Hi, I have 2 Toshiba compressors (PH170X & PH160X), New, for air conditioners. Can they be used to pump air? Does this cause any problems? Do they need to be filled with oil, and if so how much? They have 3 electrical connections on top marked S / R & C. I believe R is for Red - Active, what do the other letters stand for? I would appreciate any assistance. Regads Helmut.
  • 69 Answers
No they will not pump air. the oil in the compressor circulates in the freon, the freon also cools the compressor. these run on 230 volts c-common r-run, and s- start from a capacitor. Sell them to a dealer
Posted on Aug 04, 2009
What would be the top 2 reasons 1 of the outside 20 amp fuses would blow?
There are only two possible things that it could be. The compressor or the fan motor. The compressor is self contained and cannot be serviced. You just replace the whole thing. The fan motor can be replaced.
Jul 11, 2013 | Heating & Cooling
Air conit/2002 buick rendezvous
was system evacuate by pumping it down using vacuum pump to remove all moisture out of the system.most time of the time when i work on AC system you have pump it down from 30 minutes to a hour.pump it until low pressure gauge read 30 hgs in the green area.i shut down vacuum pump close off manifold gauge valves see if low pressure side reading stay at 30 hgs or drop if gauge needle stop dropping have leak in the AC system.if all is good you have temperature air door problems.air door not opening all cool air to circulate through AC vents.
Jun 21, 2013 | Cars & Trucks
AC (57915.622) fan hi & low working, compressor
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 14, 2011 | Heating & Cooling
How to determine evaporator icing problem of air conditioning units
Due to :
1.. Evaparator coil dust blocked. 2. Air filter blocked. 3. Less rpm of fan motor. 4. Short of gas. 5.Filter drier chocked 6. Compressor less pumping.
To rectify:
1 & 2.Clean air filter and evaporator. 3. Replace fan capacitor. 4.Check for gas leak and recharge. 5. Replace new filter drier, vacumize and gas charge.
Dec 16, 2010 | Heating & Cooling
My 3-year old LG air-conditioner was leaking water. So i called some 'experts' to come fix it. This is the first time I called for maintenance service on the air conditioner. The 'experts' dismantled some...
White snow.. I had this issue when 2 inside unit electrical lines were hooked up backwards at the compressor. The compressor would pump too often and overcool the inside unit, because it was using the wrong temperature sensor. But you could have a different issue. I'd have them recheck your freon levels, that can cause it to cool too much - should be 120-135psi when it is running, after 5-10 minutes or so. They adjust this for the outside temperature though.
Oct 04, 2010 | LG LS-L1210CL Mini Split Air Conditioner
My frigidaire air conditioner model FAA060p7a will not cool the fan works fine but on cool the compressor does not kick on, if I turn the the temp knob you can hear it click behind the knob like its...
The problem here is the compressor.... it has failed and will not start. You can try to replace the capacitor and see if it will go but most likely the compressor is toast. I t will cost more to replace it then to buy a new unit.
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 25, 2010 | Frigidaire FAA060P7A Air Conditioner
AC compressor won't start
hi,you might need a new compressor...you will need need to go back were you bought capacitor...buy a hard start capacitor too..this might crank the compressor...hope this helps.if you buy it..call an ill tell you how to wire it...if it dont ,you need new compressor...call michael..doctor airr..appl.repair...843-384-8474...
Mar 27, 2010 | Dometic Rooftop RV Air Conditioner
During low voltage period window AC compressor shudders and kicks off, but fan runs, when voltage returns normal compressor runs.
low voltage issues causes higher amp draw and equipment to run a lot harder. whats causing the low voltage problem to the equipment? high amp draw of the compressor could be causing it to overheat and trip until the compressor physically cools down.
May 27, 2009 | Dometic Rooftop RV Air Conditioner
Compressor
get a second opinion from a different company
Sep 03, 2008 | Goodman CKL60AR60 Air Conditioner
Window Air conditioner pulls too many amps
Probably Seems Replace Running Capacitor Located in Component Box or Nearby Compressor
Jun 23, 2008 | Whirlpool ACQ108XL Air Conditioner
Heating & Cooling Logo
75 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
