Re: Replacing cutting blades on Bernette fun lock 007d
Normally, only one blade on a serger can be replaced by a user (assuming a replacement blade can be found). If both blades should be replaced, then a technician is strongly recommended since there are minute technical specifications required to make sure the blades are aligned properly.
Bernina Bernette 334D Overlocker - recent service identified the nylon gear cog inside overlocker is broken, Do you know where I can buy a replacement.??
Serger manuals for early machines are really basic.
Thread in order.
upper looper, lower looper, right needle, left needle. (see the inside of the looper cover door.)
Adjust tensions to suit the fabric you are sewing.
If you need to change colors clip threads near the spools and tie on new spools to previous threads and draw threads through an already threaded machine.
Bernina is the brand. But I believe early models of the serger were made by Juki. I've looked for the manual for 006 as well and found thinging. Your only other choice is find someone who has one for sale and ask for a scanned copy.... or order a new one from Bernina or one of the other places that has one.
First to see if the top blade is pressing against the lower blade when it goes past to make the cut.
You should be able to push the top blade to the right and have it spring back to the left. Do that to see if there is a small amount of presser on the lower blade.
Next, the cutting part of the top blade should drop just under the lower blade buy about 2 mil.
Also the lower blade should be level with the needle/stitch plate.
Blades also may need sharpened. The top one can be done with just about any sharpening tool but the botom is carbide so you will need a dimond wheel to sharpen it
