Question about Philips DVP5140/37 DVD Player
Philips DVP5140 suddenly says no disc on every dvd,plays cds fine.
  • Craig Bergstrom
    Craig Bergstrom Nov 05, 2011
    Are you using a burned DVD? If so, what type of DVD? Or is this a store purchased DVD video?
  • 297 Answers
SOURCE: DVP5140 only reads DVDs
The DVD player have two lenses.;cd and dvd lense,the cd lense needs a little adjusment so can read again..
Posted on Jun 19, 2008
jaffa012001
  • 376 Answers
SOURCE: tryed the code to unlock region
1. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all regions
8. Press the "Play" button on the remote
DVP 5106k
1 - Make sure there is no disk in the player
2 - Press EJECT on the remote or on the player. The eject icon has to be visible on screen for the hack to work!!!
3 - Press MENU (System) on the remote
4 - Press the RIGHT button on the remote until you get to the PREFERENCES screen
5 - Now enter the sequence 135566 with the remote control
6 - Now "Region Code" should appear
7 - Select the 0 (multiregion)
8 - Press MENU (System) on the remote to exit the setup screen
9 - Press the power button on the remote to set the player on standby, this saves the new setting.
Posted on Aug 12, 2008
drlalitv
  • 488 Answers
SOURCE: dvd player gives unknown disc
thats because its region locked..do the following:
start the player without any DVD in it.
open the lid.
while the lid is open press 9,9,9,9,0
you should see region 0 displayed.
close the lid.
Your DVD player is now region free.
note:
replace 0 with 1 to 6 at to set the wanted region number if needed.
do let me know if it worked.
Posted on Oct 29, 2008
vishwesh
  • 40 Answers
SOURCE: Can't play a burned dvd disc on philips dvp 3120
You might have created a data cd, dvd player normally don't support data cd. If that is not the case then you the file format is not support by your dvd player.
You would have to search for a software to convert the file to the format supported by your dvd player. and write it on the disc again.
Posted on Jul 29, 2009
hayster
  • 103 Answers
SOURCE: Philips DVP5140 region-free DVD player: NO DISC
You could try cleaning the laser using a laser cleaning disk. Most of the time when it cant read a disk its just because the laser is dirty. If that doesn't work it could just be a faulty laser
Posted on Sep 22, 2009
Why do some of my CDs jump or blank for short periods on my Philips Progressive scan DVD unit? I have used a cleaner disc and the DVD unit is relatively new.
Clean the disc itself. Look at the side (under the label side) and see what it look like? ove it around in teh light to get a good view. Scratches will do this and fingerprints can as well. Use a soft cloth and buff the cd using a circular motion. If it is really dirty you use a mild cleaner like eyeglass cleaner, etc. Usually the jumps and skips are due to a dirty or scratched media.
Dec 04, 2010 | Philips DVP5140 DVD Player
My philips dvd player is not detecting any cd or dvd, it is saying no disc after a long wait. Any idea in this, please help.
well try to purchase a dvd lens cleaner and insert it into the player for cleaning. After that process has been executed you can now insert your choice of disc for play..
Jul 23, 2010 | Philips DVP5140 DVD Player
My phillips dvp5140/37. video player ,stops
Does the player ask for a password?
If it does look in the manual or contact Philips on their website.
This helped me a lot once.
Jun 13, 2010 | Philips DVP5140/37 DVD Player
The player says wrong region code with every dvd i have!! help please Phillips 3020K
Where did u bought this DVD player?US,Canada,and Mexico?The DVD disc. used NTSC region format.Asia,Europe,Africa,and the Middle East.The DVD disc. used PAL region format.They can't be mix or it will not play as u find out.If u move in and out to another region of the world.U must have a regions free DVD player to play either NTSC or PAL regions.
Apr 26, 2010 | Philips DVP5140 DVD Player
Disc shows loading then error on all dvd disc
Put a cd in the dvd player if it is marked that it plays cds... if it plays the cd your dvd laser is shot... cheaper to get a new unit. if it doesn't play a cd try cleaning the laser. and last but not the last thing try unplugging it for a short time then plug it back in... if nothing works get the one tool that fixs most everything...... take it to office depot and they can recycle the stuff inside and help keep the earth green...then onto wally world.
Nov 26, 2009 | Philips DVP5140 DVD Player
Sep 21, 2009 | Philips DVP5140 DVD Player
Home burned DVDs won't load, commercialy produced DVDs load OK
Try using a programme called dvd flick http://www.dvdflick.net/ to author your dvds and use imgburn http://www.imgburn.com/ to burn them. I had similar kind of problem with dvds burned with nero and now use dvd flick and imgburn all the time and have had no problems. They are both free programmes so hopefully they will sort the problem out for you :)
Shaz
Sep 30, 2008 | Philips DVP5140 DVD Player
Phillips DVP5140 dvd player
Sounds like there is a short in your AV cable. Move the video cable (marked with the yellow ends on it) and see it the color changes or use different set of av cables.
Aug 30, 2008 | Philips DVP5140 DVD Player
Jun 19, 2008 | Philips DVP5140 DVD Player
Philips DVP5140/37 DVD Player Logo
117 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
