Question about Intel Computers & Internet
How do I configure my intel I power 9100 to charge agm house batteries?
2 Suggested Answers
SOURCE:
  • 248 Answers
SOURCE: What is the better battery....Gel cell or AGM?
Gel Cell is always better
Posted on Jul 22, 2014
Testimonial: "Thanks for the quick response!!"
VETERANS HOME JUST GAVE ME A USED QUANTUM WHEELCHAIR AND PRIDE MOBILITY CHARGER. HAS AGM BATTERIES. CHARGER MODEL EA11488 SAY LEAD ACID BATTERIES ONLY ????
AGM batteries( absorbant glass mat ) batteries have a different charge rate to ordinary lead acid batteries
it is all abiut the charging rate or charging volts so the charger you have may not be suitable for the AGM batteries in the chair
the difference in the lead acid battery and the AGM battery is the construction
Lead acid batteries will spill acid if tipped over where as a AGM the acid is absorbed in the glass mat or is an acid gel
to get a read of what it is all about go www.batteryuniversity.com and you will see what I am refering to
next best thing is to ring your local battery shop and ask then what charger you should be using for AGM batteries and if a normal lead acid battery is suitable for the job
Jan 24, 2017 | Pride Health & Beauty
What does the 12volt AGM button mean on 80amp battery charger by Schumacher
For charging AGM batteries.
AGM (Absorbed glass mat)[edit] AGM batteries differ from flooded lead acid batteries in that the electrolyte is held in the glass mats, as opposed to freely flooding the plates. Very thin glass fibers are woven into a mat to increase surface area enough to hold sufficient electrolyte on the cells for their lifetime.
What are the advantages and disadvantages of Gel, AGM, and Flooded / Wet Lead Acid Deep Cycle Batteries?
Generally, gel and AGM batteries have about 20% less capacity, cost about two times more, and have a shorter cycle life than comparable flooded lead acid batteries. However, Gel and AGM batteries do not need watering, are safer (no acid spilling out), can be placed in a variety of positions, have a slower self-discharge characteristic and are more efficient in charging and discharging than flooded batteries. Gel batteries are more suitable for deep cycling applications whereas AGM batteries are more for light cycling and some engine-starting applications.
Jan 01, 2016 | Jensen Schumacher Sc-600a Speedcharge High...
What size of Battery do I buy for a 2005 883 Sportster? Mine is 6 years old and DEAD DEAD ! I am a woman &* it looks pretty easy to change out just want to know what size I need to buy & Ain't...
Actually, if you're talking about Harley's AGM battery, it's a very high quality battery and is competitively priced compared to any other AGM Batteries. An AGM battery will last you about five years as long as you keep it charged. You can get a sealed lead acid battery cheaper. However, you really don't need to know the size of the battery. Just take it out of the bike and take it with you. If you're here in the U.S., you usually have to turn in a "core", part of the EPA thing. They'll just match size of your battery and which side the terminals are on and sell it to you.
Good Luck
Steve
Feb 19, 2011 | 2005 Harley Davidson XL 883C Sportster...
We put a new battery in and it will only stay on if plugged in
The battery may not be fully charged. Check the Control Panel, Hardware - Power Options. Check the battery level. If the battery is not listed, the charge circuit of the laptop may be bad.
Oct 31, 2010 | Dell Inspiron 9100 Notebook
Solo 9100 battery
Well, 8 years is an excellent life for any laptop battery. Being that old it will either be a nicad or nimh battery, both of which suffer from battery memory. There is very little you can do. Sometimes, charging the battery as much as possible, REMOVE IT FROM THE LAPTOP, put it into a plastic bag, seal it against moisture, and then put it into a freezer for 12 hours. Replace it into the laptop, charge it again, repeat twice more. If the battery has a bit of life in it you may be able to reclain SOME of it's capacity back. This is a last ditch effort, and should be carried out as a last option. That leaves either buying a new battery, this eBay link will take you to one
http://cgi.ebay.co.uk/NEW-Laptop-Battery-for-Gateway-Solo-2300-2500-9100-9150_W0QQitemZ230370600615QQcmdZViewItemQQptZLaptop_Batteries?hash=item35a32866a7
It's probably time to replace the whole laptop though.
Hope this helps
Jan 03, 2010 | Gateway Solo 9100/9150 Series Laptop...
My dell inspiron 9100 will no longer charge. it was working fine last week. i unplug it and it discharges like normal but when i plug in the cord it says its charging but will not go above the percentage...
Depending on how old the laptop is, the battery may need to be replaced. Since it charges, I would not suspect the power cord, so indications may lead you to requiring a new battery.
Good luck
-Carlos:
Dec 16, 2009 | Dell Inspiron 9100 Notebook
Not charging above 60% in the indicator
You might need to replace the battery. sometimes they get overcharged, or switch to battery power if the outlet they are plugged into has a dramatic voltage drop. so that could put a little wear on your battery. you should configure it so to meet the electricity usage for your house.
Oct 24, 2009 | Computers & Internet
Inspiron9100 charges the battery, but does not run off it
you've got a dead cell in the battery pack. Replace the cell (there're howto's dotted around the web) or replace the battery pack.
Jul 21, 2009 | Dell Inspiron 9100 Notebook
No light in the battery indicator when i charge
it must be that the notebook is running on battery or ur battery is fully charged
Thanks for using Fixya
May 06, 2009 | Dell Inspiron 9100 Notebook
Computers & Internet Logo
53 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Joe Negus
Joe Negus
Thomas F. Schneider
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
