Question about Sharp Office Equipment & Supplies
When attempting to send fax, the 1st page goes halfway and then it reads "line error" what can I do to fix it?
    Brigadier General:
  • 8,619 Answers
Hi
The 'LINE ERROR' message indicates that the Sharp fax machine could not detect a dial tone or available telephone service. A couple of ideas you could consider:
  • Verify that the machine is connected to the telephone line;
  • Verify that there is telephone service to that line. Temporarily connect a regular/standard phone instead of the Sharp fax and determine the presence of a dial tone; alternately, connect the regular/standard to the extension port of the fax;
  • Replace the telephone wire.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Aug 01, 2009
Can't fax multible pages
Your fax machine reads multiple pages into memory before sending the job, this is the pool memory. Two things can cause this error.
  1. Corrupted memory, which keeps the job from transmitting because the data stored is scrambled and lost prior to transmission.
  2. Line static, which makes the connection so unstable and slow that the fax can't get enough pages out of the queue fast enough to make room for the next pages entering the buffer.
If you checked the line and it tested good (not just listening for a dial tone), then it is probably a memory issue.
May 06, 2010 | Brother MFC 420CN All-In-One InkJet...
Fax confirmation with copy of 1st page
what is the error code 05 for ricoh fax 1140L?
Jul 21, 2009 | Ricoh FAX1180L Laser Fax
Using MagicJack for faxing; however, Brother MFC 290C is stating poor line condition - why? Also say's low ink Magenta - would that create this problem?
I had the same problem trying to send out faxes out using my Brother MFC 7340. I use a magic jack phone line. Page 106 of the user manual says if sending via VOIP phone line, you should press menu, then 2, 0, 1 to select "Basic (for VOIP) mode. Then press ok. Then press stop/exit. This cuts the modem speed down to 9600 bps and turns ECM off. Then retry to send the fax. I did that and can now send and receive faxes.
Jun 06, 2009 | Brother MFC 420CN All-In-One InkJet...
Faxing with a digital phone line
I looked up fax problems at HP.com and my guess, based on what I read, is that the 6110 is able to detect the broadband data connection at the higher line frequencies, even though all you hear on the line is a normal dial tone. If you haven't done so already, you'll need to install a line filter on one of your phone jacks (this should have come in the kit with the rest of the hardware you were sent to set up the DSL line). This isn't an issue with the 6110, but a natural "consequence" of using DSL.
Here's the web page I used as the basic for this opinion:
Phone "Off the Hook" Status
On that page scroll down to the "Checking the phone line" section and read the material there. See if that info helps. Good luck.
Nov 04, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Toshiba Super G3, e-Studio 170F
Fax display screen always reads, "Auto receive". When attempting to fax, the busy light flashes. Busy light stops flashing for 30 seconds, then starts flashing again.
Above is the default settings for the fax.
NGB0 indicates signal error or line condition error.
U need to check the phone line. U can hook any single line phone to the phone line, check for tones without background noise.
Sep 10, 2008 | Toshiba e-Studio DP170F Plain Paper Laser...
MFC-8220
Its the CIS unit. Part number LE7949001. $70 retail price.
Aug 15, 2008 | Brother MFC-8220 Fax
Sendidng a fax
I have been sending and receiving faxes for over a year on my Lexmark X6100 printer. Now whenever I try to send a fax it will say it is sending the pages but then waits for a redial. After doing the same thing a second time it will print out "remote fax error"
Aug 11, 2008 | Lexmark X4270 All-In-One InkJet Printer
My fax reads line in use
Make sure the handset switch is working.
Jul 29, 2008 | Office Equipment & Supplies
Sending Faxes
When the last page of your document has been sent successfully, the machine beeps and returns to Standby mode. When something goes wrong while sending your fax, an error message appears on the display. If you receive an error message, press Stop/Clear to clear the message and try to send the document again. You can set your machine to print a confirmation report automatically each time sending a fax is completed. If you get the error message write it down it should always supply an error message if the fax did not go through.
Jul 25, 2007 | Samsung SCX 4521F All-In-One Laser Printer
46 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
