Question about Frigidaire Refrigerators
I have a Frigidaire Gallary series top freezer style. The freezer is frosting up and the refriderator is not getting cold. The fan behind the freezer was making noise I'm told the other day. The freezer is frosting up in the back section.
  • ddseidel01 Aug 01, 2009
    How do you clean the coils. I assume with a vacuum? I n the back do you have to remove the panel?
  • ddseidel01 Aug 02, 2009
    My refrigerator fan was making noise. Now it is not. The freezer is frosting up in the back and the refrige is not getting cold. Any suggestions?
    President:
  • 1,136 Answers
Hi, Unplug the refrigerator. The automatic defrost is not working properly. You will need to remove the rear panel inside the freezer section and test the defrost heater and bi-metal switch. The bi-metal switch located on the top of the evaporator coil needs to be tested while it is still cold. Check and see if the switch has continuity. If the bi-metal switch shows an open circuit, replace it. If it shows a closed circuit, test the defrost heater the same way. If both the defrost heater and the bi-metal switch are ok, the defrost timer will need changed.
You will need to defrost the evaporator coils with a hair dryer. Please let me know if this helps you at all or if I can assist you further.
Thanks
Vic
Posted on Aug 02, 2009
  • Victor
    Victor Aug 02, 2009
    Hi, I just need to add one thing, because there was a noise, make sure the evaporator fan motor is running. If it has stopped turning and there is no frost blocking the fan blade, the fan might be the cause of the frost as well. You can test the fan motor to see if it is getting 120V. If there is voltage t the fan motor but, the fan isn't turning, replace the fan motor.
    Sorry, I should of mentioned this in my first post.
    Vic
  • Victor
    Victor Aug 08, 2009
    Hi, Can you please let me know if any of my responses helped you at all or if I can assist you further?
    Thanks
    Vic
    President:
  • 1,723 Answers
Have you cleaned the coils underneath (or back)? Is the condensor fan running?
Posted on Aug 01, 2009
Where is the defrost heating element
Freezer side at the bottom and maybe middle of evap coil. Need to remove screws to access
Jan 20, 2013 | GE J Series 18.2 cu. ft. Top Freezer...
My fridiaire refrigerator and freezer model # frt21lr7ab6 the freezer works fine but refriderator will not get cold.
check if you see any ice or frost on the back wall of the freezer that might block the air circelation to the fridge
Sep 02, 2011 | Frigidaire Refrigerators
Hotpoint (GE)CTX18GJB not cold enough. Just had serviced - tech replaced defrost timer and defrost terminator. The top located freezer gets cold and can hear the fan running - but still not cold enough...
I agree with the tech. if the refriderator isn't frosting it isn't working,their is only 1fan and its in the freezer,The tech could have missed some frost build up that is blocking the air flow into the fresh food section,if he removed all the frost it could take up to 24 hours to get cold ,it should slowly geta bit colder throughout the day,if by tomorrow its still not working have the tech come back and check for frost build up on the vents for air flow into fresh food compartment.
To reiderate their is two types of refrigerators,one that you have to manually defrost and a automatic defrost type where the defrost system which is comprised of the defrost heater,timer&termination t-stat will automatically melt the frost
Jul 28, 2011 | Refrigerators
Glrt183tdwh freezer is very cold (some frost)
There are two likely culprits: 1) You're fridge is stuffed and its blocking the inlet from the freezer (where all the cold air originates) - so pull some of the stuff out and see if this fixes the problem - let the air circulate.
Otherwise, your fan is broken and it can't circulate the air effectively, and you will need to replace the fan.
Mar 31, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire top-mount refig. freezer won't get cold ,temp.stays around 26 degrees, refrig. don't keep milk cold enough
check that the evaporator fan motor ,located in freezer is working.it circulates the cold air.also check that the coils behind freezer back panel are not iced up,this would indicate a lack of defroting due to,timer,heating element,or bi-metal.lastly when the refrig is running those coils should get frost over them all,if not you may be low on refigerant
Jan 20, 2010 | Frigidaire FRT17G5CSB Top Freezer...
Does not get cold
I'm not sure if you mean it's not getting cold enough or dot at all.
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. If there is a lot of build up then the defrost timer may need to be replaced.
Most of the time the evaporator coils and fan are located behind panels in the freezer section. These are usually easy to remove. The defrost timer is a different story and may require the help of a service person.
Hope this helps.
Sep 14, 2009 | Frigidaire FRS26R4A Side by Side...
Freezer wrk OK but temperature in the bottom fridge not cold
If you have a frost build up on the interior back wall of the freezer, you have a defrost issue. This would include a bad defrost control, bad heater or terminator.
If there is not a frost build up then you may have a bad evaporator fan motor.
Apr 28, 2009 | Frigidaire FRT17G4B Top Freezer...
My fridge is not cooling and will get cold forming ice and later will defrost...Is this because the freon is leaking or something alse altogether?
My fridge is running but not cold enough: Start out with the easy stuff first...make sure the lights go out when you close the door(s), make sure the doors are closing properly and the gaskets are closing fully and not torn. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the fan motor and also check the fan switches around the door openings, ( if your fridge has these switches, not all do ). A common problem cropping up in the last several years has been the air damper not opening up and allowing the cold air from the freezer to be blown into the fresh food section ( mostly on SxS refrigerators ). For many years the air damper was manually operated and now we have motorized controlled or temperature controlled or thermister and electronic boards controlling air dampers, and if this device sticks closed the FF section will normally warm up. An example picture of "one" style and an air damper ( called a diffuser by Whirlpool ). Next would be to check the condenser tubing, a good place to start is to make sure the condenser coils are not built up with dust!! Make sure the condenser fan motor is also working properly. Check for any "clicking on and off" noises from the compressor, is the compressor running.
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
*One new safety device added to refrigerators in the last few years has been a in-line fuse added to both sides of the defrost heater. If one of these fuses let's go, you must replace the whole defrost heater, as it comes as an assembly. If the defrost heater does not work, you should check for one of these fuses being open. Check it with a volt meter or ohm meter.
New link from Appliance Repair Aid on how the wiring circuit works for a frost free fridge, the link is here.
On a frost free refrigerator, the cooling coils should be in the freezer section. On a SxS style refrigerator the coils will be behind a cover on the back wall.  On a freezer on top style the coils could be behind the back wall or under the freezer floor. Removing the cover and exposing the evaporator coils could be a valuable tool. Seeing what the cooling coils looks like may help split your not cooling problem. Totally covered coils with white snow is a frost free problem. A ball of ice on the coils and the rest of the cooling coils are bare or only a few coils frosted a little and the rest are bare is an indication of a system problem. Example picture oneexample picture twoexample picture three. System problems may be a leak in the refrigeration tubing, an inefficient not 100% pumping compressor.
Feb 26, 2009 | Frigidaire Refrigerators
Fridge not cooling- top freezer frosting over
"Fan in freezer does not seem to be running"
This wiil cause it to frost up in the freezer and this fan is the only way to get cold air into the Fridge area.
Dec 22, 2008 | Frigidaire FRT18FS6C Top Freezer...
HELP!
Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing by compressor, Check Recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting,
Sep 13, 2007 | Frigidaire FRS266ZDSB Side by Side...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
