Question about Sharp Office Equipment & Supplies
Copier seems to be worked, but the outcome is blank copies. It is after I swept dirty small part.
  • wallan May 11, 2010
    What model of Sharp copier? There may be a color coded part that needs to be pushed in all the way. ( Corona unit)
  • Sharp Master
  • 1,294 Answers
The problem is in a high voltage part.Check and clean your transfer and separator corona unit(wires,holders).
Posted on Aug 02, 2009
Dirty copy result even if i replace a new drum
There are small wires that charge the drum to transfer image. Not sure if they are in drum unit or not on this machine. If the transfer chargers are dirty they will cause a dirty or voided copy. Make sure document glass is clean. Unplug machine check for these small wires if dirty gently clean with cotton swab or soft towel. Hope this helps
Mar 02, 2014 | Kyocera FS-1135MFP Copier require feeder
Dirty copies on Canon PC1060
First replace drum cartridge
Nov 04, 2009 | Canon PC1061 Copier
Printer leaves white vertical lines on document
I dont know what kind of copier you have but white vertical lines are virtually always caused by a dirty charge corona.There is usually a little plastic handle, blue, green or grey, that cleans the charge corona.pull it out ONCE, push it back in and try another copy.If you have an operators manual, it should have instructions for cleaning the charge corona.Good Luck, O'scope
Mar 27, 2009 | HP Office Equipment & Supplies
XEROX CopyCentre C20-Blank stripe going down side
Open the cover and put a piece of paper on only half the glass, and make a copy. BLOCK the left side of the glass with the blank paper.
See where it is blank. Most of the times that is a dirty or haved up mirror in the scan head. One of the small mirrors in the black assembly under the lamp. When a digital copier scanner optics become dirty, the image in that area becomes very light .
Mar 18, 2009 | Xerox CopyCentre C20 Black and White...
Blank copy
this problem will only occur if the main charge is not working.
it will almost certainly be the whole main charge assembly but maybe the high voltage transformer (but that would be very uncommon)
please rate if this fixes your problem
Mar 15, 2009 | Copystar Office Equipment & Supplies
WHEN I TRY AND MAKE COPIES THE COPY COMES OUT BLANK
Try checking the basics: Toner, lamp, and the other components, see if there is a jam.
Jan 06, 2009 | Canon imageCLASS D880 All-In-One Laser...
The printer is connected correctly, the printer goes through the motion of printing, but the pages come out blank. What is the problem? I use new ink cartgages and old ones, they both produce the same...
Try to take a xerox or photo copy form the printer and if it come ok than it is simple driver problem so uninstall drivers from the add & remove program and than try to install it again.
Dec 04, 2008 | Lexmark X1240 All-In-One InkJet Printer
Sends blank fax
Dirty scan glass
Clean slit of glass extremly well, it is a small slit rectangler section of glass before copy glass on the scanner.
Glue, Liquid paper are common finds on the glass in this area, While you have the lid up, clean white reference area (on lid directly on top of scan glass when lid is closed)
Feb 04, 2008 | Brother MFC-8440 All-In-One Laser Printer
18 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
