Question about Garden
Wanted manual for gutbrod 1016 . What oil goes in the axle/gearbox
    New Friend:
You can get operator handbooks, parts lists and workshop manuals for most classic Gutbrod tractors (pre-1995 models) including 1016 from www.gutbrod.co
See you there.
Posted on Mar 13, 2013
    Champion:
  • 363 Answers
Usually 90 weight
Posted on Aug 02, 2009
Had a loud noise in the front ofmy 96 blazer 4x4 when I parked it the next day mycarport was covered in oil think it came from the trancefer case where thr axle goes in
transfer case seals blown
even axle seals or gearbox seals
wont know till you look underneath
transfer case may be ok if not run without oil
Oct 27, 2016 | 1996 Chevrolet Blazer
Tip
How to change (check) AUDI transmission oil
Transmision oil for Audi A4 (1.8, 1.8T, 1.9 TDI):
Manual gearbox (5 speed):
- Capacity = 2,25 liters
- Specification: Gear oil SAE 75 W 90 (synthetic oil)
Part number G 052 145 S2 (1 liter)
- To check oil level, unscrew oil filler plug placed on the left side of the gearbox in front and near of transmission axle, using an Allen 17 mm key.
- Check oil level with locally manufactured tool, e.g. a piece of angled wire.
- Specification: oil level 7 mm below bottom edge of oil filler hole.
- Install oil filler plug, tightening torque = 25 Nm.
on Dec 19, 2009 | Audi A4 Cars & Trucks
Pronto M51. Why is it leaking oil?
hi James ,this is a power-chair right ? if so then the oil must be coming from one of the gearboxes, if possible run your finger inside the wheel where the axle goes into the gearbox ?
Regards
Rob
Feb 02, 2016 | Invacare Health & Beauty
Refill manual gearbox with what oil?
gearbox oil grade SX75W/90 make is upto you
Mar 28, 2014 | 1999 Kia Sportage
Renault Scenic 2000/2002,
It will be the axle seal. The LHS axle will have to be removed.
The old seal can be dug out and a new one driven in. Pretty good project.
Jun 26, 2013 | Cars & Trucks
What gear oil goes in manual transmission 91 Toyota pu 22re. cabanaboy68@msn.com
There are two types of gear oil per say in a car/truck. Did you mean the engine oil or oil for the axle? Either way the engine oil is in the manual for the car, and for an axle you want at least an 80-90w oil.
hope this helps.
Dec 23, 2010 | 1991 Toyota Pickup
What kind of transmission oil carries the manual aidi a4 2000
The transmission oil type for Audi A4 MY 2000 with manual gearbox is:
Synthetic oil SAE 75 W 90, part number G 052 145 S2 (1 liter).
Example:
Castrol Syntrax 75W-90 Full synthetic SAE 75W/90, API GL5. manual transmission, transaxle and rear axle lubricant with outstanding extreme pressure, synchroniser and high temperature performance.
Oct 16, 2010 | Audi A4 Cars & Trucks
While removing the CV from the car there was a lot of Oil coming out of it. would that be normal. it smelt like motor oil and looked it as well.
you must have pulled the whole axle out.finish what you started to do,then put axle back in,make sure circlip is clicked in,then refill g/box/diff to correct level.
Jul 06, 2010 | 1997 Mazda MPV
Iveco servicing
hi the axle is one of the few things that don,t fall apart on these vans but gearbox oils axless etc like engine oils need replacing regular if you want them to last i would change it every 50000 mile yates210456
Oct 13, 2008 | 2007 Ford F
Garden Logo
359 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
