Question about GPX HM3817DT Shelf System
The sound only comes out of the right speaker. Is there a way to adjust the balance of the speakers, or is it just a bad wire?
    Problem Solver:
  • 14 Answers
I don't believe there is. I think it's hard wired to be balanced in the middle. BUT, I saw a display model at the store that had the same problem.
Let's try the simple ideas first. Turn the unit around and twist and push the plug up in place to make sure it's firmly connected. Might even try unplugging it, then plugging it back in again.
If that doesn't fix it, try running your fingertips slowly over the cord (lightly grasping the cord between thumb and forefinger) and see if there are any damaged places on the cord. This could be caused by shipping damage or manufacturing damage, or even your furry kids. *giggle*
If those ideas don't produce any results, then there's most likely a broken wire in the cord that leads from the speaker to the unit. Try carefully bending the cord back and forth in U shapes and see if the sound appears then disappears. If so, then you have a broken wire. Of course even if the sound doesn't go in and out, that doesn't mean you DON'T have a broken wire... it just might be at one end or other of the cord making it harder to isolate.
If you have a broken wire, you can take it to a local electronics shop and they should be able to fix it easily and, hopefully, fairly cheaply.
Hope that helps. =)
Posted on Sep 22, 2009
No Sound in Right Front Speaker- Denon AVR-1508
hi there,
have you check the system settings for each of the speaker..? should be set and balance all output of the speaker
`jack
May 24, 2008 | Audio Players & Recorders
Pioneer DEH-P47DH Front left speaker not working, if i press audio button, i get no option to adjust balance, just fader. left rear speaker works and plays as loudly as right rear speaker. Huh? bad...
Are you sure you wired up the head unit correctly? It is fairly uncommon for a audio output amplifier to blow out leaving 3 working speakers and 1 not working. So more than likely it is bad wiring or a blown speaker. Best bet would be get a digital multimeter and ohm out the speaker and see if it has continuity and is the same as the adjacent speaker. You could also try swapping the left/right channel wiring and see if the front right speaker stops working when connected to the left speaker output or vice versa.
Nov 12, 2013 | Car Audio & Video
Very little sound coming from the speakers
follow this steps and fix it. God bless you
One of the speaker inputs is not connected. Connect the speaker wiring securely. The BALANCE setting is all the way in one direction. Adjust the BALANCE control. Unit is in MONO mode. Turn off MONO mode.
Oct 11, 2013 | Kenwood Audio Players & Recorders
The sound only comes from the right side on my acer tablet
See if there's a balance control. If the slider is all the way to the right, that could explain the problem. Otherwise, since this happens with two sets of speakers, the problem is either a bad receptacle, or sound card, or, the connection between them.
I found this Windows 7 site on how to adjust the balance.. it seems to be legit: no complaints from Avast! A/V
http://www.windows7hacker.com/index.php/2010/02/how-to-adjust-audio-balance-in-windows-7/
Aug 05, 2012 | Acer Iconia Tab A50010S32u Notebook
2007 Chevrolet Impala LT front speakers not working
Hello! Whether your vehicle is premium or standard the wiring is almost the same...Both have a Left front Speaker and a Left Front Tweeter...You did not specify which speaker (Left Front ) wasn't working; However it really doesn't matter...Either the speaker is blown or the wiring has a poor connection or is broken (open)...Here are the wire colors...LF Door=Tan (+) and Gray (-)...
LF Tweeter=Tan (+) and Yellow (-)...The Yellow and Gray are tied together...Pop the speakers out using a thin blade screwdriver with the end taped...Visually inspect...If you have an ohm meter read across each speaker if good=2-8 ohms...If bad =open or 0 ohms...Guru...Saailer
Oct 25, 2011 | 2007 Chevrolet Impala LS Sedan New Cars
1998 bravada has six radio speakers; two dash speakers and two in the front doors speakers plus two rear doors speakers. the front doors speakers work good but no sound come from the dash speakers or the...
Did it fail while you had vehicle, or like this when you bought it? Could be bad radio or wiring harness was chopped up when previous owners had an aftermarket radio installed. They probably just slapped the OEM radio back in when selling car. And didn't put all the OEM wiring back in.
Nov 07, 2009 | 1998 Oldsmobile Bravada
MY JBL Platinum Series speakers work on one side
the first thing to establish whether its the speakers would be to try them on a different computer. If there is some sound, that means its getting some feedback. Maybe you could go to sound manager in your control panel, or on the volume menu that you can access by clicking the volume icon on your desktop taskbar, you know, by the time and stuff. Once there, adjust the balance by moving the slider all the way to either side to see if its unbalanced. You might also wanna adjust the sound scheme from mono to stereo or dolby digital which would be in the same menu/ window. Does the right speaker thats plugged into the tower have a balance (R)ight and (L)eft? you might also want to adjust that to either side. If that is not helping, maybe there is a hardware issue with the left speaker, maybe a short, or a problem with the wire and you might have to replace that speaker if you do not know how to fix speakers. Tell me how everything works out.
May 25, 2009 | HP JBL Platinum Computer Speakers
My l/r channel will not work
With the radio on u will need to push audio button it will change to something different on the face push until speaker balance comes up & then push butons below it left or right to balance each side of speakers. For me it was the left speakers that i needed to balance good luck John
Jun 06, 2008 | Pioneer DEH-1600 CD Player
GPX HM3817DT Shelf System Logo
89 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
