Question about Refrigerators
Icemaker motor gear timing to ice kick out shaft gear
  • Refrigerators Master
  • 8,220 Answers
Auger does not turn to dispense ice in Ice Maker of Frigidaire refrigerator ModelGLHS66EJW. Icemaker still makes ice correctly.
Without seeing it Im guessing. Sounds like one of the small plastic gears inside is off track.There should be like a cover on the outside with 4 screws to open it. Make sure the shaft is turning when the small motor engages.Somethimes they get off track while manually shutting off ice maker manually using the bar
Aug 11, 2013 | Leviton 10 Brown Switch Outlet...
Loud noise from JD-21 ice maker
Usually a stripped gear or a bad icemaker motor. Remove the icemaker front cover by using a flat screwdriver to pry it off between the bottom of the icemaker and the cover. Inspect the icemaker to see if the large white plastic gear has any broken teeth or is cracked in the middle. The motor is in the 10:00 position of the white gear. If the gear is ok, and the noise is coming from the motor, replace the motor.
After unplugging the refrigerator you can remove the motor assembly by removing three screws in the mounting plate, and then two screws holding the motor on. The parts house also sells the complete icemaker, however your refrigerator is already 29 years old if I am reading your model number correctly. Good Luck, Appliance Specialists
Jan 01, 2010 | Kenmore Refrigerators
Door icemaker will not dispense ice. Motor starts
At the very least you have worn out coupler components. Determine what the motor issue is and replace it if necessary also.
Eric
Oct 16, 2009 | Whirlpool GS6NBEXR Side by Side...
Icemaker makes Ice But doesn't dispense it.
Had same problem. Looked everywhere and found no solution i'm a not a repairman...they probably do not want to post so they can make 150 for a repair visit. At least try this first it may save you $$. Remove ice bucket from freezer. Remove 2 screws @ auger...remove cover and auger ....remove spring and large hex shaped shaft. heat the large shaft end with a torch and put it back in hot side toward motor until the motor end is not frozen. No torch you can use hot water...but that may freeze again.
This was happing because my flap to the ice was not closing all the way .
Manual for parts can be found here it shows ice maker parts on page 7.
Good Luck Kono
Aug 21, 2009 | KitchenAid KSCS25FKSS Side by Side...
My U-Line ice maker somehow leaks water inside the freezer and a layer of ice builds up on the bottom below and to the sides of the ice container. It continues to build until ice container is not...
You can have a couple of things causing this. First do you see flakes in the ice cubes? Yes replace the icemaker. No then I would remove the cover off the icemaker (pry on the corners and pull) Check to see if the motor gears is rusty. If yes then its causing the motor to run slow and overfillilg the icemaker. You can also check to make sure the fill tube is pointing downward in the water cup of the icemaker. If that looks goo then it cold be the matter of replaceing the faceplate of the icemaker. That would replace the switch, motor and gears.
Aug 16, 2009 | U-Line Icemaker
Ice maker doesn't turn out the ice/ tray fills with water, and freezes, but doesn't turn out the ice into the door dispenser.
Top 2 possiblities
1/ The motor that ejects the ice is shot.
or
2/ the heater element that melts the ice into pieces.
Here is where you can probably pinpoint problem.
Making Ice When everything is hooked up, the icemaker begins its cycle. The cycle is usually controlled by a simple electrical circuit and a series of switches. In the diagram below, you can see how the icemaker moves through its cycle.
  • At the beginning of the cycle, a timed switch in the circuit briefly sends current to a solenoid water valve. In most designs, the water valve is actually positioned behind the refrigerator, but it is connected to the central circuit via electrical wires. When the circuit sends current down these wires, the charge moves a solenoid (a type of electromagnet), which opens the valve.
  • The valve is only open for about seven seconds; it lets in just enough water to fill the ice mold. The ice mold is a plastic well, with several connected cavities. Typically, these cavities have a curved, half-circle shape. Each of the cavity walls has a small notch in it so each ice cube will be attached to the cube next to it.
  • Once the mold is filled, the machine waits for the water in the mold to freeze. The cooling unit in the refrigerator does the actual work of freezing the water, not the icemaker itself (see How Refrigerators Work for details). The icemaker has a built-in thermostat, which monitors the temperature level of the water in the molds. When the temperature dips to a particular level -- say, 9 degrees Fahrenheit (-13 degrees Celsius) -- the thermostat closes a switch in the electrical circuit (see How Home Thermostats Work for details on this operation).
  • Closing this switch lets electrical current flow through a heating coil underneath the icemaker. As the coil heats up, it warms the bottom of the ice mold, loosening the ice cubes from the mold surface.
-->The icemaker has a heating coil underneath the ice mold.
  • The electrical circuit then activates the icemaker's motor. The motor spins a gear, which rotates another gear attached to a long plastic shaft. The shaft has a series of ejector blades extending out from it. As the blades revolve, they scoop the ice cubes up and out of the mold, pushing them to the front of the icemaker. Since the cubes are connected to one another, they move as a single unit.
  • At the front of the icemaker, there are plastic notches in the housing that match up with the ejector blades. The blades pass through these notches, and the cubes are pushed out to a collection bin underneath the icemaker.
  • The revolving shaft has a notched plastic cam at its base. Just before the cubes are pushed out of the icemaker, the cam catches hold of the shut-off arm, lifting it up. After the cubes are ejected, the arm falls down again. When the arm reaches its lowest resting position, it throws a switch in the circuit, which activates the water valve to begin another cycle. If the arm can't reach its lowest position, because there are stacked-up ice cubes in the way, the cycle is interrupted. This keeps the icemaker from filling your entire freezer with ice; it will only make more cubes when there is room in the collection bin.
This system is effective for making ice at home, but it doesn't produce enough ice for commercial purposes, such as restaurants and self-service hotel ice machines. In the next section, we'll look at a larger, more powerful icemaker design.
Jun 07, 2009 | Kenmore 21.9 cu. ft. Side-By-Side...
I have a kenmore side by side and the icemaker makes a ticking noise that last about thirty seconds and stops. It happens maybe once an hour. How do we stop the ticking ?
the ticking noise is the icemaker motor. during ice harvest there is a time whne the icemaker motor "stalls" out against the ice before the ice releases into bucket. its during this time the motor is making the noise. this is a sign of motor gear wear. the motor module on the front of your icemaker needs replacing the part number is 8201515 and should run 60-80 dollars. this part is easily replacable. remove front i/m cover and there are 3 phillips screws that hold the module in place.
Hope this answers your question. any furhter questions just leave a comment here and I'll be glad to assist any way I can.. Peyton
Mar 01, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Whirlpool Ice Maker Won't release ice
Jetguy77,
I have a 1993 year (16 years old now) Whirlpool side-by-side with icemaker, Model ED22PW. I have had similar problems with the icemaker - water goes in, freezes, but ice does not eject from tray. It has happened to this unit 2 times since 1993. It turns out the problem is not the thermostat. It is the icemaker motor module. The icemaker has a small synchronous (clock) motor that rotates the ice ejector. When it goes bad, the ejector does not rotate, either because the module timer had failed or the motor itself has failed. The solution is to go to your nearest applinace parts dealer and by a new "icemaker motor module" for Whirlpool Model (your model here). Mine cost $58.85 the last time I replaced it in 2006. To install the new module, you will need to remove the icemaker from the refrigerator. Mine has 3 screws that attach it to the side. Also unplug the power & control cable. The water tube slides out when you pull the unit forward. When you get it out, it is then easy to remove the motor module and insert the new one. You may have to reset the timer on the module to get the tray to fill completely.
Jan 18, 2009 | Whirlpool GS6NBEXR Side by Side...
Uline icemaker for my 370 sea ray stopped working 100% of the time
http://www.u-lineservice.com is the mfg customer service site......there's a link to information and service numbers along with email based service requests.
The motor/gear/switch plate is available as a service part......
or you can use these links for tech help....
OnlineService@U-Line.com
1-800-779-2547
Jun 26, 2008 | U-Line Icemaker
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
