Question about GE GSS20IBT
Freezer coils keep freezing up solid. refrigerator side doesn't cool down.
  • Mike Smith
    Mike Smith May 11, 2010
    Brand and model number necessary .
  • Dan Webster
    Dan Webster May 11, 2010
    Have you checked the defrost heater? That is the most common problem on self defrosting refrigerators. If the heater has no ohms reading it is bad (open).
    Champion:
  • 363 Answers
Sounds like the circulating fan is wearing out, this problem is very hard to diagnose because the fan still spins but not fast enough to circulate the chilled air thru the freezer and refrigerator. Parts and labor should be around $300.00
Posted on Aug 02, 2009
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 01, 2011 | General Electric GSH22JFX Side by Side...
My freezer is not cooling good but the refrigerator works find
the coils are probably froze up,, unplug it for 24 hours if possible, when it freezes up solid they can't function properly, and the defrost doesn't allow for proper de icing , make sure the components are free of debris on the underside
Jul 15, 2011 | Refrigerators
Maytag side by side. Coils froze solid, no cooling in fridge or freezer. Replaced heat coil and thermostat assly., as well as adaptive defrost control (circuit brd.). Still don't seem to be able to...
Hi Rob,
The problem in your case is most probably with the defrost thermostat.
It can be found on the evaporator i.e. freezing coils , it's round disc like with two wires.
If you get this replaced with a new proper working unit ,
Also make sure you replace the defrost timer as well if the problem persists.
Hope this helps ..:)
Jun 24, 2011 | Refrigerators
Freezer coil freezes up the fan is spinning above the coil but the coil is frozen solid is it the defrost timmer, roper model rtbkxkqoo
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 27, 2011 | Refrigerators
Hi, my GE refrigerator has ice developing on the rear wall of the freezer, and things in my crisper drawer are freezing solid,please help!!!!
Unplug refrig. Empty all food from freezer side and remove shelves from freezer. Remove back metal cover from inside freezer. Melt frost with a hair blower. Examine defrost heater at very bottom of the coils you defrosted. If heater coil inside glass tube is broken, replace defrost heater. (note: replacement may look different, but insturctions included with replacement address that) If heater is not broken, replace the small white pencil shapped sensor at the top of the cooling coils.
Dec 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Hi Side by side refrigerator not cooling down. Freezer seems to be not freezing. refrigerator compressor is running. Freezer damper wide open on a setting, refrigerator turned up to 10, running but not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
jkkfj
Jul 04, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag side by side refrigerator ice forms at the bottom of freez
Your drain is probably plugged. Remove the back panel in the freezer and keep squirting hot water down the drain hole with a turkey baster or something similar until it clears. The drain hole is located at the bottom of the coils in the freezer section. Your refrigerator goes into defrost every 8 to 10 hrs. When this happens, it melts the ice on the coils, which in turn, runs out the hole where the drain is. If something like algae is blocking or plugging the hole, it will plug up causing water to freeze over the hole. The water has nowhere to go but out the door.
Jun 02, 2009 | Maytag MSD2454G Side by Side Refrigerator
Maytag
Heres you problem your drain plug in freezer is likely frozen as well and water is running under fridge. You have to replace the thermostat defroster assembly Its behind the panel at rear of freezer and runs down and under condenser coils. Part cost $42 and plugs in its easy to replace It creates heat which keeps the coils free of ice and also keeps drain from freezing.
Jun 19, 2008 | Maytag MSD2756GES Side by Side...
Solid ice behind freezer panel door
your refrigerator has something wrong in the def system. the most common problem is the def thermostat.
Dec 08, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE GSS20IBT Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
