Question about Dell Dimension 4700 PC Desktop
I have a dell 4700c desktop with a amber light that wont start up
  • 6 more comments
  • schweikertk Aug 01, 2009
    hello
    the light flashes amber and the fans slightly start up than stop
    and it does not power up at all
    4yaers
    is the power supply just a new cord or a replacment part or a new power surge box?
    thanks i will give it a try thank you
    kcs
    thanks for the link
    very helpful
  • Dell Master
  • 13,433 Answers
Do the fans spin? do you mean it does not power on at all? do the leds blink or light when you try to turn on the machine?
Posted on Aug 01, 2009
  • 3 more comments
  • Ekse Aug 01, 2009
    HELLO?
  • Ekse Aug 01, 2009
    It sounds like a bad powersupply. how old is the machine?
  • Ekse Aug 01, 2009
    Yes it could very likely be the powersupply, I would open up the side panel of the machine and get the dust out, disconnect the powersupply from the mainboard for a while. Plug it back in and try starting up.
    always unplug the machine before working inside.
    If you have another powersupply around I would test the machine with another powersupply.
    I think this is a normal ATX powersupply, which will cost around 20 to 40 usd.
    check on www.newegg.com
    ATX powersupply 300 - 500W will do fine for you, depending on what kind of powersupply is installed now. the W reads on the Side.
  • Ekse Aug 01, 2009
    See here.
    http://www.newegg.com/Product/ProductLis...
    Its inside the computer, it converts the power from your house to power that your computer can use.
  • Ekse Aug 01, 2009
    Let me know if you need further assitance.
Standby light on my dimension is blinking amber and will not boot up. Nothing will run. Any ideas as to what may be wrong. I'm thinking either a power supply or possibly a HD failure.
Definitely not a hard drive problem. It would boot, but not go to windows. This is one of two things. Power supply failure (most likely), or one of the RAM sticks went bad. I would try testing the RAM by taking one out, and trying to turn it on. Do this with both, or all four (depending on how many you have). If it still doesn't work, I would think that the Power Supply is the issue.
Dell has a set of codes that would tell you what the exact error would be based on the blinks of the amber light. If you find the pattern, you can look that up. In my professional experience it's normally the power supply.
Please Rate. Thanks.
Apr 03, 2011 | Dell Dimension 4700C PC Desktop
POWER LIGHT BLINKS BUT PC never comes on. amber color
check your power supply. A flashing amber power button usually means its gone bad
Dec 09, 2010 | Dell Dimension 4700C PC Desktop
Hi my pc dell 4700c does not power up. Yello light
Most indicative that the power supply may have failed and needs replacement.
Hope this helps.
Andrew
Don't forget to vote
Apr 09, 2010 | Dell Dimension 4700C PC Desktop
Dell 4700c will not power on white light on motherboard
Is there any chance for you to check if the power supply blows air from inside of the power supply? If yes, on your motherboard, do disconnect the P1 cable or the main power supply cable that connects to the motherboard and the P2 cable which. and try to plug the power cord of the power supply and if the fan did not spin, power supply is the one causing the problem
You may also try to remove the RAM or memory card module from the motherboard and all of the PCI card connected to the motherboard. Try to turn on the system and check the power supply fan and the CPU fan if it will spin. If not then I recommend you to replace the power supply.
On the other hand, if the fan is spinning on the power supply after you remove all the RAM and PCI cards. And the power button light is flashing amber or solid amber color. Try to install RAM 1 by 1 to isolate the problem.
Let me know if the problem persist
I
Sep 23, 2009 | Dell Dimension 4700C PC Desktop
Amber light flashing, computer wont start up.
I have a dell 4700C and the amber light flashing, computer wont start up.
Aug 01, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Solid Amber light when starting the Inspiron 530 . Every time i start the Dell inspiron 530, the solid amber light comes on and it dont start. As per Dell user manual i have tried everything but of no use....
Amber led simplifies a start-up-error. This could be a number of things.
For example:
Check if HDD is connected properly
Check if RAM is connected properly / also if this is damaged your pc wont start.
Check your m/board for any loose capacitors an if they are not popped at the top.
Your LCD screen is properly plugged in to the m/board and if the cables aren't damaged they are very thin and fragile.
also could be the power supply...
Goodluck
Ryno Gerber
Jul 30, 2009 | Dell Inspiron 530 Desktop Computer
Dell dimension 8100 diagnostic lights
please refer to the below link...being dell support technician myself this link would give you the best possible help
http://support.dell.com/support/edocs/systems/dsleest/codemess.htm#diagnostic_codes
Oct 18, 2008 | Dell Dimension 3000® Pentium® 4...
Dell 4700C randomly goes into "sleep mode" and doesn't wake up.
Honestly, my first suggestion would have been to upgrade your memory. If you go into control panel and check your power settings (I'm assuming you're on windows XP) Do you have all of you options set to "Never"? You may also want to check your BIOS settings to see how your sleep/hibernate is set up. Aside from that, you'd have to run some hardware diagnostics to give a better idea of what to look for. Hope this helps!
May 08, 2008 | Dell Dimension 4700C PC Desktop
Power light flashing
not understanding your question ..need more info .. is the computer not booting ? Is it flashing red, green, orange? need more info
Mar 08, 2008 | Computers & Internet
Dell Dimension 4700 PC Desktop Logo
93 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
