Question about Mamiya RB67 Pro SD Medium Format Camera
Mamiya RB67 ProS wont trigger or advance
Hi there-
My havent used my RB67 ProS in 2yrs,I took it out to use today & it wont fire. The film advance lever on the right side is stuck in the up position & the silver trigger button is loose-slides in & out. Its seemes jammed. Hows this possible? Help!!
  • Anonymous Feb 07, 2009
    winder is jammed
  • 667 Answers
Start by making sure the dark slide is removed, the camera will not fire with it in place. The next step is to check the rotating back to make sure it is locked in either the vertical or horizontal position. Without film in the magazine, the multi-exp lever on the back must be set to show the red dot under the advance lever. You can check the camera without the back by removing the rotating back using the latch on the bottom of the camera
Posted on Dec 23, 2007
Minolta 700 film advance lever was working, then it wouldnt wind, now it is stuck.
Use or buy a brand new battery from store that sell lot of them.
Do not get from store that only has a few, meaning they have been sitting there for years.
atdlee@netzero.com
Feb 14, 2014 | Minolta X-700 35mm SLR Camera
Mamiya RB67 Pro S: film counter does not advance, but the film does advance purchase another back same problem. Is there a switch that I'm missing??
If the problem is on the magazine's counter and if the spacing of frames is correct then the counter dial is loose. two screws on the outside front of the top of magazine, two screws in the film chamber hold the top cover. remove leather cover on winding lever loosen screw and remove. you can then remove the complete top housing to expose the counter mechanism.
Oct 30, 2013 | Mamiya Rb67 Pro S Medium Format Camera-...
My advance lever is stuck o my Ricoh camera. I had a roll of film get stripped in it and took it out in the dark room and developed it but now even with no film in it the lever won't advance. I've looked...
Your camera is in cocked position with shutter fully cocked and that is why you cannot advance the film advance lever. Set the shutter to x position ( on your shutter speed dial on the right hand side and top of your camera ) . The shutter should release and then you should be able to advance the film advance lever.
Oct 18, 2013 | Ricoh KR-30SP 35mm SLR Camera
Film-advance warning won't go away on a RB67 Pro SD 120 film back?
Mamiya RB67 Pro SD that is new to me. loaded the film correctly took the first shot. But, the film won't advance. What am I doing wrong?
Feb 18, 2012 | Mamiya RB67 Pro SD Medium Format Camera
I need repair manuals for MAMIYA RB 6x7 ProS: Lenses & Body. Where are they available?
http://stores.ebay.com/photobooksonline/Service-Repair-Manuals-/_i.html?_nkw=Mamiya+rb&submit=Search&LH_TitleDesc=1&_fsub=6&_sid=98011905
May 31, 2010 | Mamiya RB67 Pro SD Medium Format Camera
I installed a Mamiya lens on my RB 67 Pro S. I cocked the shutter and fired it. Now I can't recock shutter and I can't get the lens off. The lens blades are closed.
Hi RMT, I sueest you only one thing. Please visit the service center. Beoause you already cocked the shutter & make it fired. So please follow the link its really very helpful for you.
LINK
Thanks & waiting for your feedback.
Feb 17, 2010 | Mamiya RB67 Pro SD Medium Format Camera
Mamiya 645 AF back won't advance film.
The battery in the film back is only used to supply power when the back is off the camera, when it is on the body power is supplied by the six batteries in the body so try them and also make sure the film insert is properly seated.
Feb 07, 2010 | Mamiya 645AF Medium Format Camera
Pro-S film back doesn't advance film properly.
There is good chance that the back needs a spring replaced. I've seen them fail many times.
Nov 14, 2009 | Mamiya RB67 Pro SD Medium Format Camera
My Mamiya RB67 triggers and shutter lease lever works but film advance lever doesn't move. Trigger button fired several times but film advance still showing 1.
This is not the best solution as it indicates a faulty film back. The film should advance without resorting to activating the film-wind release lever. That is only for intentionally advancing a partially exposed roll of film. Make sure the multi-exposure lever is not engaged and that the counter does advance and the red mark disappears as you advance to an unexposed frame.
Nov 09, 2009 | Mamiya RB67 Pro SD Medium Format Camera
Shutter will not trigger when film back is attached, only when it is off
Did you made sure the dark slide was removed? Check to see that the firing pins on the camera back are coming through the revolving bracket okay and that they are engaging the pin on the film back (left side). Is there film loaded? You can check without film if you have the multi-exposure lever engaged (red spot visible) and dark slide pulled out.
Nov 06, 2009 | Mamiya RB67 Pro SD Medium Format Camera
Mamiya RB67 Pro SD Medium Format Camera Logo
745 people viewed this question
Top Mamiya Photography Experts
Tony
Parshiv Luthra
Are you a Mamiya Photography Expert? Answer questions, earn points and help others
