Question about Toshiba Satellite A10-S100 Notebook
Lid will not stay open by itself can i tighten it up myself?
  • 104 Answers
No have
Posted on Aug 01, 2009
I replaced the lid switch on my whirlpool washer. It worked perfectly for10 loads and now doesn't. To finish the load in progress when it broke again, I pushed a screw driver into lid switch and pressed...
The post attached to the lid that actuates the switch might be missing or the switch itself might have slipped out of alignment. Make sure the switch is positioned properly so the post actuates it and tightened sufficiently to stay properly aligned.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Nov 01, 2014 | Washing Machines
Loose hinge/lid on Dell latitude D410 laptop-lid does not stay upright and falls back flat and no screws to tighten...How can you fix this? Thanks
I took the hinge cover off to look for myself to see if there were in fact some set screws to tighten the monitor up. None were found, no suprise there. While on ebay ordering a new hinge set I noticed that the picture of the new hinges didn;t look the same as what I observed on the laptop. The pin on the right was sticking out on my lapto but in the picture on ebay it was flush.
I used a flat ended phillips tip screwdriver and pushed the pin back in while gently rocking the monitor back and forth. That seemed to solve the problem.
Jan 22, 2010 | Dell Latitude D410 Notebook
Tightening HP Pavilion DV9000 17'' LCD Hinges
you may find the hinges parts from eBay which is cheaper price:
http://shop.ebay.ca/?_from=R40&_trksid=m38&_nkw=HP+Pavilion+DV9000+hinges&_sacat=See-All-Categories
how to replace your laptop hinges:
1) take out the screws at back of laptop under the hinges base
2) or take out the screw at side of laptop near the hinges base (if you find any screw there)
3) there are two cables connect between LCD lid and laptop base
you do not need disconnect those canbles. just careful them
4) take out all scews on the front of lid cover( the scews is covered by thin plastic cover), then take away front lid cover.
5) take out the screws at beside hinge base and side of LCD panel(2-4 scews at one side), you need check the back of lid cover can separate to LCD panel a little., be care replace only one at one time .
6) put back all screws step by step.
hope help you fix it, please take a rating let me know how much you are helped, thanks! any question please let me know!
May 18, 2009 | HP Pavilion dv6000z Notebook
Lid problem
A common easy fix for this problem is making sure the screws on the hinges (right and left side of the lid) are tight. Loose screws will cause it not to properly srike the lid switch and the unit wont run since it thinks the lid is open. If they are tight, you will probably need to replace the lid switch itself.
Jun 30, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Locked keys in trunk
I believe you can remove the back seat and get into it. Remove the lower part of the back seat first and remove attaching bolts/screws to remove the upper part of the seat.
Jun 20, 2008 | 2008 Nissan Sentra
Open Questions:
Toshiba Satellite A10-S100 Notebook Logo
60 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
