Question about Dryers
Heat doesn't work ..dryer spins but no heat is produced
  • Larry
    Larry May 11, 2010
    Electric or gas? could just be a bad heating element if elect. not high dollar and easy to replace.
  • Dan Webster
    Dan Webster May 11, 2010
    The first thing to check would be the heating element. A lot of people assume it is the heating element. It is best to check for open components. Anything without an ohms reading at all would be the problem. I have all sorts of dervice pictures, I have access to cheap parts, I can be more specific if you will post a brand and model number. The model number is inside the door on most units. Does this help?
  • 6,784 Answers
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Posted on Aug 01, 2009
I looked through the peep hole in front of my gas dryer and I don't see anything lit.Dryer spins great, but doesn't heat up. What is the problem?
Igniter - The dryer's igniter is what ignites the gas that has entereddryer-ignitor.jpg through the gas valve. It will glow red, then when it reaches a certain temperature, it will trigger a thermostat that opens up the gas valve and that's when the dryer starts to heat the air. If the igniter has failed, the motor will still run but not produce any heat.
Jan 31, 2012 | Whirlpool Dryers
Frigidaire dryer doesn't produce heat, but everything else is working. What do I do to fix that problem?
Unplug remove panels necessary
Check the element for breaks or issues
if no problems found replace the safety devices directly in line with the power supply for the element
Nov 15, 2011 | Dryers
Runs fine Doesn't dry clothes, not enough heat?
You will first need to determine where the problem is, I would disconnect the dryer vent from the dryer. Now if the drying improves, problem is not the dryer, its the vent system. If no change, does the unit heat at first then slowly fail to heat? Does it produce any heat? I need more information to direct you in the correct direction.
Please get back to me
Sep 08, 2011 | KitchenAid KEYS700LQ Electric Dryer
Hello, my dryer doesn't dry the clothes. What seems to be the problem and how can I check it on my own? Is it the heather, the thermostat or something else? The machine works fine except that its not...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 11, 2011 | Dryers
My ge dryer DBXR453EVOWW , drum doesn't spin, does heat
heatman101
Jun 12, 2011 | GE Dryers
When we turn the dryer on it doesn't produce heat to dry the clothes, we've even changed the heat settings and the dryer just won't get prdouce heat, but when we tried to look online it stated...
hello matt.... the most common cause of no heat is a burned out heating element. Replace it and you should have heat again. Joe
May 07, 2011 | Dryers
Dryer spins but wil not produce any heat to dry clothes
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 16, 2010 | Frigidaire GLER341A Electric Dryer
Why won't my LEB 6300 produce heat? It spins just
unplug remove the back, the heater box is to your right,the heater box fuse is on the left side top check it with your meter,the heater box element is on the bottom remove the 2 wires and check with meter,iam sure it is one of the-mike
Feb 21, 2010 | Whirlpool LEB6300 Electric Dryer
My dryer spins and heat just a little but not enough to dry any clothes
Need to change the heater filament. The heater filament has several portions to produce heat. As it ages, some portions are not producing heat anymore hence the total heat produced by an old filament can not put out as much as originally designed.
Jan 08, 2010 | Estate EED4300TQ Electric Dryer
Dryers Logo
131 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
