Question about Sport & Outdoor - Others
Run ok out of water, in water wont rev up or plane out . Cleaned fuel tank,rebuilt carbs.
  • 32 Answers
I think maby that you have a small woter or air leak somewhere, find that and you should be good
Posted on Aug 03, 2009
My eckman ptc1 cultivator but is spasmodic on throttle it'll rev to full power then it wont added redx to try clean carb what next
could be water in the fuel blocking the main jet
put in a 1/2 bottle( 1/2 pint) of methylated spirits into the fuel tank
other than that remove and overhaul the carby
Jul 20, 2017 | Garden
Rebuilt duel carbs but one acts like its not getting enough fuel almost like its in limp mode
Recheck the carbs to see the slide needle is properly located. While you are in there check the float valves are right.
Feb 17, 2016 | ATVs
Get my 1980 Suzuki GS8750L to run when I turn throttle..it starts n runs fine otherwise..idles wonderful
Is the fuel flowing freely? Definetly a fuel/air starvation issue. Something really simple such as blocked tank filter ,even a blocked exhaust,next doors cat isn't stuck up the pie nis it??
Oct 05, 2014 | Motorcycles
Hs45 does not prime properly and won't run at full revs
Replace the carbeurator and all fuel hoses. The circuits in the carb are stopped up and they are so small they can't be properly cleaned out.
Jun 23, 2014 | Stihl Garden
Why does my 8N Ford tractor die at about half throttle?
Sounds like it might be starved for either air or fuel. Have you made sure there is full gas flow from the tank to the carb? Also recheck the needle valve regulating gas flow into the carb. May be that a speck of trash is partially plugging that flow to carb. Should have in-line fuel filter (add on) in addition to the bowl 'filter
Mar 30, 2014 | Ford 8N Tractor
I have cleaned the gas tank, fuel lines and rebuilt the carb. It now runs but just at idle almost in the choke position. I have played with the throttle and it wants to die when I move it to normal ru
if it runs only in choke it sounds like its lean (choke reduces airflow and gets back to a mixture it will run on.....just). It could just be a small bit of crud in the carby jet. You cleaned the fuel system.....did you install or replace a fuel filter? sometimes cleaning the tank and lines stirs up stuff that needs to be filtered.....even though you may had cleaned and rinsed out a lot.
Nov 22, 2013 | Electrical Supplies
1983 CJ-7 Had someone put water in gas tank? Blew out lines, rebuilt carb and cleaned out, cleaned tank, gas dryer and new fuel, new fuel filter (clear), new fuel pump,replaced rotor cap, plug wires,...
You put something back the wrong way.....any amount of water in the tank, carb or whatever WILL NOT cause the engine not to fire.....check any wiring/rewiring you did for accuracy
Sep 20, 2011 | 1983 Jeep CJ7
33cc 14 inch homelite chainsaw, wont rev up to high speed, will start and idle fine, but when you try to rev it up it just dies. I have changed the plug, cleaned the muffler, changed the fuel, rebuilt the...
Morning William:
Acceleration is the "L" needle, try 1/8 turn CCW. No better 3/16 CW.
Please install a new filter on the fuel line, you will be beat to death with carburetor overhauls if you do not.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 27, 2010 | Homelite Garden
55hp suzuki wont get up and go
I had the exact same problem. The problem was that there was a piece of dirt in main jet of the bottom carb. The engine would rev up aton fast idle but would not produce enough power to plane the boat due to the lack of fuel flowing through the carb. Cleaned all three carbs. Motor ran like a champ.
Jun 10, 2009 | Light Outboard Motor Boat Bass Fishing...
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
