SOURCE: mtd yardman riding lawn mower will barely move or
rock it back and forth, and pull the shifter to neutraLwith out mtor running.
SOURCE: MANUAL FOR A TROY BUILT RIDING LAWN MOWER
Try this site it is called manuals online . Should find what your looking for , Free.
SOURCE: mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
SOURCE: I need a diagram showing how to put the drive belt
I'm having trouble with the number you provided. Please revisit your mower and obtain the model number and serial number, then click on this link:
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10301&LeftNav=true&langId=-1#
Type in your info to obtain your users manual for your mower. It should contain the belt routing diagram you're looking for.
Hope this helps... Good luck!
SOURCE: My mtd riding lawn mower won't go into gear...
Yes , this is what I had- the vari- pully was stuck and wouldn't move up or down and keep pressure on the belt. once I sprayed it with wd40 it started moving up and down ok- and would shift ok-
