Question about Car Audio & Video
Lost radio reception in 1991 Chevy Silverado
What could cause the radio in a 1991 silverado to slowly lose reception, AM went first followed by FM which gradually faded out, now I just get static, new radio didn't fix the problem, installed a new antenna as well and it didn't fix the problem
    Problem Solver:
  • 6 Answers
IT IS THE ANTENNA WIRE THAT RUNS FROM THE ACTUAL ANTENNA MOUNTED ON YOUR TRUCK TO THE BACK OF YOUR RADIO.THIS WIRE IS POSSIBLY BROKEN OR CORRODED.REPLACE THIS WIRE OR RUN A COMPLETELY NEW ONE.
Posted on Sep 07, 2009
1993 silverado no FM reception
That has been a problem with them for years allready that the FM Screws up on some of them, Just go out to a auto wrecker end get a different radio for it,It will cost you less , Then to have it repaired,
Dec 02, 2012 | Ac Delco AM-FM Radio Cassette
AM will not work on my radio
It does not work at all or reception is bad? The radio has a ferrite bar antenna inside. Tune in to the frequency of the station you want and rotate the radio slowly to find the orientation for best reception. You may also try to hook an external AM antenna to the radio.
Sep 29, 2012 | Dewalt DC011 AM/FM Radio
The FM radio reception went out. AM radio reception is still ok. What should I look for to fix the loss of FM radio reception?
Pull radio and check antenna plug in rear of radio, They'll still pull AM with antenna unplugged
Apr 03, 2011 | 2005 Chrysler 300
Improve reception
HI there,
Well Yes you can improve the reception, please follow the below steps -
Improve FM Radio Reception -
1. If you don't have an antenna connected to your FM receiver, purchase a simple dipole antenna--a simple T-shape flexible wire-- and connect it to the FM antenna inputs on the receiver. Because FM signals are directional, you'll want to experiment with the positioning of the wire to find the best reception of the station you're trying to receive.
2. If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
3. If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
4. If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
5. Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
Improve AM Reception -
1. Gradually rotate the radio 360 degrees. Leave it in the position where it sounds best.
2. Reverse the AC plug if it isn't polarized. (If you can flip the plug over, then it's non-polarized.)
3. Plug the radio into a different AC outlet.
4. Move the radio closer to a window.
5. Experiment to learn if appliances and powered products in your home are causing interference: computer monitor, television, electric blanket, light dimmer, fluorescent light, hair dryer, air conditioner, smoke detector. If possible, turn off the offending item. Otherwise, move the radio to another room.
6. Upgrade to an external antenna if your receiver, tuner or radio has a place to connect one.
7. Buy a passive AM antenna that doesn't need to be connected to a radio or receiver.
Good Luck!!
Thanks
Dec 29, 2009 | RCA RP5430 Clock Radio
The AM/FM radio in my 2003 cadillac CTS faded to only static
check antenna cable connections at radio & antenna.suspect power antenna if equipped.
Sep 30, 2009 | 2003 Cadillac CTS
FM Reception with Jensen MSR3007
I have the exact same problem with the exact same stereo. I started by removing the in-line AM/FM/VHF Separator and connecting the antenna directly to the stereo. The static/popping/fade-out continued. Today I swapped to a new antenna, but it did not help. I swapped back to the original antenna and for a brief while, I had good reception. The I went to coil the excess antenna cable and the static/popping/fade-out resumed. I have narrowed it down to either the antenna connector coming out of the back of the stereo or an internal circuit. Either way, it does not look like a do-it-yourself fix.
May 31, 2009 | Jensen CD400M CD Player
2004 Jetta Radio
This is a common problem, mostly caused by corrosion to the circuitry underneath the antenna boot. You may need to replace the antenna itself. Pull off your antenna and check for corrosion. The cost is approx. $80 for the part. This is what the problem with my '04 jetta was and the tdiclub website has a good thread on the problem.
Jul 16, 2008 | 2004 Volkswagen Jetta
Radio frequency fades after few seconds
your headset wires are the antenna of your phone... be sure to let it loose freely to avoid the frequency fading... dont fold it...
Oct 27, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Car Audio & Video Logo
395 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
