SOURCE: car will not start
Recheck the battery, the starter doesn't care if your battery gives 12 volts, it needs CCA (Cold Cranking Amps), Autozone will test this for free where I live, most likely where you live too.
SOURCE: 1995 subaru legacy with new starter and
A solenoid needs so much power to kick in. I think your battery is getting old and not at full capacity. Hove it check and replace if needed.
SOURCE: 1986 will not start with new battery
Have the voltage in your new battery tested. It must have 12 or better and stand up to a 200amp load for 15 seconds, not dropping below 9.5v while load is present, returning to 12 volts after load is removed. If battery tests good, put it back in the car and put a volt meter on it. If when you attempt to start it, the voltage drops to 9.5 or below, change the starter.(but first make sure you can turn the engine by hand). If it does not drop at all check the solenoid and trigger wire (12v at trigger when turned to start, 12v at lead to starter when turned to start.)
SOURCE: WONT START, BATTERY IS UP. MAKES CLICKING SOUND.
if the clicking sound comes from the solenoid when you try to start the engine the solenoid may need replacing, the solenoid is like a big switch that takes the power from the battery to the starter motor,inside it there contacts that come together to make contact & that is where the problem is.....hope this helps.....cheers
