Question about Asrock K7VT6 (K7VT6 RAID) Motherboard
Trying to create a server using the ASRock k7vt6 mobo
Hi, I'm trying to create a server using the ASRock k7vt6 motherboard, but I do not want to use the hardware RAID. However, that is a bit of a problem since the BIOS with only recognize and boot from my hard disk if the RAID is turned on. I no longer have the support CD, how can I configure the RAID/mobo to work with me?
Turns out the RAID enable in the bios is also used to enable the SATA. but this doesn't mean you have to use RAID to use SATA drives! there's a separate bios to configure the RAID that you can access after the initial boot screen by pressing tab. here, you can delete an existing array or create a new one. deleting the array makes the motherboard see both drives separately, like I wanted. problem solved :)
Posted on Aug 03, 2009
Hi having trouble with a sata 2 drive in my k7vt6, i followed all the instructions to the letter created my raid driver utility floppy disk by useing the mobo driver disk to get the drivers, i stick my...
Hi!
According to your mob specs ( 2 x ATA 133/100/66 IDE connectors ( supports 4 x IDE devices)), it does not support Sata2; however, if you configured your HD to Sata1, then check your FSB and set it to 400MHZ.
Jumper Setting 400:FSB_SEL1 : 1_2 FSB_SEL2 : 2_3
I hope this helps; nontheless, I also hope you can exchange the HD to a regular Sata.
Aug 31, 2011 | Asrock K7VT6 (K7VT6 RAID) Motherboard
Got an AsRock P4i65G mobo and bought 2 gig RAM for it. However, I have bought ECC memory by mistake instead of Non-ECC. PC wont boot with the new RAM. Is there any way I can get this to work such as with...
Hi, you can download a manual here:
http://www.asrock.com/mb/overview.asp?model=p4i65g
Your mainboard DOES NOT SUPPORT ECC RAM.
This ram type is ONLY intended for servers
or mainboards that are compatible for that ram type.
This is what your mainboard supports:
Dual Channel DDR memory technology
- 2 x DDR DIMM slots
- Supports DDR400/333/266 non-ECC, un-buffered memory
- Max. capacity of system memory: 2GB
Use only the asrock site when upgrading the bios.
And a bios upgrade does not supports the ecc ram anyway.
Hope this will help you.
Aug 20, 2011 | Asrock P4i65G Motherboard
Mobo power
There are jumpers on the motherboard,
check all jumpers are set correctly, as from the user manual, this could be a problem.
check all your front lights are wired properly
power button, reset switch, must be correct too.
double/treble check them before building it.
Richard.
Apr 20, 2009 | Asrock 845GV (P4I45GV) Motherboard
Graffics accelerator failure
Hi Carpeteddy,
The ASRock K7VT6 motherboard does not have a intergrated graphics card onboard. So your 1.5V, AGP8X / 4X card needs replaced. It wouldn't hurt to uninstall the AGP's driver software, reboot the system & re-install the software. Check the manufactures web site for updated driver software before replacing it.
Link to ASRock K7VT6 MB: http://www.asrock.com/mb/overview.asp?Model=K7VT6
Here is a link to an XFX 1.5v AGP card:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2412161&csid=ITD&body=WARRANTY#tabs
The good part of XFX is its warranted for life!
Good luck Carpeteddy!
Questions?
Mike
Sep 29, 2008 | Asrock K7VT6 (K7VT6 RAID) Motherboard
MoBo turns off after booting
hey, this victor from kenya. Have you confirmed that the heatsink n coler fan is firmly attached to the motherboard? suc error is usually as aresult of non efficient cooing systems.
Also reapply the cooling compound. Use methylated spirit to clear tha old application on the surface of your processor.
If this 2 fail,confirm that you are using a compartible processor to the asrock motherboard.
Jun 27, 2008 | Asrock 845GV (P4I45GV) Motherboard
Upgrade cpu
According to the product website your board supports all intel socket 478 cpu's. Maybe you bought a faulty cpu ?
M266A
  1. Socket 478 for Intel® P4 processor
  2. VIA® P4M266A chipset
  • FSB 533MHz
  • Supports Hyper-Threading Technology
  • Hybrid Booster - a safe overclocking feature
  • 2xDDR 266/200
  • Integrated ProSavage8 3D Graphic
Socket 478, Intel® Pentium 4 / Celeron
- FSB 533/400MHz
Jun 22, 2008 | Asrock M266A Motherboard
Windows xp does not continue to start up
Hi if you hear knocking noise from the hard disk then it has conked off - as for the data there are service agents who claim to retrieve even from bad hard disks - search for them on the net .
May 28, 2008 | Asrock M266A Motherboard
Sound problem
Hi
U can download the drivers from www.asrock.com,
Here u select the global/english then u select the Download option search with ur mobo model no
Pl try it
Regards
Was this soultion useful?show ur appriciation by rating it
Apr 02, 2008 | Asrock P4I45GV...
Asrock K7VT6 (K7VT6 RAID) Motherboard Logo
152 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
