Question about Hyundai L90D+ 19" LCD Monitor
I have a Gateway LP2207 monitor. Last night it went blank. The monitor powers up. It has a touch menu along the side of the face and i can hear the sounds dinging when i touch them but no options appear on the screen. If i unplug the VGA cable and plug it back in i can see my desktop flash for about a second and i can see the VGA recognition box. But then it goes black again. Monitor does stay powered though. I dont have any other cables in the the house to check if the other ports work - but i did try another VGA cable with the same problem. Also if i turn the monitor on and off i do see the gateway splash. Forums seem to suggest that its the monitor power supply? but that doesnt make sense to me as it has power, just no picture.. Thanks in advance
  • 63 Answers
SOURCE: flashes on then goes black
The green light only lets you know there is a valid video signal reaching the monitor. If the green light was not "on" your problems would possibly be within the pc itself. Something is not holding the circuit for the backlight "on" thus going black. Suggestions are: 1. Take it to get it repaired (if not under warranty) Hyundai carries a 3 yr warranty on this monitor. Website provided. 2. Buy a new monitor
Posted on Aug 27, 2007
  • 87 Answers
SOURCE: Hyundai LCD monitor L70N Stuck in sleep mode?
push and hold the power button... then hit the settings button on the monitor and goto power>sleep mode
Posted on Jun 17, 2008
Scott Ellin
  • 558 Answers
SOURCE: monitor shows screen then goes black
It is the Monitor Cable connected to the CPU cabinet is faulty. Please check out the cable and its pin firmly.
Try to find the fault, may be the cable broken or tear up.
Let me know if further diagnose required.
Have a nice day.
Posted on Oct 14, 2008
  • 4 Answers
SOURCE: Gateway LP2207 Monitor comes on with Gateway icon but will not stay on.
Its most likely the light capacitor it can easily be fixed but if your going to buy one anyway dont go back to gateway they offer poor technical support
by light capacitor i mean the capacitor giving power to the light
Posted on May 22, 2009
Testimonial: "This was the problem, thanks for you help. "
  • 159 Answers
SOURCE: Gateway LP2207 Powers up to a bright white screen... nothing else
White screen is usually in the video input board. Once in a while it is in the lcd panel.
Does the power button turn on and off normally ? do you hear the gateway boot-up sound when it starts up ?
If you don’t have the startup sound when you plug it in, the main board may be bad.
If your picture was pinkish or dark at the top or bottom when it was working then you may have 1 or more of the bulbs failing.
If your picture wasn't pinkish or dark at the top or bottom when it was working, then it sounds like probably the inverter may have went. They are light light bulbs and have life expectancies on the capacitors.
To get to the inverter:
remove the stand
Take the 3 screws out of the bottom rear edge (these hold the front trim),and the 4 big black ones at the middle of the back
the the trim then unsnaps. {Be aware of the small ribbon to the power button board on the right edge} Start at the bottom and release the trim usually by gripping it on the lcd screen side with your fingertips and pulling outward, then work your way up each side from the back where the front trim meets the rear case. Work from the bottom to the top (a pocket knife or thin putty knife will help release the catches) You can also sharpen the edge of a credit card-(plastic is a little safer)
Then unsnap the top edge (rocking it while lifting helps)
Disconnect the ribbon, (Tiny latch lifts up on a hinge and ribbon slides out)
Once trim is off, remove the 4 corner screws that hold the screen in. Then the screen will lift out with all the guts. You may have to use a screwdriver like a crowbar in the corners to start the screen to lift up.
You’ll then have to remove a bunch of screws including the speaker ones and the usb board ones and unplug the bulbs and wire to the screen
then the inverter is under the center area under the metal cover
Shout if you need more info.
If you email me a good picture of the inverter , I may be able to get a better idea if it is the inverter from a visual.
Thanks Fran
Posted on Jan 15, 2010
How do i get the sound to turn off on the monitor when i turn it on?
Hello Janine
Of course, if your particular monitor provide sound, (integrated) or the monitor has speakers, you can.
but if in the HUD menu, or visually you wont see any speakers, I fear not.
Mar 25, 2016 | Gateway LP2207 LCD Monitor
Some monitors do not have speakers (my HP monitor does not). The sound has come out of some external speakers attached to the tower. Or maybe you need to access the monitors on-screen menu to turn the speakers on (if they have speakers). Or maybe you can access the monitor speaker control through the PCs Device Manager option (this is where all external components attache to the PC can be viewed, and sometimes changed).
Aug 13, 2014 | Gateway LP2207 LCD Monitor
Gateway LP2207 64 bit drivers
If you can't find the drivers anywhere else, do this: There is a UL Code listing on the back on the monitor's electrical ID tag on the back label. It has a number on it: UL (number). Go to the UL site and look up the number, it will tell you who actually made the monitor for Gateway. (Gateway doesn't
make monitors, it rebrands them.) Go to the mfr's site and download drivers for the monitor of the same size as yours using the 64 bit drivers. It will take a bit of slouthing, but can't be done successfully. (Ex. Sampo is actually Hitachi.)
Jun 30, 2014 | Gateway LP2207 LCD Monitor
You didn't mention what operating system you have.
You can check out the drivers here for the LP2207:
Additionally, you can get a lp2201 manual here:
Jun 30, 2014 | Gateway FPD2275W LCD Monitor
Gateway monitor problem
Does this monitor has a reset to factory specs on the menu? If so then select it.
Jan 05, 2009 | Gateway FPD1760 17" LCD Monitor
I have a Gateway LP2207 Monitor that will not turn on. It shows a picture for about a second and goes off. Any assistance would be greatly appreciated.
3 electrolic capcitors on power supply board go bad, disasemble carefully split case,start from bottom take care with ribbon cable to face, flip up ribbon brown holder on face slide out cable, remove sheild for supply take screws off of supply board,turn over and 2 caps next to each other are 680uf by 25v replace with 680uf by 50v , close by is a 1000uf by 25v replace with 1000uf by 35v or 50v. reassemble but be carefull not to pinch ribbon cable to face buttons after sliding back in socket and flip catch down on cable,remember!!! don't pinch cable when snaping case together.
From Keith the ham radio operator former TV and radio repairman.
Dec 07, 2008 | Computers & Internet
Problem with FPD1760 Gateway monitor
sounds like the LCD inverter gone bad.
you might get lucky in finding one on EBAY.
yeah gateway sucks on customer service.
Jun 18, 2008 | Gateway FPD1760 17" LCD Monitor
Side Buttons - Not Responding (wrong input?)
These buttons can stick, when you press the buttons do they click
if not then it is stuck in.
Jan 27, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Open Questions:
Hyundai L90D+ 19" LCD Monitor Logo
422 people viewed this question
Top Hyundai Computers & Internet Experts
 Zackery G
Zackery G
Level 1 Expert
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
