Question about Toshiba Satellite A10-S100 Notebook
Lid is falling shut.
Our lid keeps falling shut. I think some screws are loose, but when we tightened them, they wouldn't stay tight for very long. The lid only stays in one position, and it is hard to see it in that position. Please help!
5 Suggested Answers
  • 32 Answers
SOURCE: problem with cover lid on my laptop
Obviously a hardware issue, go to a service center.
Posted on Oct 15, 2007
gpetti2009
  • 92 Answers
SOURCE: how do I tighten a loose lid on a laptop computer?
it depends on the model and where the screw are
Posted on Mar 26, 2009
  • 104 Answers
SOURCE: lid will not stay open by itself can i tighten it
no have
Posted on Aug 01, 2009
  • 21 Answers
SOURCE: Lid/Top Loose
I have a Tecra M2 S630 and was able to fix my left hinge by removing it and drilling out the rivet and replacing it with a 6-32x1/4 inch machine screw and a nut. Total cost was $4 for a package of nuts and screws from Radio Shack.
Posted on Dec 17, 2009
Tip
How to service a lid switch
The lid switch on a washer often serves as a safety switch. If the switch is not working, or if the switch opening in the lid is clogged with detergent, the machine will not run. To check and repair the lid switch:
- Unplug the machine. Clean out the lid switch port with a wood manicure stick or chopstick. Clean off any detergent buildup around the rim of the lid. Sometimes there's enough detergent encrusted on the metal to prevent the lid from closing tightly and keep the washer from operating.
- If cleaning doesn't help, remove the top of the cabinet to get at the switch. With the switch exposed, check the screws for looseness. Loose screws can cause the switch to move when the lid is closed or as the machine goes through its cycles. Check the terminals of the switch to make sure they're tight. Tighten the mounting screws after the switch is in alignment. -Test the switch with a VOM set to the RX1 scale. Disconnect the power leads to the switch terminals and clip one probe of the VOM to each terminal. Close the lid of the washer. If the meter reads zero, the switch is working. If not, the switch is faulty and should be replaced. - If necessary, replace the lid switch with a new one of the same type. Connect the new switch in exactly the same way the old one was connected.
- If the switch still doesn't work, it is probably misaligned. Realign the switch by repositioning the screws holding it in place, testing the switch as you go until it works properly.
on Jan 16, 2010 | Washing Machines
One of the baffle fins are loose inside my Kenmore HE2 dryer. How can I tighten?
you can lid or remove the lid to gain access to the screws on the drum vanes.turn the drum by hand to get all the screws tight
Apr 21, 2010 | Kenmore Dryers
Loose Monitor on a HP Pavilion ZV6233nr Laptop
It seems that some screw that was loose is now totally out of socket. The latch assembly might be disbalanced due to that. To me it doesn't seem to be a broken latch.
Apr 04, 2010 | HP Pavilion zv6233NR Notebook
Sony VGN AR630
If the lid has a small slack and then is firmer again when the lid/screen is in another position, then the hinge mounting screws is most likely loose and the mounting screws needs to be tighten.
If the hinges are loose no matter what the position of the lid/screen is in then, they need to be replaced, there is no adjustment to tighten the hinges.
Jul 23, 2009 | Sony VAIO VGN-AR630E Notebook
Power comes on but nothing happens
hi
Step 1: Unplug the machine. Clean out the lid switch port with a wood manicure stick or chopstick. Clean off any detergent buildup around the rim of the lid. Sometimes there's enough detergent encrusted on the metal to prevent the lid from closing tightly and keep the washer from operating.
Step 2: If cleaning doesn't help, remove the top of the cabinet to get at the switch. With the switch exposed, check the screws for looseness. Loose screws can cause the switch to move when the lid is closed or as the machine goes through its cycles. Check the terminals of the switch to make sure they're tight. Tighten the mounting screws after the switch is in alignment.
Step 3: Test the switch with a VOM set to the RX1 scale; procedures for using the VOM are detailed
here. Disconnect the power leads to the switch terminals and clip one probe of the VOM to each terminal. Close the lid of the washer. If the meter reads zero, the switch is working. If not, the switch is faulty and should be replaced.
Step 4: If necessary, replace the lid switch with a new one of the same type. Connect the new switch in exactly the same way the old one was connected.
Step 5: If the switch still doesn't work, it is probably misaligned. Realign the switch by repositioning the screws holding it in place, testing the switch as you go until it works properly.
Nov 21, 2008 | Washing Machines
Kenmore elite top loader electric washer
you have poor contact with the left lid hinge and the lid switch.1st open the lid and check the 2 phillips head screws on the left side of the hinge.if they are loose tighten them and try mach.if the screws are tight,the lid switch might need to be replaced or adjusted.there will be 1 screw in each corner of the back of the console facing down.remove and flip console up,if there are no screws,take a putty knife and slide under front left and right corner of console and flip console up.the lid switch will be on left.if it is not broken out of socket,adjust hinge bar underneath switch by removing switch and bending silver bar up SLIGHTLY
Sep 27, 2008 | Kenmore 24032\24036 Top Load Washer
Lid problem
A common easy fix for this problem is making sure the screws on the hinges (right and left side of the lid) are tight. Loose screws will cause it not to properly srike the lid switch and the unit wont run since it thinks the lid is open. If they are tight, you will probably need to replace the lid switch itself.
Jun 30, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Washer will not agitate. After starting the washer the water will begin to fill but when it's time for the agitator to begin it shuts the whole machine off.
If the lid lifts up from the front, tighten the hinge screws on both sides of the lid. If the screws are tight open and close the lid..listen for a click.. no click..lid switch is bad.
Jun 12, 2008 | Kenmore Washing Machines
Battery compartment
same problem , no solution, i e-mailed like 10 times to buy ine cover lid, i think they re out of business
Nov 11, 2007 | Cameras
Open Questions:
Toshiba Satellite A10-S100 Notebook Logo
132 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
