Question about Refrigerators
Refrig side not working
I have a Frigidaire Pure Source Plus, Model FRS26ZRG
The Freezer side is working BUT the Refrig side is not working.
    Champion:
  • 363 Answers
Sounds like the circulating fan(evaporator)is wearing out, this problem is very hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and refrigerator. The parts and labor are around $300.00
Posted on Aug 02, 2009
Which numbers give the coldest setting in the fridge section of the Frigidaire Refrigerator
THE COLDEST SETTING IN THE FRIDGE SECTION OF THE FRIGIDAIRE SIDE BY SIDE FRIDGE, MODEL # FRS26ZRG IS # 6
Oct 21, 2014 | Frigidaire Refrigerators
We have a Pure Source Plus model, no manual as it came with the house we purchased a year ago. Things worked fine then. A few months ago the water pressure lowered and temp changed(became warmer) for the...
the ice maker slows as the tempt in freezer gets warmer . icw cream get softer ect . ck for ice build up in back of freezer and the evap fan motor may be running to slow causing poor air flow . ck these first . mm
Aug 10, 2010 | Frigidaire FRS3R5EMB Side by Side...
Water pooling inside of refrigorator
sounds like the drain line for the defrost cycle is plugged. the water is supposedto end up in a pan under the refrig. the drain probably needs to be defrosted and cleaned.located behind the back panel in the freezer compartment
Jan 21, 2010 | Frigidaire Refrigerators
Water leaks on the floor. i Is there a tray that
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
Nov 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
Water leaks from the pure source filter
vaseline on filter threads and tighten...thumbs up...
VE6GAR 73 88 99
Aug 10, 2009 | Frigidaire FRS3R5EMB Side by Side...
FREEZER NOT FREEZING
I will be more than happy to help.  Read this first on Frigidaire Refrigerators.   Then if you have anymore questions about this ask me on Frigidaire Tech Support.
Thanks, Bill
Jun 30, 2008 | Frigidaire FRS26H5AS Side by Side...
Fridge stopped working, freezer still works
Light going out is a separate problem. If the freezer is still working and the fan in the freezer operating check for frost on the back wall. If there is frost on the back wall you have a defrost system problem.
Possible open heater, bad timer, or defrost thermostat. If the freezer is not working check for power to it. Reset the breaker if necessary.
If the light went out because of some power loss the freezer would not be working.
May 26, 2008 | Frigidaire FRS26ZSG
I have a Frigidaire model FRT21LRG
CHECK TO SEE IF THE CONDENSOR FAN IS WORKING IT COOLS THE COMPRESSOR IF IT IS THEN UNPLUG IT AND LAT COOL DOWN FOR A DAY THEN TRY TO SEE IF IT WORKS BETTER IT MAY NEED A RELAY OVERLOAD TOO BUY A 3 N 1 START KIT IT TELLS YOU HOW TO WIRE IT ON THE PACKAGE
Aug 26, 2007 | Frigidaire FRS23KF7AB Side by Side...
Refrigerators Logo
324 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
