Question about Cuisinart DTC-975 Coffee Maker
Coffee maker (DTC-975) shuts off and beeps about 20 seconds
Coffee maker shuts off and beeps about 20 seconds after it has been turned on.
I checked continuity on the 120 volt heating circuit including the thermo switch . It had a complete circuit.
I also removed and bench checked the the Potter & Brumsfield relay. It is working properly.
I performed in circuit tests on most of the components on the main circuit board. Can not find any bad parts.
  • 2039 Answers
SOURCE: Metal Tasting Coffee
vinegar is not the best it remove calcium in little piece descaler produit melt go buy the descaler produit 1part descaler 1 part water put in water container start the machine after a few second turn it off leave it there for 15 minute repeat untill empty rinse very good after that product is corosif 2 or 3 full rinse thanks for using fixya pierre
Posted on Feb 12, 2008
SOURCE: i have had a cuisinart
I don't think you are putting the top on correctly. Make sure you thread it correctly - it is sort of fussy! I did that once and water went all over the place!
Posted on Apr 06, 2009
  • 85 Answers
SOURCE: Coffee maker doesn't turn on when you flip the switch.
Hello evc622,
This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. The may be an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it or shuts the unit down, but most people don't know about this fix. I hope this is helpful to you, evc. Positive feedback is appreciated. Good luck. NormanZ
Posted on Jul 09, 2009
stonephoenix
  • 563 Answers
SOURCE: My DCC1000 Cuisinart Coffee Maker shuts off.
Your unit needs to be repaired or replaced. Please call the manufacturer to determine your warranty status.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jul 22, 2009
VtToolMan
  • 704 Answers
SOURCE: Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
Posted on Nov 10, 2009
My coffee pot is black inside & using vinegar does not clean it
Use a coffee pot cleaner such as Dip-IT. Walmart sells a product in the coffee maker area that is for cleaning the coffee maker. It cleans the coffee pots too.
Feb 24, 2011 | Cuisinart DTC-975 Coffee Maker
DTC 975 Won't brew and beep comes on in about 1 minute. What is the problem/resolution?
I returned my first one because it was under warranty and now the new one is doing it too. I think that it clogs with scale very quickly and the vinegar and water cleaning does not work. It turns itself off and will not reset, even though we unplugged it overnight and then tried again (as was suggested by others). I am going to take it apart and see if I can fix it, because I might as well, since it is broken. If that doesn't work, I will just have to buy a new one, AND NOT A CUISINART!
Jan 30, 2011 | Cuisinart DTC-975 Coffee Maker
My Cuisinart DTC -975 coffemaker fails to pump water. I turn it on then after twoo minutes it beeps and then shut-off. Why is it doing this and is it fixable?
My Cuisinart Espresso Maker EM-200 won't pump the water in and then the manual, one cup, and two cup lights come one and they flash and beep. What am I doing wrong?
Nov 28, 2010 | Cuisinart DTC-975 Coffee Maker
DTC-975 overflowing pot caused LCD readout to malfunction
when you took the display apart did you wash it down with 90% isopropyl alchohol? do this and, then dry with a hairdryer
Aug 29, 2009 | Cuisinart DTC-975 Coffee Maker
WORKS GOOD
Run a mixture of 50% vinegar and 50% water through the unit, just like it was coffee. For the caraffe, let the vinegar sit in the caraffe for 20 minutes, and then scrub it out with a soft sponge.
-Tha Mp3 Doctor
Jan 12, 2009 | Cuisinart DTC-975 Coffee Maker
2nd time using this brand new machine and it won't brew.
try unplugging the unit for 1 1/2 hours to reset the electronics...I just called them and that was their advice...we shall see..worth a try
Aug 09, 2007 | Cuisinart DTC-975 Coffee Maker
Cuisinart DTC-975 Coffee Maker Logo
133 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
