Question about Garmin StreetPilot C330 GPS Receiver
Video is there a video on how to set a c330 up?
  • 504 Answers
Re: video
Not that I am aware of. What questions do you have? I may be able to help you set it up.
Posted on Feb 10, 2008
0 characters
3 Points
C330 will not power up when plugged into power receptacle in car
First, check the car's power receptacle by plugging in another device that definitely works (or take your gps to another car). Cars generally have a fuse associated with the receptacle that can blow. The second most likely problem is that the internal battery inside the c330 has died. This is especially likely if the unit is old (more than 1 year) and if you live in a climate with extreme heat or cold (which reduces battery life). This video shows how to replace the battery:
The company that produced the video sells a kit which includes the battery and tools necessary to replace the battery yourself. See: I swapped the battery of my brother's dying GPS using the aforementioned kit and all went well. His Garmin is back up and running smoothly.
Hope this helps.
Jul 11, 2010 | Garmin StreetPilot C330 GPS Receiver
How do i update my c330
check your settings you will find it needs to be updated
Oct 20, 2008 | Garmin StreetPilot C330 GPS Receiver
New voices for c330
Go to Tools.....Settings....Language.... under Voice make sure Language with ( TTS ) is chosen
Not sure on your Model but its where the Language is set
Aug 03, 2008 | Garmin StreetPilot C330 GPS Receiver
POI menu with custom POI does not appear anywhere on the C330?
You need to use Garmin POI loader to input custom POI. After loading POI's they will show up in "My Favorite" under "Custom POI"
Jan 10, 2008 | Garmin StreetPilot C330 GPS Receiver
Added Avoidances
Go to setting and then Navigation and you should see the following
Dec 28, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 Navigation quirks
did you check the avoidance settings.....possibly you checked highways and the GPS is avoiding them
Nov 30, 2007 | Garmin StreetPilot C330 GPS Receiver
NUVI 250W compared to the C330 streetpilot
Are both units set to the same level of detail in the map options?
It is possible to choose the level of detail displayed on the maps. Look at your map settings in the setup menu to increase the map detail.
The level of detail may also be different if both models are not set to the same map scale. The more you zoom in, the more detail you see.
Nov 01, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
19 people viewed this question
Top Garmin GPS Devices Experts
Tom Chichester
Jonathon summesfield
Bill Gilhooly
Bill Gilhooly
Are you a Garmin GPS Device Expert? Answer questions, earn points and help others
