Question about Maytag Neptune MDE5500AY Electric Dryer
One of the dryer "blades" on the inside fell off
One of the dryer "blades", (I don't know what they're actually called), came unscrewed and fell off. How do I get in to repair it?
  • 67 Answers
You just need to remove the front panel and then take out the drum. While the drum is out check the rollers and replace the skid pads.
Posted on Aug 15, 2009
The POWER button fell inside and it won't turn the dryer on. How do we fix it on our own?
take the panel off and place back in from inside the panel should be able to remove the back perhaps
Jul 31, 2014 | GE Dryers
Maytag dryer blade inside of the drum
Is blade loose or broken off? Either way, you must remove front panel (door panel) to expose the front drum end retainer brackets, which you must unscrew and remove to get at screws to tighten or replace missing paddle blade. You can get replacement part at www.repairclinic.com their very reasonable
Feb 13, 2011 | Maytag PYE2300AY Electric Dryer
The plastic piece inside the dryer (about 18"
If you are referring to the "fins", there are 3 of them that tumble the clothes, you can refer to some previous questions. You will need to remove the top first and then tighten them up. I have to replace one of my "fins" because it broke off inside of the dryer.
Jan 07, 2011 | Maytag Neptune MDE5500AY Electric Dryer
The "blades" inside the drum
yes they can you would end up removing the top panel or actually as they term it kicking it up and around the drum are screws that hold in the blades unscrew each of these and take out the change and the balls of lint as well then reattach if you have any if you need a diagram of your machine message me back and please remember to rank how this opinion has helped in your appliance situation we try to obtain 4 thumbs up on all our posts Thanks again Rick
p.s if you need a schematic of your dryer and how it comes apart send me the model number of your machine and tomorrow after 6 am eastern time i can send it to you sorry the site is down for maintenance this evening
Jan 02, 2011 | Dryers
I unscrewed Stanley 10-379 Interlock retractable knife and now I don't know how to put back the gizmo that fell out or the three blades that came with it.
Google: how to change blade in Stanley 10-379 utility knife. Stanley website shows how knife & blade look on the outside. Put it together so it looks like that. Sorry, but ain't don't know how to send the picture to you.
Oct 21, 2010 | Garden
The window fell inside door. i would like to know how to take inside door panel off
Hello. Unscrew any screws you see around the door handle and then using a stiff blade putty knife work your way around the perimeter of the panel where you will be prying clips up. If you break a clip don't worry because these are common, inexpensive items at any auto parts store. Joe
Please rate this answer 4 thumbs up. Thanks.
Oct 01, 2010 | 2001 Cadillac DeVille
Dryer fan blade fell off
Secure the blade using some Loctite.
Check the others also.
Jan 17, 2010 | Dryers
One of the 3 tumblers inside the dryer fell off.
you actually open the top first if you look between the front and the top you will see two clips. push these in with a small screwdriver to lift the top. then there is two screws holding on the front to get it off.
May 21, 2009 | Dryers
My filter queen fell apart!!
http://geeksquad.fixya.com/ThreadView.aspx?prdid=20821&thid=780805
Posted by julieartlit on Jul 14, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Not knowing what actually fell apart is to contact your local vacuum cleaner dealer in your area or to call the Filter Queen factory cust serv or tech serv @ the phone # listed below, you can also request a new owner’s manual so that you might see what actual fell apart and you might be able to fix it yourself. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.filterqueen.com/
Customer Service 1-800-344-1840
custserv@filterqueen.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 14, 2008 | Filter Queen Majestic Canister Vacuum
Kenmore gas dryer model 11070812990
Take a flat-blade screw driver and stick it in the seam between the top cover and front panel at one corner and pry up. The top panel will pop up from the catch - then do the same for the other front corner.
You can then tilt the top up towards the back of the dryer because there are hinges in the back. Spin the drum to where the holes for the baffle are and screw the baffle back on. If you are missing the screws, they probably fell to the bottom inside.
You can take off the front by unscrewing the two screws that hold the top of the front panel to the outside panels. Once those are off, just lift the front panel straight up and pull away. There are two holders towards the bottom that the front panel slides into.
Once the front is off you should be able to find the screws below.
Good luck. . .
Mar 24, 2008 | Kenmore 74602 Gas Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
115 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
