Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
Motor turns but shaft does not
The problem is the belt drive between the motor shaft and the drive shaft to the trimmer end has slipped and melted the plastic gear on the drive shaft end of the belt. This is a fatal problem and requires replacement of the drive system inside of the motor housing. Cost wise, probably means you totaled the unit.
  • 313 Answers
SOURCE: re: GH1000 Trimmer - looks
there is one hidden screw under the label. fell with your hand the label where the screw located.
Posted on Jul 24, 2008
SOURCE: Take apart method to replace rubber drive belt.
I had the same dillema, till I discovered a soft spot on the label. They put one last screw there. I got the housing open and discovered the belt was broken. Ordered a new belt ($12.39) through ACE Hardware repair center, now I can't get the belt on. That is why I came to this site.
The Ace guy told me he has had lot of calls for this particular belt. If you order one, I suggest you order two.
Good luck.
Posted on May 15, 2009
SOURCE: Motor spins, shaft does not...
I'm in a similar situation with my GH1000, except that it was a part that comes with whole motor assembly. I could sell you the shaft assembly of my trimmer, or I'll buy your motor assembly. Yes?
Posted on Jul 26, 2009
dixxfixx
SOURCE: Motor is on but the spool does not turn.
Remove the hidden screw under the stick-on label.
Posted on Aug 07, 2009
SOURCE: Describe your Black & Decker
You have missed a screw about half way, there is one under a sticker.
Posted on Jul 25, 2010
Rigid table saw blade frozen
Well with only this info it could be a lot of or many failures to lock it down . First is it belt driven or direct shaft drive.if it is belt driven ,
(possible more not likely ) then unplug power supply .locate belt and follow to bearing journal and pulley on the blade end . pull from this end in the direction the teeth are facing(forward or fryont )
. Shouldn't take much effort.the idea is to roll any foreign object
clear , or free of smaller areas that would bind or jam any part of the drive train . While your there check belt
TIP: usually,almost any type of motor that has a belt for the drive train, has built in thermal overloads .. Like a fuse when it gets hot ,
the solder pot melts thus opening the circuit . They reset themselves In a time vs. Temperatures. Depending on the melt point of pot ( some in mins , some in hours ) . For yours it takes 15
mins or so to allow solder to cool and the link has made continuity thus closing the circuit. If belt slips around pully but motor shaft turns , something or some object has gotten between frame and drive ,or the bearings are seized up on the blade end . That's why we roll the belt at the blade end istead of turning shaft at motor end . The only other thing is if it's a direct shaft drive , you still will be looking for a jam piece , however possibly a locked rotor in side motor ,, meaning the out put (Armature ) shaft extending from motor to blade has seized up internally .Again check bearings if direct shaft .,,also more and more power tools are coming with a brake on them . As soon as the user has taken the power of
of tool the brake will engage and stop any rotating parts .
Best to Ya. A. Goodwin
Sep 15, 2016 | Saws
Stihl fs 55r head won't turn
Check drive shaft. Some models have a flexible cable drive shaft that is prone to breaking. also make sure the drive shaft is engaged in the clutch drum and in the gear head end.
Mar 25, 2013 | Stihl Garden
My bissell 6590 works fine with hose attachment. Motor shaft turns when belt and roller are off. When belt and roller are on it's noisy and smelly. Now one end of the roller actually melted in the holding...
replace the roller,belt and before instalation clean motor shaft where belt rolls. you can turn on the vacumm and using a knife scrape the motor shaft from the black dirt.
Feb 19, 2011 | Bissell 6590 CleanView Bagless Upright...
The trimmer head stopped turning What could be wrong
here is web site for parts
http://www.partstree.com/parts/?lc=husqvarna&mn=225+L+%281994-06%29
almost sounds like the driving drum engagement end has rounded off or the end of drive shaft broke off at either end , or the gear head end is broken / damaged
have a look at the splines on the output shaft on the gear head , check the plate that engages those splines too
physicaly take off the tube / shaft assy from power head and check drum and clutch rotating , check drive shaft end (s)
if ok refit tube / shaft assy ( make sure engaged properly)
tighten mount bolts - remove gear head from end of shaft, start motor and run see if shaft turns ok with some rev s if so
problem is in the gear head
check out website good site
cheers paul hope it helps
Aug 01, 2010 | Husqvarna Garden
Plastic shaft drive melted and belt snapped. can I get these parts?
No, they only sell the plastic pulley as part of the motor assembly, not separately. Currently $54.88, more than half the cost of a new trimmer. The belt says "call service center". I tossed mine and bought a cheaper model (NOT B&D!)
Jun 27, 2009 | Black & Decker 14" Grass Hog Xp...
The motor want turn the attachments i.e. string on the trimmer or blade on the edger
there is definitely a problem in the drive shaft. check to make sure there's nothing blocking the mal and female ends. if there is, clean it out and lubricate it so that the male will attach to the female slot. also check to see that both ends are not stripped. if the motor portion of it is stripped, which most liekly is out culprit, then it needs to be replaced, or you need to get a new trimmer. if you do, i recommend the Ryobi model CS26 gas trimmer.if the atachment shaft is stripped, the the attachment needs replacement. if you replace the motor portion you need not lubricate the attatchment slot. if the attachment is stripped, it needs to be replaced, but im quite sure the female end in the motor shaft is our problem. it could also be broken inside the shaft. make sure nothing falls out if you hold the attatching ends to the ground.
May 31, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Slipping belt onto motor shaft pulley
On most vacuums, you:
put the belt on the motor,
slip the beater bar thru the belt,
put the end opposite the belt into the frame,
stretch the belt and put the belt end of the beater bar into the frame.
Hope that helps!
Apr 25, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Head will not drive. Can feel it slip between nut and motor.
inside the shaft is a flexible drive cord, at each end is usually a hex or torx head fitting that slides into a sleeve, theese can sometimes strip or even snap off and need replaced. remove one end of the shaft (either the engine or the spool) and the cord should slide right out easily. inspect each end for stripping and to make sure it didn't snap off inside the sleeves.
Sep 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Vacuum smell
Your belt is slipping, it is probably stretched and slips trying to drive the brush roll. Take the bottom plate off, check the brush also, make sure the ends turn freely. The belt runs from the brush roll to the motor shaft. If you can't get to the motor shaft, then you will have to remove the top cover.
Mar 25, 2008 | Vacuums
I cant get the roller back in place
This guide should help.....
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Please rate it when you are done reading it if it was helpful. :0)
Marci
Oct 02, 2007 | Oreck XLS700A Upright Vacuum
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
327 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
