Question about Recoton Advent Advent HT3251A TV
No input picture, just a blue screen
I took it apart, don't try with no training, CRT's hold about 30000 volts! I have a bad input board. I am trying to find one.
  • 616 Answers
Its usually a good idea when asking for parts, to include a model #. Thanks Julio
Posted on Aug 02, 2009
The projector is stuck on the blue screen. It will let me change the input but it will still stay on the blue screen even though everything else is on and working.
Hello!
"blue screen" means: picture is all blue, but there is a signal coming through? Do you see channel logo? Menu? If so, blue CRT or CRT board is at fault. Depends on the age of the set. If set is fairly new, then try to bang on the neck of blue tube with rubber screwdriver hands. Very gentle! While set is working. If you see the retrace lines and TV shuts down then, CRT is at fault. If not, try to play with blue "screen" control of "focus block". Black plastic module with bunch of thick wires attachad to that. Has 3 "focus" and 3 "screen" controls. For each of the tubes. In many cases you'll be able to adjust "blue" down to normal. Usually, those controls are smeared with white paint and hard to turn by hand. Loosen those with little pliers, then adjust manually or via small "phillips" screwdriver. If nothing helps: CRT board is at fault and must be replaced or repaired. In this case you won't see any characters on blue CRT, just solid "blue".
good luck,
Alex.
Jan 20, 2012 | Sony Televison & Video
Vertical Lines on my Mitsubishi WS-65819
This sounds like a bad connection or a bad capacitor in the 220 volt source that supplies the voltage for the CRT boards. You will need to get a schematic and trace out this voltage from the PM board to the CRT driver boards when the set acts up. it could even be a connection on one of the plugs from the PM board to the CRT boards. Sorry but not a real easy repair. Might take some time to trace unless a component is failing. Good Luck
Jun 29, 2007 | Mitsubishi WS-65819 TV
I purchased my Sony KV-35S66 in Dec. 1999. The screen is black when I turn it on. Sometimes, it will show the picture for about 45 seconds, then it disappears. The audio is fine. Have the picture tubes...
No,this tv is fixable.The video board,that the board,that connected to the CRT (Tv Tube),those round pins holes that connected CRT sockets that hold the CRT(Tv Tube) and the video board together.Resolders those CRT pins sockets that connected on to the video board.Will solved the cold solders connections between the CRT pins sockets and the video board this problems,will be solved.Tries take it to a tv shop,ask them take the tv aparts,resolder the video board CRT pins hole sockets on the video board for you.The priced my guest about $35-40.They must,take tv cover out and resolder the vdieo board CRT pins holes sockets.The whole job,take about 20-30 mins.
Oct 28, 2010 | Sony KV-35S66 35" TV
Blue light goes to Orange blinking no sound no picture Screen on
Hi!
Okay, if the screen is white! First, take apart and check the ribbon like cable that goes from your signal board (where you inputs are plugged in) to the lcd controller (under a small metal plate feed the lcd screen), see if loose and or reset! Secondly you either have a bad signal board or lcd controller!
Feb 28, 2009 | Westinghouse LTV-30W2 Television
Where is the deflection board
Was there a change in symptom from original?? Then recheck
your soldering with meter....short circuit???? Let me know...T.
Nov 16, 2007 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP74
havent had time to check these things out but here is some raw research I have done
No. The CRT driver ICs are prone to shorting and cause this symptom (I just had one with those very symptoms and the green CRT driver IC was shorted). Disconnecting the CRT board does not clear the short on the board. Often then is a small burn mark on the CRT board under the affected IC (but not always). The IC should be a TDA6111Q. Be sure to note the proper position
of the IC as it should face with the letters TOWARD the heat sink!!!!
Larry, Check the CRT driver ICs on each of the CRT boards.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
geminitv@xxxxxxxxxxx
Hi Guys, I don`t see many JVC`s and don`t have the print for this AV48WP30, went out this morning and as customer claimed on phone when you plug set in and turn on it makes a loud thump thump in both speakers 20-30 times then relay clicks, the thump stops, and blue idiot light on front goes dim/bright, dim/bright, have to unplug set to start this same scenario over again. Never develops HV or audio, Will order the service manual today, but would like to know if anyone has seen this before (should say "heard" this before)
I would disconnect each crt board and hv lead one at a time and try. Have seen several bad tubes on that model. The only other problem I have seen on that set is bad convergence amps, however that doesn't cause shutdown.
Perry Bower
Electric Medic
From Tech Repair CD:
JVC\AV48WP74\just went click*click*click when turned on Video drive IC (IC1101) on the red CRT module
shorted. It looked like bad solder on the B+ was the cause
Frequently Used Top Five Repair Parts by symptom code
MODEL NUMBER : AV48WP30 - TV
SYMPTOM CODE : DEAD
TOP FIVE PARTS :
2SC5552-RL
2SC5904-RL
QQH0113-002
STR-F6629B/F7
STK392-110
Above from JVC Web site, also I have seen shorted video drive IC's on the crt boards short and cause this symptom. Try unplugging the 200 volt source to the crt boards and see it the set powers up and stays on. There is a B+ relay which supplies 130 Volts to the horizontal output circuit. Is this relay energizing? I takes about five seconds after the power is turned on for it to energize. If a short is detected on the 130 volt line the blue power lamp on the front will do what you describe and the relay will pulse on and off. (David)
Symptom:
Non-functional Digital Input
Solution:
1. Power off the unit
2. Disconnect the digital input if it is connected
3. Remove the rear cover
4. On the digital input module, using a shorting pin (PC type) or a
jumper, short Pin 1 and Pin 2 of the
SB connector
5. Power on the unit
6. Unplug the unit and remove the shorting pin or the jumper
7. Re-attach the unit’s rear cover
8. Power on the unit, and input the digital source
Oct 10, 2007 | JVC AV-48WP74 48" Rear Projection...
Blue Screen
Your blue crt has a short - you can verify this by unplugging the socket from the blue crt and powering up the set and you should see a yellowish looking picture with just the red and green crt's operating. You can try turning down the screen control pot (B) for blue with the blue crt on (just to the point where you no longer see retrace lines in the picture on a blank input)Sony has had a lot of problems with the crt's on these models and sooner or later all the crt's will fail - For a permanent repair all must be changed.
Aug 20, 2007 | Sony KP-46WT500 46" Rear Projection...
Popping noises and no picture or sound
try replacing the stk's on the deflection board (making sure that all of the resistors on the board are OK and that there are no solder cracks I found one of the jumpers had a bad solder joint on the one I worked on) but if that doesn't fix I have some raw research that might give you somewhere to start :
(508)695-7302
(508)695-7769 FAX
Perry Bower
Electric Medic
SYMPTOM CODE : DEAD
TOP FIVE PARTS :
2SC5552-RL
2SC5904-RL
QQH0113-002
STR-F6629B/F7
STK392-110
Symptom:
Solution:
SB connector
Jan 16, 2007 | JVC AV-48WP74 48" Rear Projection...
Bad color .
Turn the set on without an antenna, so there is only snow on the screen. Measure the 3 cathode voltages at the CRT, red green and blue. If the 3 voltages are about the same, around 175 volts, then the CRT is bad (purple picture means bad green gun). If the red and blue are around 175 and the green is over 200 volts, then there is a chassis problem, usually the video output transistor itself has gone bad or come loose.
Oct 24, 2006 | Zenith A25A23W 25" TV
Stationary horizontal lines
Thjeres a problem with the screen voltage driver voltage capacitor or the crt is going bad. have the shop test the b+ on the crt board first off . then remove the crt board and see if the voltage comes up. If it does the capaicitor is bad as it can take the load. But remeber theres extremly hi Voltage inside these sets so its never a good idea to try to do this your self unless you have the training to deal with HI Voltage and the proper saftey and test equipment. Good Luck
Jun 21, 2006 | RCA F25655BC 25" TV
Televison & Video Logo
90 people viewed this question
Top Recoton Advent Televison & Video Experts
Rommel Balcita
Jaime Hernandez
oodio
oodio
Level 1 Expert
Are you a Recoton Advent Televison and Video Expert? Answer questions, earn points and help others
