Question about Eddie Bauer Musical Rocking Bassinet 10330WOW Crib
How do you remove the covering from the top of the bassinet in order to wash
Easy, at the top of the bassinet there are two plastic pieces; one on each end.... On the end that has the music volume and on/off switch there is a cover with a small screw holding it on, remove the screw and take the cover off. Next remove the two bottom batteries and you will see a Philips screw inside remove that.
Now on the other side facing out wards there should be another large Philips screw, remove it and the bassinet basket will come out.
Posted on Sep 06, 2009
How do I remove the fabric from the bassinet to wash it?
Some do not have removable covers. Spot washing will do.
Oct 08, 2014 | Baby Gear
Dont know how to remove the bedding from the bassinet to wash
Which part of the bedding is soiled and needs to be washed?
There should be a flat sheet that covers the mattress pad, an optional top sheet, a comforter, a dust ruffle, pillow sham and a decorative cover for the hooded area.
Remove the comforter & top sheet & set them aside. Pick up the mattress inside the bassinet, remove the flat sheet on it and put that with the other items to wash. Leave the mattress pad out, and you should be able to see the dust ruffle. The dust ruffle goes under the mattress pad and hangs like a skirt on the bottom of the bassinet. Pick up the dust ruffle and untie any ribbons that might be used to anchor it on the sides or bottom area. Depending on the bedding set you bought or are using with the bassinett, the piece that goes around the hood area might have elastic to keep it snug, or if you are using the default that came the model that is sold in California, US - its not really removeable without a lot of trouble and other problems - (I would suggest leaving it on unless its REALLY soiled).
Jun 07, 2011 | Eddie Bauer Musical Rocking Bassinet...
How do you take off the bassinet cover for the top part that is like a canopy?
If this is for a bassinet here is the answer I posted for another person. If not, just let us know.
We will see what we can do for you.
Many bassinets have rivets that dont allow you to remove the fabric.
We draw water in the washer and add soap then drop one end in
and work it around until it is in the washer. Use gentle cycle and
cross your fingers that no damage is done. I have washed many of them
and never destroyed one. Good luck
Feb 23, 2011 | Delta Luv Angelina
How do I get the cover off the top of the basinet to wash it?
at the top on both sides where the white plastic is the middle screw needs to come out, the side where u turn the music on u have to take the batteries out to get the it.
Jul 26, 2010 | Eddie Bauer Musical Rocking Bassinet...
How to wash First Years bassinet
I got this second hand and it had a ton of icky little stains on it. I cannot believe a baby bassinet was made without a removable cover!
I sprayed Shout on the stains and soaked it in the tub with HOT water with 2 cups vinegar and 1/2 cup of Borax washing powder (baking soda works well too) I scrubbed the fabric w/ a soft brush and swooshed the loose fabric around in the water. Then I rinsed it in hot water and more vinegar to remove any soaps. Then I towel dried the fabric and set it up in the tub w/a fan on it ( I cannot leave it outside as I have 2 outdoor kitties) I did this at the recommendation of the nice woman who runs our local dry cleaner. It turned out clean and bright and totally stain free! You may want to wrap the handle in Saran Wrap and of course DO NOT submerge it completely. I did this and the light/music feature was dry and still works.
Feb 28, 2009 | The First Years Carry-Me-Near 3-in-1...
Taking off the hood fabric to wash.
go to any gm partsdepartmentat the dealership they can give you details on how to take it off bring in vin Please rate my response. Thank you !
Jan 27, 2009 | 2001 Buick Century
Cleaning eddie bauer bassinet
First take off the battery cover ( your will need a screw driver). Once you do that take out the batteries and you will see a big screw, unscrew that and take out the screw. You will repeat the same thing on the other side of the bassinet, but you access the screw right on the outside (not like through the battery compartment with the other side). Once both of those screws are removed push back the plastic clip on the inside holder and the bassinet will lift right off. Once the bassinet is off you can take the cover right off. It says to hand wash with cold water and line dry. Hope this helps
Jan 19, 2009 | Eddie Bauer Musical Rocking Bassinet...
Kolcraft Bassinet
  • i have kolcraft basinet which i dont have the can padding can some one plese tell me to get one or pleases send one to me thank tou renee kotaska www.rfk1118@yhoo.com
Aug 06, 2008 | Baby Gear
Bedding
I got this bassinet 2nd hand. I can tell you that I did wash the whole set. You have to take the screws out at either end to remove the cover (one screw is behind the batteries in the music box). I removed the plastic parts (the slits are closed with velcro for the flat plastic panels so the plastic simply slides out). The hoops were a little more difficult but since it is an overlap closing and the hoops are flexible, you can remove them. Simply wash in cold water and hang to dry. When its dry, you can put the plastic slides and hoops back in the same way you took them out. Came out fine.
Jun 19, 2008 | Eddie Bauer Musical Rocking Bassinet...
Kolcraft Bassinet
Hello
I too have this bassinet and went looking online for a 'how to' on removing to wash. What I found was the manual, I will post the link below. In the manual it does say that the fabric cannot be removed from the canopy frame.
you have to either turn off your pop up blocker for this manual or hold down "control" when clicking the link for it
http://www.kolcraft.com/Media/B22-R2.pdf
Apr 29, 2007 | Kolcraft Light Vibes 18270 Crib
Eddie Bauer Musical Rocking Bassinet 10330WOW Crib Logo
1,214 people viewed this question
Top Eddie Bauer Baby Gear Experts
Jennifer Rock
Jennifer Rock
Nikki  Mclean
Nikki Mclean
woodzowl307
Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
