1. Clogged drain line or water pump Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Fisher and Paykel WA37T26G Top
I noticed a little water at the bottom of my washing machine after a load was done. Can anyone...
(More)
I noticed a little water at the bottom of my washing machine after a load was done. Can anyone explain why that could be ?
I have a whirlpool washer and it wont stop filling with water. It fills to start the wash cycle and...
(More)
I have a whirlpool washer and it wont stop filling with water. It fills to start the wash cycle and as it starts to wash it continues to fill, to continue to over fill and floods the floor!
I have a Fisher Paykel Model MKT GWL 15 US Product #96200-A. I read the other solution for this...
(More)
I have a Fisher Paykel Model MKT GWL 15 US Product #96200-A. I read the other solution for this type of problem and it doesnt seem to apply to my problem so Im going to post whats happening with mine and hope for the best. Ive run it through an entire cycle empty with the door open so I can see what is happening. During the final spin water doesnt come from the sprayers directly in the center of the washer into the tub but from another hose that is off to the right (if your facing the washer) in the upper right corner of the inside. it doesnt put water into the tub but seems to put it on the edge of the tub and maybe run down between tub walls inside? It doesnt come out the bottom immediatly but when the tub spins the water is hitting the side of the tub and splashes water all over the lid (or me when I had the lid open) and then water also starts coming out from under the washer.it gets worse the faster the tub spins. I thought it might be coming from water hitting the lid but it does this even when I have the lid open. I checked the drain hose and everything there seems fine, full stream while draining before spin and all the way through the wash and it drains a little during final spinning. . I hope I decribed this well enough, I love my washer I just wanna fix it!
Where is the hot water wash? Hot water starts up, but cold water over rides the hot resulting in a...
(More)
Where is the hot water wash? Hot water starts up, but cold water over rides the hot resulting in a cold wash. We want a hot water wash. So far the sales people and techs haven't been much help.
