Question about Husqvarna Forest & Garden No.967012396 345 16" Gas Chain Saw
Starting problems works fine cold, but when i try to restart it after it is warmed up, it won't start
    Scholar:
  • 135 Answers
You didn't mention the type of saw you had if it's even indeed a saw. I have found solutions for issues such as yours. First of all have you heard of vapour lock? Some smaller saws with the gas tanks in the front next to the cutter bar get extremely hot and when it runs out of gas and you refill it (let it cool down first), it may have a little vapour lock and sometimes vapour lock is hard to clear up. Give it full throttle with no choke on when you pull the starter rope. This may help. Also have someone qualified to test the ignition spark. Also, these smaller saws will run hot and the module breaks down. This is not a nice problem because there are so many factors affecting it to have this problem. Good luck with your unit.
Posted on Aug 02, 2009
On my husky 359, i find that when its warm,i make sure choke is in, then pull 6-7 times and vrooooooommmm, seems to work everry time
Posted on Aug 04, 2009
1997 grand marquis wont restart when cold
change air filter and fuel filter clean fuel injectors.faulty coolant temperature sensor will cause cold start problems.
Jan 04, 2013 | 1997 Mercury Grand Marquis
Tip
Vehicle won't start when hot
A common problem that's surfaced a great deal lately is a car/truck that starts fine when the engine is cold but won't when the engine is warm. Most of the time, the car will require a jump start with a warm engine to get it to start. Most mistakenly assume a bad battery and change it out, only to have the same problem. What happens is most starters don't just "quit" when they are defective. A bad starter will usually start your vehicle when it's absolutely cold. Once warm, the starter will behave as follows:<br /> <ul> <li>No power</li> <li>Click then nothing</li> <li>All other electrical is fine (headlights, stereo, alarm etc)</li></ul> If your car or truck won't start when the engine is warm, but starts fine when it's cold, you most likely have a bad starter. Although replacing the battery is less expensive, it rarely (if ever) will resolve this issue. Consider the age of the car / starter when these symptoms occur. If you have an older vehicle (older than 5 years) then replacing the starter is a good place to start prior to buying other electrical components (battery, alternator). <br /> <br /> Always bring the vehicle to a shop that offers a free electrical diagnostic test to confirm the electrical system is sound to rule out an electrical problem first. If the electrical system is sound, I'd go ahead and replace the starter. <br />Although this tip will show under the Lincoln category, it applies to all makes and models.<br />
on Jun 16, 2011 | Lincoln Continental Cars & Trucks
Won't stay started after it warms up
First did you reset the computer after replacing each of these sensors? If you did then i would check the fuel pressure it should be 48-55 psi with the key on and the engine off.If its not within these specs then replace the fuel pump and filter.
Aug 17, 2012 | Cars & Trucks
89 K5 Blazer 350 TBI cranks but won't start... the rad hose blew, i fixed it then the next day it bogged and backfired, ran fine cold, but when warmed up it would lose power and stall when trying
Have you checked Google I found this hopefully it's not your timing or it may be flooded but doubtful have you tried spraying starting fluid into the intake while cranking it
Jun 01, 2012 | Cars & Trucks
1998tarus starts when engine is cold, won't restart when engine is warm, nothing, no clicking
sounds like either the starter solenoid is dying or a bad connection at the battery
Jan 28, 2012 | 1998 Ford Taurus
Runs fine when cold, not when warm though
The next time it won't start check the fuel pressure you should have 48-55 psi with key on and engine off.
Jan 06, 2012 | 1997 Buick LeSabre
97 cavalier starts and runs ok from a cold start after a few minutes of warm up it starts to run rough and miss. If i try to drive it it will start out ok but won't shift automaticly but shifts fine m
Sounds like possibly more than on problem, crankshaft position sensor, or ignition module likely on starting prob which maybe affecting shifting due to hard code in ecm, or shift prob could be shift solenoid in valve body of transmission. Both parts readily available from local parts store
Nov 27, 2011 | 1997 Chevrolet Cavalier
Have a '94 S-10 Blazer Tahoe 4X4 and it starts
My suspicion is a starter going bad. Sometimes when starters get old and worn they will start good when the engine is cold but not when the engine is warmed up. Did you perhaps notice that lately is seemed to drag when you tried starting, especially warm or it seemed to crank a little slower? I'd replace the starter. Hope this helps.
Aug 14, 2011 | 1994 Chevrolet S-10 Blazer
Husqvarna Forest & Garden No.967012396 345 16" Gas Chain Saw Logo
322 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
