Question about Tower Aloha Breeze Fan
Lubrication - sounds like a bearing is dry - Tower Aloha Breeze Fan
  • 90 Answers
Dont have bearings
4 screws under 16 at the back
top and bottom of the blade needs oil
Posted on Aug 02, 2009
My Black and Decker blower BV200-04 is overheating and smoking during use, and making noises. Is it repairable. Does it need lubrication and if so, how?
sounds like dry bearing or burnt brushes try lubing the motor and fan bade bearings need to split cover off by unscrewing the case
Aug 26, 2017 | Garden
The fan moter is humming , but the blades do not rotate and the light works.
Hi jfitzmaur84...
It sounds like your fan has dry bearings and not allowing the fan to rotate.
Sounds like you need to disassemble the fan and lubricate the bearings with a good grade of machine oil such as 3 in One oil.
Please take time to rate me
Aug 18, 2011 | Dryers
Where are the bearings that need oiling on my oil furnace motor dayton 8U386?
There may not be any access ports to these bearings...
Most new motors today do not expect to be lubricated in their life's expectancy.
If the bearings are designed to accept oil, there will be either an obvious hole on the top side, (so that gravity can pull the oil down into the wicking or packing box..)
If not-- there is no way of 'oiling' them--
So-- Are you having problems, that tell you that you need to lubricate these bearings?
Like squealing or squeaking-- or 'dry' sounds when the motor slows down?
Tell us more!
Dec 27, 2010 | Dayton Heating & Cooling
I have a Craftsman brand shop vac [model # 113.77420]. It is still picking items when I sweep with it, but it has developed a very high pitched squealing sound whenever I turn it on. The sound makes it...
I have the same problem with a CTC Shop Vac. It's he bearings ... they're worn out and dry ... no lubrication. I've trid taking the motor apart and lubricating the bearings, then it runs super for a few uses but then the squealing starts again. Oitch it and buy a new one.
Aug 23, 2010 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
My dryer is screeching and squealing, dries fine but sounds like it is going to die.
Sounds like your bearings are dry on the shaft. Unplug unit. Remove the rear panel. You should be able to access the center shaft bearing. Using a good general purpose oil, such as 3-in-one, carefully lubricate the shaft and bearing allowing the oil to penatrate. Wipe up any excess or spills. Also check the belt tensioner pulley. You should also lubricate the shaft on it. Reassemble the unit and test. You should have eliminated the problem. Let me know if you need any more help.
hardrocko
Thanks for using FixYa
Feb 17, 2010 | Maytag Dryers
While drying for short time the dryer starts to squeak
Probably a dry bearing
.You would have to gain access into the dryer to establish which bearing/s it is.
You would then need to see if lubricating the bearing/s, would cure the squeak..
If it does not, then you may have to fit a new bearing/s.\
Hope this helps.
Dec 22, 2009 | Maytag Dryers
I have the Sharp Quadra air purifier tower. I clean it
Sounds like a dry bearing in the motor.
If you are handy, you could try and get to the fan motor and lubricate the bearings.
Aug 25, 2009 | Kitchen Appliances - Others
I wana fix the whistling sound coming from the serpintine belt
you probably have a dry bearing, or the bearing is losing its lubrication. Make sure that the sound that you are hearing isn't normal belt noise.
Repairs can be done by yourself. Remove the belt, remove the idler pulley, and take to local bearing shop / machine shop / automotive shop to have new bearing installed.
Jun 05, 2009 | 1983 Chevrolet Chevy
Lasko electric fan purchased from Walgreen's; called "wind machine"; turned on fan yesterday and blades barely move.
is the motor getting hot? try lubricating the main bearings.sounds like dry bearings .farr64
Apr 29, 2009 | Dryers
Tower Aloha Breeze Fan Logo
115 people viewed this question
Top Tower Dryers Experts
Henry  Thomas
Henry Thomas
Jay Finke
Jay Finke
Are you a Tower Dryer Expert? Answer questions, earn points and help others
