Question about Hamilton Beach Steam Excel 14770 Iron
I have Laurastar steampump model 01-0165. How
I have Laurastar steampump ironing station, model 01-0165. How do I clean the steam jets?
  • Chris Roubis Jan 21, 2012
    nothing will clean it.. you can try though.. once it calcifies all the tiny passages in the iron, you need to replace it... then it will just happen again to the new iron.
  • Anonymous Mar 13, 2014
    Laurastar iron: the water indicator keeps on beeping even there is enough water
    Brigadier General:
  • 4,088 Answers
Vinegar and water mix (about 1 to 4 ratio) and run through. Use distilled water only thereafter--rinse through several times to clear out vinegar.
Posted on Aug 01, 2009
Nothing will clean it.. you can try though.. once it calcifies all the tiny passages in the iron, you need to replace it... then it will just happen again to the new iron.
Posted on Jan 21, 2012
How can i dismantle a laurastar s4 iron?
not really-- use the correct iron cleaner and if that doesn't work, the damage done dismantling the iron will require a new unit any way
May 11, 2016 | Irons
I have a lauraStar Magic Evolution and Steam is escaping around the filling cap. Alot What do I need to do
rubber fittings destroyed in internal compartment,ervice by expert professional
Jan 12, 2015 | Irons
Brown steam
Brown steam is normally associated with internal rust in the iron. descaling may help clean it up. To descale make a solution of 3 parts distilled water to one part white vinegar, about a teacup full and pour into the irons water reservoir. Switch the iron on and set it on to the highest steam setting. Place a clean tea towel or similar on the ironing board and steam-clean it with the iron for a few minutes. The vinegar/distilled water solution will break down and expel the limescale. Turn off the iron (unplug). Pour out the water and vinegar solution. Pour clean distilled water into the iron reservoir and steam-clean a new clean cloth for a few minutes. this will remove any risidual vinegar etc. Turn off and unplug the iron and pour out the remaining water.
Oct 26, 2013 | Morphy Richards Jet Stream 42271 Iron
My Laurastar Premium Steam Iron is letting out lots of water with the steam Why/
see this steps and fix it. God bless you
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below). If the iron produces too much or too little heat, test the . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Nov 14, 2012 | Irons
MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON does not provide steam
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
Feb 29, 2012 | Irons
The iron will not steam and the standby button is constantly flashing
Always switch off the unit and allow to cool before cleaning or storing. .... If your steam generator does not work, check the following points: ... working temperature, the LOW STEAM ICON will flash whilst the heating cycle takes place ... steam. 9 When ironing is complete, press the POWER. STANDBY button.
Jul 27, 2011 | Morphy Richards Jet Stream 42271 Iron
My new laurastar steamer is not producing steam at
plse call customer service on 1800 999 910
Nov 13, 2009 | Irons
Hamilton Beach Steam Excel 14770 Iron Logo
1,032 people viewed this question
Top Hamilton Beach Irons Experts
Jim Thurston
Andrew Taylor
Andrew Taylor
richie46
Are you a Hamilton Beach Iron Expert? Answer questions, earn points and help others
