1982 machine, tub will not pump out at end of wash or rinse
  • Dan Webster
    Dan Webster May 11, 2010
    Will you post the model number and brand please?
    Brigadier General:
  • 4,090 Answers
Sometimes its just soap buildup and blockage like cholesterol in arteries. have the pump cleaned or replaced . Other times its a fused pump either way it needs service
Posted on Aug 01, 2009
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
The Tub Clean function never ends
why do you use tub clean function, we have never had the need to reclean the tub having just run hot detergent and water thru it .
Oct 04, 2015 | LG WM Washing Machines
Water won't drain from tub.how to change pump.everything else works fine. nothing pluged.
Does water drain when washer goes from wash to rinse or is it just at the end after rinse. It could be a switch on the cycle timer not working if it doesn't pump out at all. If it doesn't pump out at only the end maybe one of the cams on the timer that makes the switch to dump water is loose or broke.
Dec 30, 2014 | Kenmore 94702 Front Load Stacked Washer /...
This washer machine is about 4years old it's a whirlpool model # LCE4332PQ1 and the problem that I'm having is that it's making this loud noise when it's rinsing in on the finally rinse it don't drain
Almost sounds like a bearing going out, but that wouldn't address the no drain situation. My bet is a sock has lodged itself between your basket and tub. They usually end up covering the drain whole. Sometimes they work their way down into the hose between tub and pump. There they often work themselves against the propellers of the pump. Check that the hose is clear and pump functions correctly before attempting basket to tub disassembly. Also look really closely with flashlight at the drain holes at bottom of basket, you may be able to see it if it's between basket and tub. If you can see it try to move it towards drain hole with a straightened coat-hanger. If you can get it there i think it is just a matter of removing the hose from the tub end on your model and grabbing it with some needlenose pliers. Keep in mind i'm going from 20 sec. of video here, so i could be way off base. Hope this helps.
Dec 30, 2012 | Washing Machines
At the end of the rinse cycle, water and suds will
Does water empty on spin? if not to check for blockage remove waste pipe from drain, place as low as possible into bowl, if water flows then fault likely to be on pump, if no water flows then pipes blocked and need to be removed to clear them. Good luck
Feb 12, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
FISHER PAYKEL WASHING MACHINE STUCK IN RINSE CYCLE
lift the end of the drain hose see if the tub fills and goes in the rinse cycle if it works you have a syphon problem if so make your drain pipe stand longer.
Aug 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washer runs wont pump water out
You have a sock stuck in the tub at the tub to pump drain area.
You can take a wire coat hanger and straighten it out. Bend a "U" in one end. Fish it down between the tubs at the drain location and pull out whatever is stuck. If this does not work, you will have to remove the inner tub to get to it.
May 24, 2009 | GE Washing Machines
Fisher paykel ecosmart washer wont go drain or go to rinse cycle
this is joyce
take hose and siphion the water out of the unit.run into pan on floor or outside if you have long enough hose. it will come out just get started by putting one end in water in tub and the other end outside or in tub or whatever and start suction on hose untill water comes out and let run untill all water is out of tub.
thanks,
joyce
Feb 07, 2009 | Fisher Paykel EcoSmart GWL15
I replaced drain pump due to broken vanes, now washer will not rinse
timer problem replace it you did not do anything that caused it it just failed
Jun 13, 2008 | Frigidaire FWT449
Kenmore Washing Machine doesn't rinse
The drain line is probably clogged. Maybe that a small sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. Check as well that pump spins and clean from any clogged. Good luck!
Oct 08, 2006 | Kenmore 43042 Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
