Question about Apple TV MB189LL/A 160GB RTL 160 GB USB 2.0 Hard Drive
I bought a used Apple tv. The usb port does not work. Genius told me it is "burnt". any suggestions?
    Problem Solver:
  • 12 Answers
If it is just the USB port, and you have some soldering skills, you may be able to replace the port itself. The port should have a part # on it that you can then search for using Google. If it is more than the USB port, unfortunately you may be looking at a logic board replacement.
Hope this helps!
TechRestore http://techrestore.com
Posted on Oct 03, 2009
How can I watch my digital photos on the TV? Where do i have to go to on the menu?THX
If you connected via USB you'll have to change your TV's input to the USB port where you have a flash stick or hard drive connect. Normally this would be done by pressing the SOURCE or INPUT button on your remote. Since I don't know what your TV is that is the best answer I can give you. With most modern smart tv's you can also sync your TV to your phone either by WiFi or Bluetooth. In this case you might need to enable, turn on, that feature in your TV's system Menu.
I hope that helps...
Mar 03, 2015 | Televison & Video
My Genius Traveler 6000x wireless mouse suddenly stopped working
Double check the batteries, although the lights work and the computer sees it, the voltage could drop low enough to stop the sensors.
next, try another USB device in that plug. USB port can go bad.
If the port works, it could be the wireless USB connector starting to fail, if they are bumped to hard sideways it can cause loose connections internally.
then, you might just need to update drivers. Computer update s can conflict with drivers cause devices toss top working.
May 20, 2014 | Genius "Wireless Mouse - Traveler 6000X,...
How to trun on genius
How to Turn on Genius
The iTunes Genius feature suggests and recommends new music, movies, and television shows based on your device's music library and playlists. The Genius feature can automatically create new playlists for the user to enjoy and will do so based on the different genres and styles of media already present in the library. Using Genius, you can discover new music that's interesting to you.
Instructions
1Open iTunes on your computer.
2Click the "Store" menu link then click "Turn on Genius."
3Click the "Genius" entry in the iTunes sidebar to the left then click "Turn on Genius."
4Select a song in your iTunes music library and click the Genius icon located at the bottom of iTunes. The icon is represented by an atom.
f you are using iTunes for the first time, you will see Genius listed on the left side of the iTunes window above Playlists. Click Genius and then click Turn On Genius to start using Genius. You can also start Genius by choosing Turn On Genius from the Store menu in iTunes, or by selecting a song from your library and pressing the Genius button at the bottom of the iTunes window.
When starting Genius, you'll be asked to sign in with your Apple ID or create a new one and agree to the terms and conditions.* iTunes will then proceed to gather information about the contents of your library, send this information to Apple, and download Genius results. The time to complete this process will vary depending on the size of library information and the amount of traffic on the iTunes Store. At any time during this process you can use iTunes to play music or other content.
To turn off Genius, simply choose Store > Turn Off Genius in iTunes.
Jan 03, 2012 | Apple iPod mini 2nd generation MP3 Player
Problem installing a genius VideoCam Messenger
Try restarting the computer with the device unplugged, and then when you are in Windows and everything has loaded, plug your Web Cam into a "different" USB port than you originally had it plugged into.
Now the drivers should install your device.
Jan 26, 2010 | Genius VideoCAM Messenger Webcam
I just bought a netscroll optical mouse,but the
Yes you can get a ps2 connector to usb. They sell them at Radioshack and some Walmarts. What computer are you using the brand and model? The ps2 connector should fit into the one on the tower, unless its a really old computer.
Jan 15, 2010 | Genius Mouse Netscroll 110 High-Precision...
Laser doesnt work
Check the mouse cord and make sure that it is properly connected to the PS2 port of you computer. Turn off your computer, wait for a few seconds and then power it on. If it failed to function properly, contact the store where you bought it about the problem. The device is cover by its' warranty and they may replace it if found defected.
Hope this could help you..:-) Thanks..
Dec 27, 2009 | Genius Mouse, OEM Net Scroll PS2...
My ipod won't charge. keeps saying "please wait. very low battery" what's wrong with it?
I had the same problem. Went to the Apple store and the technician said that the IPOD battery ran down to low (battery level showed red) and the USB port on the computer was not strong enough to recharge it. He used a rechargeable adapter that pluged directly into the wall (adapter cost about $30) and recharged it enough for me to take it home and recharge it on my computer.He said to never let the battery level drop below 5% unless you are going to recharge it using the adapter that pluged into the wall. I bought an IPOD rechargeable travel kit from Target for $20 and used it to recharge my IPOD. My IPOD works fine now. The Technician also said at some point the battery will need to be replaced (in a year or two depends). Will cost about $59 to replace it (don't quote me on the timeframe or price of replacement, this may have been just for my IPOD but thought this would be useful info for someone.
Nov 24, 2009 | Apple iPod MA446LL/A MP3 Player
I pod nano not reconized by laptop with vista usb device not reconized code 10 appears
Which USB ports are you using? I just had this issue on a customer's computer and it turns out that a 5 port USB 2.0 hub they had installed in the pc wasn't functioning properly and so I would get a code 10 on their iPod nano. I plugged it into the onboard USB 1.0 ports and it installed correctly and synched. I would suggest trying other USB ports. If that doesn't work then go to Programs and Features in Control Panel and uninstall all apple products and then reboot and reinstall iTunes.
Oct 15, 2009 | Apple iPod nano 4th Generation
Vista driver for Intel camers
You need a USB video class driver to use in vista. this link says it's for a genius webcam but the driver is a generic one for vista-supported usb cameras(amongst others devices), so it should work for you.
http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/GENIUS/Genius-Eye-320-webcam-Vista-driver-10.shtml
happy snapping and filming,
chris
ziraffa@hotmail.com
Sep 13, 2008 | Intel Create And Share Camera Pack Webcam
Apple TV MB189LL/A 160GB RTL 160 GB USB 2.0 Hard Drive Logo
261 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
