Question about Pantech Matrix Cell Phone
When i slide it to show the full keyboard it goes to the correct screen then goes to the screen it was just on. what happened and how can i fix it?
    Problem Solver:
  • 11 Answers
Not sure how to fix it...but try looking in the matrix's manual and look for the support number call them and see what they can do, maybe they can send you a refurbished one or new one. Also you can try going to AT&T and see what they can do about the phone and replacing it.
Posted on Aug 06, 2009
    Brigadier General:
  • 7,752 Answers
You should take it int a service center to a check'd it may need reflashing....
Posted on Aug 01, 2009
How do I fix problem with hp pavilion dv7 that the fan runs but screen remains black and the keyboard does not function
hello Anonymouse
It is possible that the problem in the slide card that beats screen located on the main board and the faults which also appear on-screen plasma appearance of a white image on the screen or the colors are without any data. Easy to verify the integrity of the slide card that beats the screen by pressing of Touch Pad or the left part of Keyboard to the East, including notes. When connecting to an external monitor with no emergence of data
Among these symptoms we see that it is clear that the device temperature was high because of heat produced following larger processor and thus the slide master ICH
Card and slide the screen. However, the slide of the type Intel does not notice the high levels of heat and when exposed to heat the welding related Qdanvsal on the main board of the parent on the board
Sep 15, 2014 | Computers & Internet
I have an LG Neon. The screen goes black when I slide the keyboard out. I read about a similar problem that addressed and said it was the flex and that it can be fixed. How would I go about getting that...
Most of the sliding phones have the fault of the flexible connection that gets worn or broken with long useage.
So this is possible in your case as the contacts cut off when slided.
You will need the small set of tools to remove carefully and change , if not this work will be done with the mobile store with the part available to them while you wait.
Other wise youwill have to remove to get the correct size/type of the strip and change.
Decide what will be the best for you.
Sep 27, 2010 | Cell Phones
If i have the slide opened the screen and image works ok but if i slide to close the keyboard, the screen goes dark with some glitchy images sometimes and then if i open it again and use the direction keys...
There is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Take care.
Aug 25, 2010 | Nokia N95 Cellular Phone
When i slide my phone open to use the keyboard the screen goes blank and the phone turns off. what is happening and can it be fixed?
The problem is from the flex of the phone.
The flex is the mechanism that assists the phone in flipping.
It is faulty and is not allowing the free flow if information from the board of the screen side of the phone.
so it seizes whenever you slide the phone.
it can be fixed.
all you have to do is replace the flex and it will work perfectly again.
take care
Jun 18, 2010 | LG Neon GT365 Cell Phone
HP laptop. Ok when turned on, then after a while
f it's just the screen that's broken (most likely a connector if it goes white when you move the hinge) you could probably fix it yourself by taking the case off the screen and reinserting the connector. If it's the motherboard, though, and you want someone else to fix it.
Here it seems that monitor has got problem, you have to replace the LCD panel, which will cost you some amount.
Thanks.
Apr 17, 2010 | HP Pavilion dv6000z Notebook
My laptop goes crazy, the keyboard selects random things when i type, windows open and close, stuff goes sidways when i garb windows, and stuff like that this happens when i touch my laptop, just when i...
Hello my friend,this is probably virus or keyboard hardware problem.Update your antivirus and make full scan.If this still doesnt fix your problem go to device manager(Right-click My Computer then select Properties,select the Hardware tab,click the Device Manager button) for windows xp or click Start -> in the "Start Search" box type "Dev" (without pressing enter); wait for a list to show up and click Device Manager for windows vista.Next go to Keyboards right click all the keyboard you see and press unistall
Feb 06, 2010 | Dell Latitude D520 Notebook
When I hit forward slash my audio deck comes up on the screen. When I hit hyphen, the volume shows up on the bottom of the screen. How do I correct this?
electricb921
It sound like your "CTRL" key or some other function key is stuck on your keyboard. I would try another keyboard on your computer. If the problem goes away then the problem is with your keyboard.
Issken
Jan 10, 2010 | ASUS Computers & Internet
Icons have got larger and dont fit on screen properly. When actioning a task briefly they revert to correct size. Was fitting a case and when finished everything was larger. Can,t see all keyboard or other...
The same thing has just happened to mine, I rang Apple helpline. Put three fingers onto the screen and double tap. This will reduce back to normal. Then go into Settings and choose accessibility and zoom. Turn this function off.
Nov 14, 2009 | Apple iPhone 3G
Samsung V25 Laptop When it is powered up nothing is showing on the screen although the power light is on and you can hear a noise. This has happened before and it just came on.
One way to make sure the system is still working, remove the Batery, then plug the power adapter only and turn the computer back on, normally if the laptop goes into Hybernation mode and the battery is low on power this can happen. If that fixes the system then you can do a safe shutdown and re-install the battery and turn your laptop on and it should come on, the fact that you mentioned this has happened before makes me believe it is Hybernation issue. Good Luck.
Jan 07, 2008 | Samsung V25 CXTD 2000 Notebook
Pantech Matrix  Cell Phone Logo
64 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
