To select the address setting method, choose one of the following:
    • Easy: the following information is automatically set
      • IP address settings: Automatic
      • DNS settings: Automatic
      • Proxy server: Do Not Use
      • Internet browser: Do Not Start
      Note: Most home networks will allow you to use the Easy address setting, which is recommended.
    • Custom: you can manually enter detailed setting information, such as when you are using a static IP network. For details, see the instructions supplied with the network device or the information provided by your ISP.
  13. After selecting the address setting method, press the right arrow button to continue.
  14. Check the settings, using the left arrow button to return to previous screens to make any necessary corrections.
  15. To save the new connection, press icn_btnx_color.gif.
  16. To test the connection, select Test Connection and press icn_btnx_color.gif.
  17. If the connection is successful, information about the network connection will appear. Press icn_btncircle_color.gif to end the connection test.
You can also check http://www.us.playstation.com/support/psp
for more information.
Jun 17, 2008 | Sony PlayStation Portable (PSP) Console
  6. Use the on-screen keyboard to enter a name for the connection, then press the right arrow button to continue. For more information, see Using the On-screen Keyboard.
Mar 25, 2008 | Sony PlayStation Portable (PSP) Console
Psp
You would need to configure your netgear router to accpect trasfers from a multimedia device like psp. and also psp can only support only WPA-PSK (TKIP) Encryption.
Please Follow the below steps to do the same.(please perform the steps in a already connected device like a laptop or a desktop using a Wi-Fi Card.
Step One: open the web browser in your computerthe laand type http://www.routerlogin.net/ or http://192.168.1.1/.
Step Five: it would ask you for username and password. enter Username : admin and Password : password .
Step Six : Confiuring the router.
1) please avoid setup wizard and confure it manually and follow the steps below.
2) you would need to click on left frame buttons for the confgration to come on the right side.
3) On the right menu now click on wireless settings in the setup section.
a) set security option as WPA-PSK the third option.
give a password like "abcde12345" should be 10 charactes and alpha-numerical. ( This option is to make your Wi-Fi more secure and to avoid unauthorized access. Key lifetime : 60minutes
then click Click "Apply"
5) Now on the right menu goto advanced tab and click on UPnP(Universal Plug and Play Devices)
a) Check on Turn UPnP On.
Then Click "Apply".
Router Config Done..Now on the right side click in "Logout" (bottom most option)
after the router logout is done close the web browser and remove the network cable and the the power cable from the router.
Post Configring Steps :
a) Swich off the dsl modem.
b) plug the dsl cable to the internet jack in the router.
c) plug in the router power cable back to switch on the router.
d) Switch on the DSL Modem.
Wait for 15 Seconds.
Connect to you wireless netowrk using you psp and provide the WPA-PSK - TKIP passord which you had given in router for preventing unauhorized access.
Bingo !! you are connected...and more secure.
Feb 25, 2008 | NetGear WGR614 Wireless Router
Sony PSP-3000 Silver Console Logo
168 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
