Question about X2Gen MG19MY 19" LCD Monitor
My computer screen just starting "autoadjusting" itself the last month and the display adjustment gets off set and I have to move theH postion back to the original setting. Why did this start to occur and how to I stop it? Thanks Judy Richardson
  • judy_richard Aug 06, 2009
    Thanks for the advise. I did check both of these and they are ok. I did have to adjust my resolution a few weeks ago but it is back to where it was always set. When I turn my computer on this "auto adjusting" comes on the screen in a blue box and that is when the H focus shifts to the right. I reset it and later on it moves it again.
  • 3,051 Answers
Hello there
If you go to the monitors properties and if there is a advanced section click on it and make sure that the refresh rate is set to the manufactures specification or you may experience a out of range problem also on your video resolution make sure that it is not set to low ok
best regards mike
Posted on Aug 06, 2009
Install oovoo
Changing the screen size on an Acer computer, whether it is a laptop computer or a desktop computer, is a simple task.
You can adjust the screen size to be larger or smaller.
If your eyes hurt from concentrating on tiny letters all the time, you should make the screen smaller.
If you have to scroll left and right to read sentences in a document on your computer, you should make the screen larger, at least to the point where you do not have to scroll left and right to view the entire window.
Go to the desktop of your computer and right-click the screen.
Click the last option, which is "Properties."
The "Display Properties" window will now show up.
Click the "Settings" tab in the "Display Properties."
Adjust the meter under "Screen Resolution."
When you move the meter to the left, the screen becomes smaller.
If you move the meter to the right, the screen becomes larger.
Click "Apply" to save the settings once you are finished adjusting the screen resolution.
http://www.marthas-web.com/display.htm
Jul 13, 2013 | Acer Aspire One PC Notebook
I am having problems setting the alarms on my Emerson Smart Set clock
Directions for Resetting the Daylight Savings Time (DST) Start & End Dates on the Emerson Research Smartset Dual Alarm Clock Radio (cks5055s):
  • This should work for all Smartsets, but I cannot make the guarantee (and no, I don't have any other directions, sorry)!
  • Adjusting the DST Start Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM1 buttons (at the same time). After 3 seconds the display will show the DST 'start' month, week, and date. It should be alternately showing "4 F" (April and first week week) and "4. 1".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the DOWN (or "-") button 3 times, until the display is showing "3" (March) and the week as "F2". It should alternately flash "3 F2" and "3. 11".
    3. After this is set, the clock should "automatically" reset itself
  • Adjusting the DST End Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM2 buttons (at the same time). After 3 seconds the display will show the DST 'end' month, week, and date. It should be alternately showing "10 L" (October and last week week) and "10. 28".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the UP (or "+") button 1 time, until the display is showing "11" (November) and the week as "F". It should alternately flash "11 F" and "11. 4".
One thing to note, if you ever have to change the lithium backup battery for the Smartset clocks, it will revert back to it's factory defaults and you'll have to go through his all over again.
And this conclude's Search Marketing Guru's public service announcement. :) We'll be back with relevant online marketing posts with our next posting!
Nov 03, 2010 | Vacuums
Monitor stops working and box start floating around on screen with "Not Optimum Mode -- Recommended Mode 1280 X 1024 60 Hz." Replacement monitor works on computer.
check if your monitor has an auto-adjust button, this will help you autoadjusting the recommended resolution so that there are no problems, if not, you can try to rightclick on windows desktop and go to properties>configuration, set the resolution there
Sep 16, 2009 | Computers & Internet
My aopen f2925 monitor has a green tint.
The solution: hidden menu within the main menu itself. Hold the Menu button down while pressing Power to power on, and release power button only when the screen comes up, still holding the menu button. The menu will appear and there will now be a hidden selection, "Auto Color", printed in a red-on-black font at the bottom of the menu. Use the +/- buttons to access it, and press Menu. My green/yellow tint went away! Now my picture works great, and the setting lasts through Auto-Adjusts and Resets!
Apr 08, 2009 | AOpen F70PS 17" Flat Panel LCD Monitor
Screen stays black on startup of toshiba satellite L300
have you tried either switching between external and internal monitor usally Fn + F5 on toshiba or try plugging a monitor into the back and see if it displays.
if you get a display on the external monitor then its probably a screen or inverter fault if you donot get a display to an external screen then it is likley t be the graphics on the board itself.
hope this helps
Feb 22, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
Goodmans Flat screen monitor GV series - when I turn on the screen a message comes up "entering sleep mode" then it goes in to standby (the computer is still on) - HELP
when u start computer press F8 key untill u get safe mode menu.
then go to enable vga mode .then u can enter in wicxp .theh set display resolution in display properties. 800*600 or 1024*768 .
thats all.
Oct 11, 2008 | Computers & Internet
HP 1730 lcd monitor horizontal glitches on screen. the monitor shows clearly but the screen shakes up and down until it enlarges itself of the screen so you can't see the task bar on thebottom the screen...
find the buttons on the monitor itself,  they control all those things.  I had the same problem myself.  It's not within the operating system --- it's the monitor itself.  It's not display control or any of those things
good luck
Jul 12, 2008 | Computers & Internet
Can't manually adjust color
I happen to have an Acer Monitor although a later model. It has 4 buttons....one of these is the auto adjust and one other is the window that has manual controls (so to speak). If you look at it carefully...(and it should stay on the screen for at least a minute - they believe you will do something in that timeframe)...you will find a set of icons at the top. These are suppose to be visually intuitive (and they are after you have used them once or twice)....anyway, if you really want to set your colors manually and or make other adjustments....alignment et al...you use the other buttons when the manual control screen is there. Experiment a bit and you will discover what does what. FYI...all "modern" monitors have this ability....the icons differ....but autoadjust does the best job in general....personal preferences and eyesight withstanding. Good luck....a small glass of wine sometimes helps the process and reduces the frustration level the first time around.
Jan 24, 2008 | Acer AL1916W 19" LCD Monitor
Daylight Savings Times Changed
Oct 29, 2007 | Emerson Smartset Clock Radio
X2Gen MG19MY 19" LCD Monitor Logo
100 people viewed this question
Top X2Gen Computers & Internet Experts
Sandy Moore
Sandy Moore
William Alequin
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
