Question about Toshiba Satellite P105-S6227 Notebook
My Toshiba P105-S6227 will not come on. When I have gotten it on the monitor is shutting off but now I can't get it to come on.
  • 2 more comments
  • dceier Aug 01, 2009
    The DC and battery light are indicating that power supply is good. When I turn it on the power light goes on the HD light blinks the keyboard lights blink and the monitor get a light glow but doesn't come up even if I attach an external monitor. About 2 weeks ago I was able to get the system to come on with the monitor band about 20 min in the monitor shut off.
    Yes the original items I have done as well as blowing the whole system with compressed air to make sure it wasn't a dust issue. How do I take the ram out?
    Ok, I think I found the RAM, there are 2 cards. So I take both out and then turn the computer on?
    Ok, yep correct spot, I have 2 that look like the 2nd pic just took them out and will try turning on and then replace
  • Toshiba Master
  • 13,433 Answers
Does the DC in light flash?
How is the battery and Dc in led state?
What happens when you try to turn it on? do you get a blink code from any of the leds or beeps from the machine?
Try taking out the battery and the ac power. leave it be for 5 minutes, plug in the power adapter, try turning on. if it doesn't help, unplug wait 1 minute, plug in the battery (Remember you did the last test withOUT the battery).
Now try turning it on with just the battery, what happens?
let me know.
thanks
Posted on Aug 01, 2009
  • 1 more comment
  • Ekse Aug 01, 2009
    Have you tried any of my suggestions yet?
    I would also suggest taking the ram out of the laptop, then try starting up with no ram inside the laptop, it obviously won't start up (still turn it on and let it run for 1 minute ). Turn it off. Place in the other ram module and try starting up, if you don't get picture remove the memory module and try the other slot.
    if that doesn't help take all the ram out again and start up without ram, now repeat the above steps with the other ram module (if you have 2, if you have 1, just do it ones)
  • Ekse Aug 01, 2009
    there should be a cover on the bottom of the laptop which contains the ram modules.
  • Ekse Aug 01, 2009
    disconnect battery and ac power when removing or adding internal components.
Toshiba satellite p105-s6227 built in and external monitors not responding
Your Graphics Adapter may be bad. You didn't post the results of the screen testing in another laptop? Did the screen work? Has the laptop been overheating due to dust build up in the fan, vents, heatsink? Has the Thermal Paste degraded/overheating causing a failure of the Graphics Adapter? When you boot does the HDD blink? Sound? Fan spins? Just no monitor? Any damage? drop? Possible loose connection of the Graphics?
Apr 08, 2013 | Toshiba Satellite P105-S6227 Notebook
Support toshiba.com
It is on web site , go to toshiba tech dept. you can not order , down load.only
Jan 09, 2013 | Toshiba Satellite P105-S6227 Notebook
I have a Toshiba Satellite P105-S6227, when I turn it on, it does one of two things, it either just shows Toshiba in bold letters, and never directs me to my password screen (but the screen is working), or...
Reads like you have a hardware system fault. Check your RAM chips are seated properly and test your HDD using a linux liveCD and running diagnostics tests (UBCD4Win is good for this too).
The other task would be to update/reflash the BIOS.
Sep 11, 2010 | Toshiba Satellite P105-S6227 Notebook
I have a Toshiba laptop, model #P105-S6227. When
Leave battery out and use power supply, if that works battery is faulty. If not it maybe a hardware fault. Do you hear a beep when it starts?? If not could be faulty ram / video / mobo.
Feb 25, 2010 | Toshiba Satellite P105-S6227 Notebook
I have vertical lines (15 of them now) on my Toshiba laptop.
I'm afraid when you see vertical line on an lcd panel, it most likely is screen failure. Ebay has plenty of screen from good companies in Texas. I get most of my screens from Ebay store LCDTECH99. They have the best prices, most screens are under 100 bucks and they ship right away. The Toshiba screen is an easy repair, Only the bezel needs to be removed in most cases. Below is a guide to show the process.
http://www.irisvista.com/tech/laptops/toshiba-satellite-p105/take-apart-1.htm
Nov 27, 2009 | Toshiba Satellite P105-S6227 Notebook
Toshiba preparing to hibernate
Shut it down and start over. That would be the power button for 5 or 6 seconds.
Mar 17, 2009 | Toshiba Satellite P105-S6227 Notebook
Drivers
Here is the link to download your drivers.
Just select your operating system and download.
Satellite® P105-S6227
DON'T FORGET TO RATE !!!
Thanks
Mar 12, 2009 | Toshiba Satellite P105-S6227 Notebook
I'm getting a Black Page
try to boot in safe mode when prompted on startup when u forcibly shut down ur operating sys it will present u with a screen to select safe mode on startup just go thru safe mode and try using system restore in the Start> All programs> accessories>system tools>system restore try to restore on the earlier date when ur sys was ok see if it helps pls vote if u think i was helpful
Jan 29, 2009 | Toshiba Satellite P105-S6227 Notebook
Toshiba flash cards stopped working
go to Toshiba web site. they have your problem solution.
Dec 20, 2008 | Toshiba Satellite A105 Notebook
Open Questions:
See all Toshiba Satellite P105-S6227 Notebook Questions
Toshiba Satellite P105-S6227 Notebook Logo
60 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
