SOURCE: what does the orange light blinking on the computer mean?
It generally means that you have an empty, damaged, or incorrect ink cartridge installed.
SOURCE: toshiba theatrewide hdtv blinks 3 green and orange then 2 orange and orange lights
You need to first look from the side(left) and or back to see if lamp comes on even for a few seconds.
Average life span for the model indicated (52hm84) is 2,000 hours or 2 years.
The lamp is the place to start and it is customer replaceable so if you remove it and find it damaged (shattered inside) you know what your problem is.
Let me know what you have tried.
SOURCE: toshiba lcd # 42hli67 blimks orange light and wont turn on
Thats usually caused by the power supply having bad capacitors. It could be the power board itself that needs replacement if the caps all look good with no swelling.. If you need a power board you can get one from www.tvrepairworld.com
SOURCE: Toshiba L655s5065RD wont start , only sign of life is blinking orange light
Okay, what does that light indicate? (hard drive activity, power plugged in, battery, etc). It most likely indicates a faulty power supply or damaged battery unit.
