The manual does not help me with this, and i cant seem to find how to do this in the service menu. Please do not post suggestions from other models or manufacturers it wont be the same for a Runco projector. The Projector is functioning properly all im trying to do is reset the timer now after i have added a new lamp!
SOURCE: RESET LAMP HOURS
Hi Greg147
The resetting is not done in the menu.
Plug in your power cable - Machine is now in standby mode.
Then Hold down the left and right arrow keys on the Projector and press the power button. You'll see a indicator light on top of the Projector flashing twice - Lamp hours is now reset.
Hope this is of help.
SOURCE: Lamp hour reset
I don't thing that because you were not reset the time lamp used now your LCD projector stop function
What was exact the unit did? no power at all or some LED light up or flashing. In any case to reset the lamp time use you must enter when unit is on
As you mentioned you did replaced the new lamp, You should check again if you reinstalled properly the lamp and lamp cover because under the lamp cover it had a safety switch if this SW not active then the unit will be in protection mode
I sugges you to remove again the lamp and reinsert properly and secure the lamp cover and try it again and if it still is not go then let me know what are the status of the 2 LED
Cheers
SOURCE: Lamp time resetting
HI
Not sure if its in the handbook but you can download a copy from here
http://safemanuals.com/user-guide-instructions-owner-manual/SONY/VPL-CS5-_E
SOURCE: Panasonic projector PT-L78 lamp reset
Press the MENU button. Use the < > arrows to get to the OPTION menu. Press the ENTER button. Select LAMP RUN TIME. Press and hold the ENTER button for about 3 seconds. The 'lamp time reset' will display. Press OK and press the ENTER button. This will reset the lamp hours as well as turn off the projector.
SOURCE: Hello Wardens wife
What you want to do is go to the advanced menu, find the filter time and using the remote hold down reset button for 3 seconds or so while the filter time is selected. This will bring up a reset menu and reset the timer.
