Question about Milwaukee Drills
The chuck is stuck how do you fix it - Milwaukee Drills
  • 98 Answers
Pull the release back and use some pliars to pull it out, you may have to tap the bit first. All the torque from those bad boys sometimes makes the bits very had to get out.
Posted on Aug 04, 2009
  • Shawn S Aug 04, 2009
    Ime sorry, i guess i should have asked what part is exactly stuck, your bit is stuck or the release wont open to get your bit out.
Ryobi 18v drill stuck chuck
easy to fix
with the drill not running
grab the bottom part of the spinning part of the drill nearest the drill's motor.
then
grab the spinning shaft bit nearest the drill bit
pull them apart slightly
when the two parts are pushed together thay lock the chuck
I own a ryobi hammer drill that does the same thing
Mar 13, 2015 | Ryobi 18v Cordless Drill - P206 18 Volt V
Ryobi 18v drill keyless chuck stuck
Try holding the bit in a vice and gently tap the chuck off of the bit and see it it releases the pressure on the jaws.
Jun 20, 2012 | Ryobi 18v Cordless Drill - P206 18 Volt V
I have a drill bit stuck in my drill and I can not get it out of the chuck How can it be released from the chuck that I can change to an other drill bit.
By stuck do you mean that you can not release the chuck? if so then you can use 2 channel lock pliers to grip the chuck and the base to break it free. i have done the same on a keyed chuck and a keyless chuck .
Oct 03, 2010 | Garden
A bit is stuck in the chuck of my Bosch drill
Hello. Wrap a towel around the chuck and use a pipe wrench or a pair of channel locks to put a little force on the chuck. J.
Jul 19, 2010 | Bosch Drills
Jammed chuck
Use a pipe wrench to turn the chuck open. J.
May 31, 2010 | Dewalt 18 Volt Compact Drill Kit
Bit is stuck / jammed. Can't seem to loosen. Any ideas on how to fix?
If the chuck is too tight to get the bit out you can either put a glove on one hand grab the chuck and run the drill in the reverse direction or if that will not work use vise grips or a small pipe wrench on the chuck to loosen it but be sure to tape the pipe wrench or vise grips with a thin piece of duct tape so you don't gouge the drill chuck.
May 23, 2010 | Black & Decker BD12PSK 12-Volt Smart...
Bosch keyless chuck stuck
Make sure you try it in both directions.
Apr 18, 2010 | Black & Decker 3/8" Variable Speed...
Bit is stuck. chuck wont open. turns but makes a
the chuck is broken inside if clicking. Ace and True Value stores sell chuck replacements
Mar 04, 2010 | Black & Decker BD12PSK 12-Volt Smart...
Cordless Drill, Keyless Chuck stuck in full open position.
if chuck is wide open ,look down inside there should be an allen screw or bolt at the bottom of the chuck it should undo anti clocwise and the chuck comes off
Aug 18, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Stuck chuck
open the chuck all the way, insde there may be a screw in the bottom it's lefthand thread turn it clockwise to remove, the chuck is also threaded, right hand thread. close the jaws on the short end of an allen wrench and strike the long end with a hammer to break it free
Apr 01, 2009 | Makita Usa Inc No.8390DWPE 18V Crdls...
Drills Logo
527 people viewed this question
Top Milwaukee Drills Experts
Jim Thurston
Mike
Are you a Milwaukee Drill Expert? Answer questions, earn points and help others
