Question about Kenmore Washing Machines
The control lock button is lit - we can't start the washer...
  • 15,935 Answers
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
Control lock lit, no other buttons work
Instructions
    • 1 Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
    • 2 Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
    • 3 Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
Read more: How to Unlock the Control on a Whirlpool Duet ' eHow.com http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html#ixzz2HVS4i8hL
Jan 09, 2013 | Kenmore HE4t 3.8 Cu. Ft. King Size...
The "Control Locked" light is
The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start.
You can lock the controls while the washer is operating.
To lock the controls:
Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows.
To unlock the controls:
Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
Mar 31, 2011 | Washing Machines
I am trying to start my washer and the symbol of a head with a collar appears on the dial and i am unable to change any of the controlls or start the washer.
Hi.
Samsung machines error codes are numbers and letters, then I the machine is not in fault mode, but child lock has likely kicked in.
Here is child lock icon:
Try the following:
ACTIVATING/DEACTIVATING
If you want to activate/deactivate the Child Lock function, press the Soil Level and Signal
buttons at the same time for 3 seconds.
How It Works:
1. "Child Lock" can be activated while your Washer is running.
2. Once you activate "Child Lock", all controls (except for the Power button) will be locked
until you deactivate "Child Lock".
3. The Child Lock button will be lit while it is in effect.
Here the user manual.
Jan 11, 2011 | Samsung WF218AN Front Load Washer
"Control Locked" lamp is lit on the washer. Tried
Press and hold the end of cycle button for 15 seconds this should clear it.
Control locked
Nov 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control lock is lit up and will not go to any
This happens often, pressing buttons, sometimes it can be easy to slide into control lock. I have this link that shows how to turn it off.
http://www.managemylife.com/mmh/questions/193855-how-do-i-disable-the-control-lock-on-my-duet-washer
Jul 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The contol lock red light is lit and I can't get it to work
Jun 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
"Control Locked" light is lit. Washer won't start now.
Hi
Thanks for using FixYa. Press and Hold the "End Of Cycle" button so that it resets itself. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
"Controls Locked" light lit, unlock button has no effect
Have you tried unplugging the machine for awhile to let the board reset?
Nov 14, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Control Locked
Locking controls
lit, all buttons are disabled. You can lock the washer while it is
operating.
Select and hold END OF CYCLE SIGNAL for 3 seconds.
Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
37 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
